configure file missing in archive Topic is solved
mbiwer
#1 Post by mbiwer »
I am trying to install testdisk/photorec according to https://www.cgsecurity.org/testdisk.pdf.
  • running Xubuntu 18.04 LTS
  • installed the compilation environment
    apt-get install -y build-essential ...... dh-autoreconf git
  • extracted with tar xjf ...
There is no file "configure" in the resulting directory testdisk-7.1-WIP.
Tried the same with the 32-bit-archive (www.cgsecurity.org/testdisk-7.0.linux26.tar.bz2) and the git repository (git clone https://git.cgsecurity.org/testdisk.git. Same result - no configure file. Where am I wrong???
Thanks in advance for any help!
https://www.cgsecurity.org/testdisk-7.1 ... 26.tar.bz2
Re: configure file missing in archive
You have downloaded 32-bits and 64-bits binary packages, so no configure script is present. You can use the photorec_static or testdisk_static binaries directly.
When using git to get the source code, you have to create the configure script as state in the documentation by using autoreconf:
cd testdisk
mkdir config
autoreconf --install -W all -I config
./configure
make
mbiwer
#3 Post by mbiwer »
Christophe, merci beaucoup! Works great now.
