Hi Thank you for the great software.
I'm extracting images from E01 file using photorec using script.
"photorec_win.exe" /debug /log /d "Results" /cmd "/cygdrive/C/Users/Admin\Desktop/EO1 Multi/Multi Test E01.E01", fileopt,everything,enable,search
which is working fine, but if i add the split the E01 in chunks and use the same script with ??? in the as suggested in the documentation, it give me Exception file not found.
"photorec_win.exe" /debug /log /d "Results" /cmd "/cygdrive/C/Users/Admin\Desktop/EO1 Multi/Multi Test E01.???", fileopt,everything,enable,search
Here is the exact output which i get.
PhotoRec 7.1-WIP, Data Recovery Utility, April 2018
Unable to open file or device C:/Users/Admin/Desktop/EO1 Multi/Multi Test E01.???: No such file or directory
Unable to open file or device when using command for ??? for multi E01 files
haideraqeel86
Re: Unable to open file or device when using command for ??? for multi E01 files
If there are less than 100 files, you may want to try ".E??", otherwise check that you don't have a "Multi Test E01.txt" file.
