Raid Recovery - Files Recoverable / Partition Help
sherman
#1 Post by sherman »
Current situation - Raid Level 5 Failed After Bios Update
I am able to recover files one by one, or by folder, but I am not able to properly recover the entire partition by writing the boot block.
Followed all the steps over and over again, but the partition itself won't come back...
I can provide the log file if needed.
Thank you for your help in advance!
S
Re: Raid Recovery - Files Recoverable / Partition Help
If you can list the files using TestDisk but not from your OS, it looks like a filesystem corruption.
Try "Repairing filesystem" from https://www.cgsecurity.org/testdisk.pdf
