Recovery shared folder on QNAP TS-209 II
danielemarchi68
#1 Post by danielemarchi68 »
Hi Guys!
Please help me...
Accidentally I have deleted shared folder and all data. My Qnap have 2 disk in RAID 1 (Mirror). I would like to recover this folder and data. I need to recreate original geometry inside this shared folder. How can I do? Which program use?
Thanks a lot
Daniele
Re: Recovery shared folder on QNAP TS-209 II
You should run PhotoRec on the QNAP itself or on a computer running Linux with the disks from the QNAP.
Select /dev/mdX for the correct software raid device.
Be careful to store the recovered files on other disks (not the disk from the QNAP).
https://www.cgsecurity.org/testdisk.pdf explains how to create a Linux bootable USB key.
