Hello there,
I have a Seagate External Harddisk which i have been using for more than 5 years now. It started to give some device I/O errors while copying files to and from the drive to windows, which then i had to unplug/plug the hdd again to acces it. So i decided to clear the contents and try to format and fix the drive. While i was getting my files to at some point it all went black and windows started not recognising the drive.
The symptoms:
1-) when i plug the drive it is shown as generic Local Disk I: and requires to be formatted to be used.
2-) I thought to format the drive and recover the files using a recovery program but windows cannot complete the format either.
3-) My Samsung TV recognises the drive without problem and the files can be accessed/used like nothing happened.
4-) Cannot access anything on the harddrive in windows.
5-) TestDisk can see the disk and its size correctly but cannot find any partition when analysed, i have started whole analyse procces with creating a log this time and will try deeper search.
I searched the forums but the solutions similar to my problems cannot be done because no partition had show up in testdisk so i don't know what to do.
Any help or recommendation is muchly appriciated as i am a newby in this topic.
HDD stopped being recognised/Tv still sees...
Re: HDD stopped being recognised/Tv still sees...
Hi Weroc.
I have the same problem And situation. A WD passport USB3 that usually I used with the PC. I put it into a new Samsung TV Led 5000 series... and from that time i can access to the files only from Samsung TV. But obviously I cannot copy them. I tried a lot of software and now I trying this.
Windows ask me to format the drive and I say no.
I have a solution but I cannot due a limitation of my TV. There is the hack tool for Samsung Tv called Samygo. Potentially you can install Samba Server on your TV. Unfortunately my TV has a firmware that does not support Samygo and I'm looking for a another TV.
Good luck
Good luck
