My laptop (Lenovo ThinkPad T450s) has a Windows 8 partition and an Ubuntu partition. Yesterday, in the Ubuntu partition, I ran "sudo rm -rf /* instead of "sudo rm -rf ./*", so I lost everything, so am trying to use testdisk to recover what I can. I was able to run Quick Search, it found an NTFS partition (Image 1), and it was able to list the files, or at least the folders, in the root directory. I attempted to copy them all over to an external hard drive (image 2). The first time, I may have used the destination, since I thought it would be /dev/sdc like it says. It copied about 200000 successfully, but 300000 failed. I then thought that /media was the right place, but now testdisk is frozen at 0 ok, 298520 failed (Image 3). It's been over 18 hours now. I was wondering if I should force shutdown my computer and restart the process by copying smaller components at a time? Or if force shutting down would cause more data to be lost.
I have attached the following pictures (I dont have access to the .log file currently):
Image 1: partition found by quick search
Image 2: Results after running sudo fdisk -l. 1st device is the hard drive I am trying to recover, 2nd device is my USB that GParted is running off of, 3rd device is my external hard drive I am trying to copy my files over to. The 3rd drive is a harddrive from a Windows 10 computer which is why it has the partitions.
Image 3: Image of my screen currently, where testdisk is frozen.
Testdisk Frozen
Testdisk Frozen
- Image 2.jpeg (121.5 KiB) Viewed 4262 times
- Image 3.jpeg (118.86 KiB) Viewed 4262 times
- Image 1.jpeg (70.94 KiB) Viewed 4262 times
Re: Testdisk Frozen
Run "dmesg", it may output io error message and explain the problem.
If testdisk has been able to list the files, the files on the NTFS partition are probably not be deleted.
