Unfinalized wav and photorec option
Hi a recording got interrupted ,power cut- and after that dir showed a 0 size file.Ran photorec without changing advanced option -keep corrupted file off.Does that mean file got deleted instead of recoverwd bacause I cant see its name i(and size 0) in dir folder any longer?other software cant see that file name as deleted either!
Re: Unfinalized wav and photorec option
The wav header may be missing completly, so I don't know if it's possible to recover the file or not...
Try using PhotoRec with keep corrupted file on.
