Is there any version of "testdisk" that can be run from the Android environment
Emanuel2558
Hey to all, is there any version of "testdisk" that can be run from the Android environment like an Android app? or at least to run it from Android terminal?
Re: Is there any version of "testdisk" that can be run from the Android environment
photorec can be compiled using Android NDK and run from a terminal using cli command in a rooted Android.
It's easier to export the internal memory using dd and nc or ssh to another computer or even to copy the memory to an sdcard
See https://android.stackexchange.com/quest ... -android-d
https://roubert.name/joakim/androidfilerecovery/
