Recover original partition after using Windows Disk Management
MattWright
#1 Post by MattWright »
Hi all, I could really use some help here.
We have a computer that dual boots Ubuntu and Windows. We had an external harddrive in there that was visible in Ubuntu. It is 8TB so I assume its partition table was GPT although I do not know for sure. Someone tried to access this drive from Windows recently. They went through the Disk Management utility and used the Initialize Disk menu to initialize a logical disk using the GPT option. Screen shot below is from another website showing the same situation but it is reflective of what was done here (the event wasn't recorded here). Now the disk reads as empty by both Windows and Ubuntu. The data on the disk was extremely sensitive and its extremely important that I figure out how to recover it.
I started a scan with testdisk. In the menu that offers a [Quick Search] the partition is recognized as being Microsoft Reserved. If I start the scan with the [Intel] option selected for the partition table type it shows the same Linux partition listed several times with the correct harddrive name. This does not make sense to me since an 8TB harddrive should have been using a GPT from the beginning and I understood that the [Intel] option searched for MBR partitions. If we run the scan using the [EFI GPT] option selected, then the partitions are found elsewhere and are labelled as MS Data.
How can I retreieve my original data??
Re: Recover original partition after using Windows Disk Management
Using the key "p", can you list the content of the listed partitions ?
If the partitions are valid, set them to P(rimary) and on next screen, choose Write, confirm, Quit and restart your computer.
MattWright
#3 Post by MattWright »
The scans are still running and look like they will take several hours. I believe TestDisk is scanning the entire disk, even though I am confident it has already found all it will find (the disks only ever had a single partition). Is it possible to stop the scans and try to list the partitions' contents before the scan has completed?
MattWright
#4 Post by MattWright »
And could you possibly explain a little bit more what is happening when I scan with different table options, ie. why [Intel] produces partitions labelled "Linux" and [EFI GPT] produces partitions labelled "MS Data"?
MattWright
#5 Post by MattWright »
During the scan, several Linux partitions were listed at a CHS Start of 0 0 1, as I hoped. These even had the correct name that we had assigned to the drive listed at the right. I was waiting until the scan finished to try to view the files in these. However, once the scan finished, the only partition listed was FAT16 LBA at CHS Start of 366887 132 61. I was looking forward to testing the Linux partition and it has disappeared in the scan results.
#6 Post by cgrenier »
An ext4 filesystem will be in a Linux (83) partition when using using a PC Intel partition table and an MS Data (the same used by an NTFS filesystem) when using a EFI GPT partition table.
Please provide a copy/paste of the testdisk.log file content if you will information about testdisk results.
MattWright
#7 Post by MattWright »
For sure. Sorry I have been unable to follow up for a few days. The forum will not let me attach the image so I am pasting it here.
This is from a run where I killed test disk knowing where it would end up. By the time it was killed it had already listed the Linux partition.
Thu Jun 28 11:29:03 2018
OS: Linux, kernel 4.13.0-45-generic (#50~16.04.1-Ubuntu SMP Wed May 30 11:18:27 UTC 2018) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sdb: size 15628053168 sectors
/dev/sdb: user_max 15628053168 sectors
/dev/sdb: native_max 15628053168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 15628053168 sectors
/dev/sdc: user_max 15628053168 sectors
/dev/sdc: native_max 15628053168 sectors
/dev/sdd: LBA, LBA48 support
/dev/sdd: size 1025610768 sectors
/dev/sdd: user_max 1025610768 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:S1DBH6AM, FW:CC56
Disk /dev/sdb - 8001 GB / 7452 GiB - CHS 972801 255 63, sector size=512 - HGST HDN728080ALE604, S/N:R6GSALDY, FW:A4GNW91X
Disk /dev/sdc - 8001 GB / 7452 GiB - CHS 972801 255 63, sector size=512 - HGST HDN728080ALE604, S/N:R6GS5P6Y, FW:A4GNW91X
Disk /dev/sdd - 525 GB / 489 GiB - CHS 63841 255 63, sector size=512 - Crucial_CT525MX300SSD1, S/N:164914EE6EC5, FW:M0CR031
Disk /dev/sdc - 8001 GB / 7452 GiB - HGST HDN728080ALE604
Analyse Disk /dev/sdc - 8001 GB / 7452 GiB - CHS 972801 255 63
block_group_nr 1
recover_EXT2: s_block_group_nr=1/59616, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
recover_EXT2: s_blocks_count 1953506646
recover_EXT2: part_size 15628053168
Linux 0 0 1 972801 80 63 15628053168 [AMI Data 4]
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 8001 GB / 7452 GiB
Partition not added.
block_group_nr 3
recover_EXT2: s_block_group_nr=3/59616, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/59616, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/59616, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/59616, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
SIGINT detected! TestDisk has been killed.
