(Actually I am reworking the text that I mis-posted on user pages
And I set days aside and am working on this issue solely for a few dozen hours already with very likely more hours ahead for me..
Here is the testdisk.log
It is biggish, but also the issues to solve seem to be a little complex to me.
Using locale 'en_US.UTF-8'.
Tue Mar 6 08:03:42 2012
Command line: TestDisk /log
OS: Linux, kernel 3.0.21-std250-amd64 (#2 SMP Mon Feb 13 19:49:17 UTC 2012) x86_64
Compiler: GCC 4.4
Compilation date: 2012-02-12T15:21:55
ext2fs lib: 1.42, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: none
/dev/sda: size 390721968 sectors
/dev/sda: user_max 390721968 sectors
/dev/sda: native_max 390721968 sectors
/dev/sda: dco 390721968 sectors
/dev/sdb: size 488397168 sectors
/dev/sdb: user_max 488397168 sectors
/dev/sdb: native_max 488397168 sectors
/dev/sdb: dco 488397168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 488397168 sectors
/dev/sdc: user_max 488397168 sectors
/dev/sdc: native_max 488397168 sectors
/dev/sdc: dco 488397168 sectors
/dev/sdd: LBA, HPA, LBA48, DCO support
/dev/sdd: size 488397168 sectors
/dev/sdd: user_max 488397168 sectors
/dev/sdd: native_max 488397168 sectors
/dev/sdd: dco 488397168 sectors
/dev/sdf: LBA, HPA, LBA48, DCO support
/dev/sdf: size 390721968 sectors
/dev/sdf: user_max 390721968 sectors
/dev/sdf: native_max 390721968 sectors
/dev/sdf: dco 390721968 sectors
Warning: can't get size for Disk /dev/md - 0 B - CHS 1 1 1 (RO), sector size=512
Warning: can't get size for Disk /dev/md125 - 0 B - CHS 1 2 4, sector size=512
Warning: can't get size for Disk /dev/md126 - 0 B - CHS 1 2 4, sector size=512
Disk /dev/sda - 200 GB / 186 GiB - CHS 24321 255 63, sector size=512 - ST3200820AS, S/N:5QE1VT50, FW:3.AAE
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST3250410AS, S/N:9RY0KQXD, FW:3.AAC
Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST3250410AS, S/N:9RY1EEZJ, FW:3.AAC
Disk /dev/sdd - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST3250410AS, S/N:9RY1503E, FW:3.AAC
Disk /dev/sde - 16 GB / 15 GiB - CHS 15480 64 32, sector size=512 - JetFlash Transcend 16GB, FW:1100
Disk /dev/sdf - 200 GB / 186 GiB - CHS 24321 255 63, sector size=512 - WDC WD2000KS-00MJB0, S/N:WD-WCANK5931037, FW:02.01C03
Disk /dev/sdg - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - Freecom Hard Drive XS, FW:1.00
Disk /dev/md127 - 9869 MB / 9412 MiB - CHS 2409600 2 4, sector size=512
Tue Mar 6 08:08:15 2012
Compiler: GCC 4.4
Tue Mar 6 08:08:46 2012
Compiler: GCC 4.4
Disk /dev/sdb - 250 GB / 232 GiB - ST3250410AS
Analyse Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63
Raid magic value at 33/0/1
Raid apparent size: 12851712 sectors
Raid chunk size: 131072 bytes
check_MD 0.90
Raid magic value at 833/1/1
Raid apparent size: 4819200 sectors
check_MD 0.90
Raid magic value at 1133/1/1
Raid apparent size: 372514816 sectors
check_MD 0.90
get_geometry_from_list_part_aux head=255 nbr=12
1 * Linux 0 1 1 32 254 63 530082
2 P Linux RAID 33 0 1 832 254 63 12852000 [md125]
3 E extended 833 0 1 30400 254 63 475009920
5 L Linux RAID 833 1 1 1132 254 63 4819437 [md127]
X extended 1133 0 1 24320 254 63 372515220
6 L Linux RAID 1133 1 1 24320 254 63 372515157 [md127]
Backup partition structure
Ask the user for vista mode
search_vista_part: 0
Linux 0 1 1 32 252 27 529920
EXT2 Sparse superblock, 271 MB / 258 MiB
FAT32 LBA 1018 0 1 2946 172 59 30984215 [NO NAME]
FAT32, 15 GB / 14 GiB
2 drwxr-xr-x 0 0 2048 2-Feb-2012 14:32 .
2 drwxr-xr-x 0 0 2048 2-Feb-2012 14:32 ..
11 drwx------ 0 0 12288 1-Jan-2008 18:01 lost+found
12 lrwxrwxrwx 0 0 1 1-Jan-2008 20:03 boot
13 -rw-r--r-- 0 0 0 25-Aug-2011 14:03 .keep
14 -rw-r--r-- 0 0 4455280 23-Dec-2011 22:16 vmlinuz-3.1.5-hardened-111223_2200
15 -rw-r--r-- 0 0 2483392 23-Dec-2011 22:16 System.map-3.1.5-hardened-111223_2200
16 -rw-r--r-- 0 0 80618 23-Dec-2011 22:16 config-3.1.5-hardened-111223_2200
6034 lrwxrwxrwx 0 0 33 26-Jan-2012 08:53 config.old
18 -rw-r--r-- 0 0 4456976 28-Dec-2011 15:32 vmlinuz-3.1.6-hardened-111228_1600
19 -rw-r--r-- 0 0 2483577 28-Dec-2011 15:32 System.map-3.1.6-hardened-111228_1600
2009 -rw-r--r-- 0 0 2436551 7-Dec-2011 23:41 System.map-3.0.4-hardened-r5-111208_0000
2010 -rw-r--r-- 0 0 79718 7-Dec-2011 23:41 config-3.0.4-hardened-r5-111208_0000
6025 -rw-r--r-- 0 0 80655 28-Dec-2011 15:32 config-3.1.6-hardened-111228_1600
6029 lrwxrwxrwx 0 0 36 2-Feb-2012 12:15 config
38153 drwxr-xr-x 0 0 1024 2-Feb-2012 14:35 grub
64269 -rw-r--r-- 0 0 4415568 6-Dec-2011 19:47 vmlinuz-3.0.4-hardened-r5-111206_2000
64270 -rw-r--r-- 0 0 2436551 6-Dec-2011 19:47 System.map-3.0.4-hardened-r5-111206_2000
64271 -rw-r--r-- 0 0 79728 6-Dec-2011 19:47 config-3.0.4-hardened-r5-111206_2000
64272 -rw-r--r-- 0 0 4415408 7-Dec-2011 23:41 vmlinuz-3.0.4-hardened-r5-111208_0000
6031 -rw-r--r-- 0 0 4456880 8-Jan-2012 15:16 vmlinuz-3.1.7-hardened-120108_1500
10041 -rw-r--r-- 0 0 2483549 8-Jan-2012 15:16 System.map-3.1.7-hardened-120108_1500
10042 -rw-r--r-- 0 0 80655 8-Jan-2012 15:16 config-3.1.7-hardened-120108_1500
6026 -rw-r--r-- 0 0 4459600 12-Jan-2012 20:27 vmlinuz-3.1.8-hardened-120113_2100
6027 -rw-r--r-- 0 0 2484178 12-Jan-2012 20:27 System.map-3.1.8-hardened-120113_2100
6028 -rw-r--r-- 0 0 80655 12-Jan-2012 20:27 config-3.1.8-hardened-120113_2100
6030 -rw-r--r-- 0 0 4417104 26-Jan-2012 08:53 vmlinuz-3.2.1-hardened-120126_0900
6032 -rw-r--r-- 0 0 2461963 26-Jan-2012 08:53 System.map-3.2.1-hardened-120126_0900
6033 -rw-r--r-- 0 0 81249 26-Jan-2012 08:53 config-3.2.1-hardened-120126_0900
6035 -rw-r--r-- 0 0 4572560 2-Feb-2012 12:15 vmlinuz-3.2.2-hardened-r1-120202_1300
6036 -rw-r--r-- 0 0 2558205 2-Feb-2012 12:15 System.map-3.2.2-hardened-r1-120202_1300
6037 -rw-r--r-- 0 0 81298 2-Feb-2012 12:15 config-3.2.2-hardened-r1-120202_1300
2 P FAT32 LBA 1018 0 1 2946 254 63 30989385 [NO NAME]
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
EXT2 Sparse superblock Backup superblock, 271 MB / 258 MiB
Disk /dev/sda - 200 GB / 186 GiB - ST3200820AS
Analyse Disk /dev/sda - 200 GB / 186 GiB - CHS 24321 255 63
check_MD 0.90
check_MD 0.90
check_MD 0.90
3 E extended 833 0 1 24320 254 63 377334720
Linux 833 0 1 24320 254 63 377334720
EXT2 Large file Sparse superblock, 193 GB / 179 GiB
get_geometry_from_list_part_aux head=255 nbr=3
2 P Linux 833 0 1 24320 254 63 377334720
recover_EXT2: part_offset problem
Linux 833 1 1 2032 236 60 19276800
EXT3 Large file Sparse superblock Recover, 9869 MB / 9412 MiB
Raid magic value at 1132/251/16
Linux RAID 833 1 1 1132 253 17 4819328 [md127]
md 0.90.0 Raid 5: devices 0(8,5)* 1(8,21) 2(8,37) 3(8,53), 2467 MB / 2353 MiB
get_geometry_from_list_part_aux head=8 nbr=3
get_geometry_from_list_part_aux head=16 nbr=3
get_geometry_from_list_part_aux head=32 nbr=3
get_geometry_from_list_part_aux head=64 nbr=3
Change partition type:
Linux RAID 33 0 1 24320 254 63 390186720
P Linux RAID 33 0 1 24320 254 63 390186720
2 P Linux RAID 33 0 1 24320 254 63 390186720
Disk /dev/sdc - 250 GB / 232 GiB - ST3250410AS
Analyse Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63
check_MD 0.90
check_MD 0.90
check_MD 0.90
Linux 33 0 1 2432 241 18 38555136
EXT3 Large file Sparse superblock Recover, 19 GB / 18 GiB
ext2fs_dir_iterate failed with error 2133571402.
Directory /grub
38153 drwxr-xr-x 0 0 1024 2-Feb-2012 14:35 .
38156 lrwxrwxrwx 0 0 9 1-Jan-2008 23:58 menu.lst
38155 -rw-r--r-- 0 0 33856 25-Aug-2011 14:03 splash.xpm.gz
38165 -rw-r--r-- 0 0 104592 25-Aug-2011 14:03 stage2
38172 -rw-r--r-- 0 0 1204 2-Feb-2012 14:35 grub.conf
38157 -rw-r--r-- 0 0 8604 25-Aug-2011 14:03 e2fs_stage1_5
38158 -rw-r--r-- 0 0 7904 25-Aug-2011 14:03 fat_stage1_5
38159 -rw-r--r-- 0 0 7152 25-Aug-2011 14:03 ffs_stage1_5
38160 -rw-r--r-- 0 0 7168 25-Aug-2011 14:03 iso9660_stage1_5
38161 -rw-r--r-- 0 0 8604 25-Aug-2011 14:03 jfs_stage1_5
38162 -rw-r--r-- 0 0 7320 25-Aug-2011 14:03 minix_stage1_5
38163 -rw-r--r-- 0 0 9548 25-Aug-2011 14:03 reiserfs_stage1_5
38164 -rw-r--r-- 0 0 512 25-Aug-2011 14:03 stage1
38166 -rw-r--r-- 0 0 104592 25-Aug-2011 14:03 stage2_eltorito
38167 -rw-r--r-- 0 0 7420 25-Aug-2011 14:03 ufs2_stage1_5
38168 -rw-r--r-- 0 0 6784 25-Aug-2011 14:03 vstafs_stage1_5
38169 -rw-r--r-- 0 0 9236 25-Aug-2011 14:03 xfs_stage1_5
38154 -rw-r--r-- 0 0 107988 4-Jul-2010 06:49 stage2.old
38171 -rw-r--r-- 0 0 1045 26-Jan-2012 09:07 grub.conf~
38173 -rw-r--r-- 0 0 105 27-Feb-2008 22:08 device.map
38174 -rw-r--r-- 0 0 733 29-Feb-2008 10:48 grub.conf.bak
38170 -rw-r--r-- 0 0 197 16-Jun-2008 15:37 default
2 P Linux 33 0 1 2432 254 63 38556000
Raid magic value at 832/252/30
Linux RAID 33 2 3 832 254 31 12851840 [md125]
md 0.90.0 Raid 6: devices 0(8,82) 1(8,50) 3(8,18) 4(8,34)*, 6580 MB / 6275 MiB
Linux 796 73 46 1996 54 42 19276800
EXT3 Large file Sparse superblock Backup superblock, 9869 MB / 9412 MiB
Linux LVM 1133 1 1 317949588 202 34 1868071381418752
LVM2, 956452 TB / 869888 TiB
This partition ends after the disk limits.
The harddisk (250 GB / 232 GiB) seems too small! (< 956452 TB / 869888 TiB)
Directory /grub
Disk /dev/sdd - 250 GB / 232 GiB - ST3250410AS
check_MD 0.90
check_MD 0.90
check_MD 0.90
md 0.90.0 Raid 6: devices 0(8,82) 1(8,50)* 3(8,18) 4(8,34), 6580 MB / 6275 MiB
md 0.90.0 Raid 5: devices 0(8,5) 1(8,21) 2(8,37) 3(8,53)*, 2467 MB / 2353 MiB
md 0.90.0 Raid 6: devices 0(8,86) 1(8,54)* 3(8,22) 4(8,38), 190 GB / 177 GiB
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : No
Analyse Disk /dev/sdd - 250 GB / 232 GiB - CHS 30401 255 63
check_MD 0.90
check_MD 0.90
check_MD 0.90
Linux LVM 1133 1 1 70696 236 48 1117544448
LVM2, 572 GB / 532 GiB
Raid magic value at 24320/251/40
Linux RAID 1133 3 3 24320 253 41 372514944 [md127]
The harddisk (250 GB / 232 GiB) seems too small! (< 581 GB / 541 GiB)
Disk /dev/sdf - 200 GB / 186 GiB - WDC WD2000KS-00MJB0
Analyse Disk /dev/sdf - 200 GB / 186 GiB - CHS 24321 255 63
check_MD 0.90
check_MD 0.90
check_MD 0.90
md 0.90.0 Raid 6: devices 0(8,82)* 3(8,18) 5(8,2) 6(8,50), 6580 MB / 6275 MiB
md 0.90.0 Raid 5: devices 0(8,5) 1(8,21) 2(8,37) 3(8,53), 2467 MB / 2353 MiB
Linux LVM 1133 1 1 2729172821 159 54 2251800930705408
LVM2, 1152922 TB / 1048576 TiB
The harddisk (200 GB / 186 GiB) seems too small! (< 1152922 TB / 1048576 TiB)
In the first place, the following is in Croatian, but someone who is interested into a down-to-earth real reasons behind my possible huge data loss, she/he can have a gander at it.
That's the gizmo which I wouln't give to my enemies for their use, unless they really need be stopped sick from computing! A short look at minute 3rd from start:
http://youtu.be/cjN9dc2YkfE?t=3m20s
And 7th: http://youtu.be/cjN9dc2YkfE?t=7m14s
But it's probably irrelevant that its that particular WD model. Any other disk could have gotten near totally broken by an accidental drop (Or the strange doings on my LVM2 raid6 caught by testdik.log below, could that be viri related?)... Well, if damaged, it is only near totally, that is, not sufficiently broken, for someone with insufficient mind to try to peddle it to you as "new, only formatted"... Yeah, I was said that about the gizmo. Yes, I was! And I saw this "new, only formtted disk" briefly, I really did, with:
$ ls -l /mnt/sdX"Bus error!" and that box's monitor went black. Dead! Dead as the dodo! Phew!
Never mind! Back to work.
I'll try and make a plan what to do to recover my data.
In the first place, I made the images of the five disks that make the permanent set in this one of my four similar boxes (all four same AT8-32X Abit MBO, long-years clones of each others, containing Gentoo Linuces, most of the time up to date, such as testing branch ~amd64), in the following way:
dd if=/dev/sda of=12-03-05_at8-g200_sda.ddto get these images:
at8-g250-b sdf1 # ls -l *.dd
-rw-r--r-- 1 root root 200049647616 2012-03-05 21:08 12-03-05_at8-g200_sda.dd
-rw-r--r-- 1 root root 250059350016 2012-03-05 23:51 12-03-05_at8-g200_sdb.dd
-rw-r--r-- 1 root root 250059350016 2012-03-06 02:35 12-03-05_at8-g200_sdc.dd
-rw-r--r-- 1 root root 250059350016 2012-03-06 05:23 12-03-05_at8-g200_sdd.dd
-rw-r--r-- 1 root root 200049647616 2012-03-06 07:36 12-03-05_at8-g200_sdg.dd
at8-g250-b sdf1 # I am rather confident I would be able to restore these disks via the files above into the exact state as before I ventured with any looking into their state early yesterday morning.
at8-g250-b is another clone of the four where I'm looking at it now and writing this. My cloned Gentoo's are networked together, I can usually ssh into one from another.
The one clone in question as per the data loss or recover, is at8-g200. Real hostnames, I have more urgent need to recover from this huge potential loss, than to hide anything.
Here follows the telling of smartmontools (basically all PASSED), on the disks in questions.
I have named the output by the command input. Such as
$ smartctl -H /dev/sdbCode: Select all
12-03-05_at8-g200_sdb.smartctl-H_sdbCode: Select all
$ smartctl -i /dev/sdbCode: Select all
12-03-05_at8-g200_sdb.smartctl-i_sdbCode: Select all
12-03-05_at8-g200_sda.smartctl-H_sda
smartctl 5.40 2010-10-16 r3189 [i486-pc-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
12-03-05_at8-g200_sda.smartctl-i_sda
Model Family: Seagate Barracuda 7200.10 family
Device Model: ST3200820AS
Serial Number: 5QE1VT50
Firmware Version: 3.AAE
User Capacity: 200,049,647,616 bytes
ATA Version is: 7
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Mar 5 23:41:17 2012 UTC
SMART support is: Enabled
Device Model: ST3250410AS
Serial Number: 9RY0KQXD
Firmware Version: 3.AAC
User Capacity: 250,059,350,016 bytes
ATA Version is: 7
Local Time is: Mon Mar 5 23:42:07 2012 UTC
12-03-05_at8-g200_sdc.smartctl-H_sdc
12-03-05_at8-g200_sdc.smartctl-i_sdc
Serial Number: 9RY1EEZJ
ATA Version is: 7
Local Time is: Mon Mar 5 23:42:30 2012 UTC
12-03-05_at8-g200_sdd.smartctl-H_sdd
12-03-05_at8-g200_sdd.smartctl-i_sdd
Serial Number: 9RY1503E
ATA Version is: 7
Local Time is: Mon Mar 5 23:42:55 2012 UTC
12-03-05_at8-g200_sdg.smartctl-H_sdg
12-03-05_at8-g200_sdg.smartctl-i_sdg
Model Family: Western Digital Caviar SE16 Serial ATA family
Device Model: WDC WD2000KS-00MJB0
Serial Number: WD-WCANK5931037
Firmware Version: 02.01C03
ATA Version is: 7
Local Time is: Mon Mar 5 23:43:30 2012 UTC
