Help! 8tb drive became raw, partitions not found
miwashi
#1 Post by miwashi »
I just tried testdisk and this is what I got:
Disk /dev/sdb - 8001 GB / 7452 GiB - CHS 972801 255 63
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
 2 P MS Data                   264192 15628052479 15627788288 [Basic data partition]
It's a single partition, so I think the first one was automatically created by windows.
It says no FAT NTFS etc found.
A quick search says the partition cannot be recoverd. "Can't open filesystem. Filesystem seems damaged". I'm running the deeper search now but I think it might take a few days to complete.
Is there any quicker way to check if this is going to succeed before the deeper search ends?
Re: Help! 8tb drive became raw, partitions not found
If you think your partition was an NTFS partition, go in Advanced, Type, set MS Data and next NTFS, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit
JonnyTestdisk
#3 Post by JonnyTestdisk »
Im curious to know if your able to get your RAW disk fixed. The same thing happened to my 1 terabyte, and 'deep scan' was not able to fix it. I dont have another drive larger to i cant reformat at the moment.
Now if you have data you need to get off, and space, at least for the important stuff, you can try to access your drive in a linux OS, for me that still works. But to actually fix the drive w/out reformatting, thats my mission and could use any clues you may run in to. and i will likewise try to help you if i can. Like i said you may still be able to access your drive from a linux machine, if you dont have one, burn Lubuntu to a liveCD (may have to be a dvd), and boot from the disk. Then try plugging in your 8tb and you may have access.. again this is not a fix but a way to recover important data if needed..
miwashi
#4 Post by miwashi »
I couldn't get it fixed and lost everythin
testdisk found nothing but corrupted file systems
strange how NTFS and GPT is supposed to keep redundant file tables but it doesn't help at all.
