After deep scan, patitions not found
kkofg
#1 Post by kkofg »
Hello, I'm accidentally hit my 128gb flash drive then it always asked for format all the time. When I check disk, it's raw file so I used testdisk-7.1 to scan for recovery partitions. But after deep scan, partitions still not found. I'm not sure about how to used testdisk so please help me. I don't know what can I do.
Thank you
https://ibb.co/emM4S8
https://ibb.co/iOa9uo
https://ibb.co/iRfL0T
https://ibb.co/cumSfT
https://ibb.co/jrDjS8
I try again by pressing Advance then it's show as picture below. What can I do next? Please help.
https://ibb.co/cdH8N8
Thank you
Tara
Re: After deep scan, patitions not found
#2 Post by Tara »
Hi, did you find any answer? I have a similar problem and I had to use PhotoRec which is not ideal for me.
