RAID 1 disk recovery
paded
#1 Post by paded »
2 TB disk, coming from UNITEK NAS Y 3357 cofigured as RAID 1
Deep search shows tons of partitions.
Is there any way to recover file structure ?
Mon Jul 23 08:53:10 2018
TestDisk 7.1-WIP, Data Recovery Utility, June 2018
OS: Darwin, kernel 15.6.0 (Darwin Kernel Version 15.6.0: Mon Oct 2 22:20:08 PDT 2017; root:xnu-3248.71.4~1/RELEASE_X86_64) x86_64
Compiler: GCC 4.0
Compilation date: Jul 19 201807:17:29
Disk /dev/disk0 - 240 GB / 223 GiB - 468862128 sectors (RO), sector size=512
Disk /dev/disk1 - 2000 GB / 1863 GiB - 3907029168 sectors (RO), sector size=512
Disk /dev/disk2 - 2000 GB / 1863 GiB - 3907029168 sectors (RO), sector size=512
Disk /dev/rdisk0 - 240 GB / 223 GiB - 468862128 sectors (RO), sector size=512
Disk /dev/rdisk1 - 2000 GB / 1863 GiB - 3907029168 sectors (RO), sector size=512
Disk /dev/rdisk2 - 2000 GB / 1863 GiB - 3907029168 sectors (RO), sector size=512
Media is opened in read-only.
Disk /dev/disk2 - 2000 GB / 1863 GiB (RO)
Analyse Disk /dev/disk2 - 2000 GB / 1863 GiB - 3907029168 sectors (RO)
get_geometry_from_list_part_aux head=1 nbr=2
1 P HPFS - NTFS 2048 3906926591 3906924544
exFAT, blocksize=131072, 2000 GB / 1862 GiB
Warning: the current number of heads per cylinder is 1 but the correct value may be 128.
* HPFS - NTFS 2048 3906926591 3906924544
NTFS signature is missing.
dir_partition inode=0
1 * HPFS - NTFS 2048 3906926591 3906924544
exFAT found using backup sector, blocksize=131072, 2000 GB / 1862 GiB
BAD_RS LBA=1364895074 740
FAT16 LBA 1364895074 5505367658 4140472585
This partition ends after the disk limits. (start=1364895074, size=4140472585, end=5505367658, disk end=3907029168)
BAD_RS LBA=673613077 593
HPFS - NTFS 673613077 2062945135 1389332059
BAD_RS LBA=1682138436 766
FAT12 1682138436 5656352813 3974214378
This partition ends after the disk limits. (start=1682138436, size=3974214378, end=5656352813, disk end=3907029168)
BAD_RS LBA=3204881114 340
FAT12 3204881114 4692013515 1487132402
This partition ends after the disk limits. (start=3204881114, size=1487132402, end=4692013515, disk end=3907029168)
BAD_RS LBA=1201533196 401
FAT12 1201533196 3143207569 1941674374
BAD_RS LBA=525985915 899
FAT16 <32M 525985915 2237323619 1711337705
BAD_RS LBA=335231423 960
FAT16 <32M 335231423 2258019956 1922788534
BAD_RS LBA=1708646719 235
FAT32 1708646719 3387509479 1678862761
BAD_RS LBA=165262602 425
FAT16 <32M 165262602 3809541963 3644279362
BAD_RS LBA=3632765482 884
FAT32 3632765482 6004166452 2371400971
This partition ends after the disk limits. (start=3632765482, size=2371400971, end=6004166452, disk end=3907029168)
BAD_RS LBA=1143312669 306
FAT16 >32M 1143312669 4502310482 3358997814
This partition ends after the disk limits. (start=1143312669, size=3358997814, end=4502310482, disk end=3907029168)
BAD_RS LBA=719672327 801
HPFS - NTFS 719672327 1627593305 907920979
BAD_RS LBA=3391498594 1121
FAT12 3391498594 4120516849 729018256
This partition ends after the disk limits. (start=3391498594, size=729018256, end=4120516849, disk end=3907029168)
BAD_RS LBA=2948831047 176
FAT12 2948831047 4264563752 1315732706
This partition ends after the disk limits. (start=2948831047, size=1315732706, end=4264563752, disk end=3907029168)
BAD_RS LBA=1396131090 902
FAT12 1396131090 5157256802 3761125713
This partition ends after the disk limits. (start=1396131090, size=3761125713, end=5157256802, disk end=3907029168)
BAD_RS LBA=2854956215 834
FAT32 LBA 2854956215 5840892736 2985936522
This partition ends after the disk limits. (start=2854956215, size=2985936522, end=5840892736, disk end=3907029168)
BAD_RS LBA=500086193 951
FAT16 >32M 500086193 1196544398 696458206
BAD_RS LBA=1132395242 1227
FAT32 1132395242 3551636886 2419241645
BAD_RS LBA=3940575846 927
HPFS - NTFS 3940575846 4312640543 372064698
This partition ends after the disk limits. (start=3940575846, size=372064698, end=4312640543, disk end=3907029168)
BAD_RS LBA=1735991856 608
FAT32 LBA 1735991856 2376701398 640709543
BAD_RS LBA=3126857735 283
FAT12 3126857735 3183658371 56800637
BAD_RS LBA=2645365853 936
FAT16 >32M 2645365853 3464324427 818958575
BAD_RS LBA=2635764288 365
HPFS - NTFS 2635764288 3850722149 1214957862
BAD_RS LBA=2901856811 615
FAT16 >32M 2901856811 3084752469 182895659
BAD_RS LBA=3801587539 828
HPFS - NTFS 3801587539 6131750461 2330162923
This partition ends after the disk limits. (start=3801587539, size=2330162923, end=6131750461, disk end=3907029168)
BAD_RS LBA=691106403 1009
FAT16 LBA 691106403 3577435031 2886328629
BAD_RS LBA=671937660 280
FAT32 671937660 715831920 43894261
BAD_RS LBA=1008149672 821
FAT16 <32M 1008149672 1888475757 880326086
BAD_RS LBA=497256209 415
FAT32 LBA 497256209 4077974823 3580718615
This partition ends after the disk limits. (start=497256209, size=3580718615, end=4077974823, disk end=3907029168)
BAD_RS LBA=2306088334 490
FAT12 2306088334 2637277632 331189299
BAD_RS LBA=343805336 291
FAT16 <32M 343805336 3577246786 3233441451
BAD_RS LBA=2935967760 1123
FAT32 LBA 2935967760 4049811104 1113843345
This partition ends after the disk limits. (start=2935967760, size=1113843345, end=4049811104, disk end=3907029168)
BAD_RS LBA=4116598887 295
FAT16 LBA 4116598887 8399314624 4282715738
This partition ends after the disk limits. (start=4116598887, size=4282715738, end=8399314624, disk end=3907029168)
BAD_RS LBA=999562510 476
HPFS - NTFS 999562510 3291655922 2292093413
BAD_RS LBA=3255482647 762
FAT32 LBA 3255482647 4096848918 841366272
This partition ends after the disk limits. (start=3255482647, size=841366272, end=4096848918, disk end=3907029168)
BAD_RS LBA=670291815 584
FAT16 <32M 670291815 694132006 23840192
BAD_RS LBA=961829566 1100
FAT16 <32M 961829566 1458842684 497013119
BAD_RS LBA=404935431 809
FAT16 <32M 404935431 879828938 474893508
BAD_RS LBA=4041954780 733
FAT16 >32M 4041954780 6115060049 2073105270
This partition ends after the disk limits. (start=4041954780, size=2073105270, end=6115060049, disk end=3907029168)
BAD_RS LBA=1841165521 809
FAT12 1841165521 2450036354 608870834
BAD_RS LBA=3969283451 1188
FAT12 3969283451 7575788388 3606504938
This partition ends after the disk limits. (start=3969283451, size=3606504938, end=7575788388, disk end=3907029168)
BAD_RS LBA=1236345830 631
FAT32 1236345830 2533933844 1297588015
BAD_RS LBA=3445847166 694
FAT32 LBA 3445847166 6565579277 3119732112
This partition ends after the disk limits. (start=3445847166, size=3119732112, end=6565579277, disk end=3907029168)
BAD_RS LBA=2804053112 612
FAT12 2804053112 4929130939 2125077828
This partition ends after the disk limits. (start=2804053112, size=2125077828, end=4929130939, disk end=3907029168)
BAD_RS LBA=1426676622 363
FAT12 1426676622 1766633174 339956553
BAD_RS LBA=3756909262 938
FAT16 LBA 3756909262 4282237582 525328321
This partition ends after the disk limits. (start=3756909262, size=525328321, end=4282237582, disk end=3907029168)
BAD_RS LBA=239179511 421
FAT32 LBA 239179511 875533103 636353593
BAD_RS LBA=2775666865 619
FAT16 >32M 2775666865 6189190800 3413523936
This partition ends after the disk limits. (start=2775666865, size=3413523936, end=6189190800, disk end=3907029168)
BAD_RS LBA=1660848684 1140
FAT16 <32M 1660848684 2855789848 1194941165
BAD_RS LBA=518300956 576
FAT16 <32M 518300956 4110605875 3592304920
This partition ends after the disk limits. (start=518300956, size=3592304920, end=4110605875, disk end=3907029168)
BAD_RS LBA=3973654501 657
FAT16 LBA 3973654501 7602485539 3628831039
This partition ends after the disk limits. (start=3973654501, size=3628831039, end=7602485539, disk end=3907029168)
BAD_RS LBA=119246035 381
FAT16 >32M 4414213331 6108219664 1694006334
This partition ends after the disk limits. (start=4414213331, size=1694006334, end=6108219664, disk end=3907029168)
BAD_RS LBA=3726437307 282
FAT16 LBA 3726437307 6515626438 2789189132
This partition ends after the disk limits. (start=3726437307, size=2789189132, end=6515626438, disk end=3907029168)
BAD_RS LBA=2031130570 1054
HPFS - NTFS 2031130570 2845163698 814033129
BAD_RS LBA=3750608692 391
FAT16 <32M 3750608692 8038033804 4287425113
This partition ends after the disk limits. (start=3750608692, size=4287425113, end=8038033804, disk end=3907029168)
BAD_RS LBA=4114297956 365
HPFS - NTFS 4114297956 6713688823 2599390868
This partition ends after the disk limits. (start=4114297956, size=2599390868, end=6713688823, disk end=3907029168)
BAD_RS LBA=2563587216 438
FAT16 LBA 2563587216 6183056963 3619469748
This partition ends after the disk limits. (start=2563587216, size=3619469748, end=6183056963, disk end=3907029168)
BAD_RS LBA=1456751431 692
FAT16 LBA 1456751431 2908986084 1452234654
BAD_RS LBA=713860131 487
HPFS - NTFS 713860131 4895581739 4181721609
This partition ends after the disk limits. (start=713860131, size=4181721609, end=4895581739, disk end=3907029168)
BAD_RS LBA=3469017379 1274
FAT32 3469017379 4248394230 779376852
This partition ends after the disk limits. (start=3469017379, size=779376852, end=4248394230, disk end=3907029168)
BAD_RS LBA=1602569472 947
FAT16 >32M 1602569472 3608504772 2005935301
BAD_RS LBA=2539016153 430
FAT12 2539016153 6429324001 3890307849
This partition ends after the disk limits. (start=2539016153, size=3890307849, end=6429324001, disk end=3907029168)
BAD_RS LBA=269434420 220
FAT16 LBA 269434420 2768726474 2499292055
BAD_RS LBA=1523168891 317
FAT32 LBA 1523168891 3733503816 2210334926
Buffer can't store more than 200 lines.
BAD_RS LBA=1651610295 271
FAT16 >32M 1651610295 3615727470 1964117176
BAD_RS LBA=1903000142 508
FAT32 1903000142 3098851216 1195851075
BAD_RS LBA=2059632714 248
FAT32 2059632714 6110356878 4050724165
This partition ends after the disk limits. (start=2059632714, size=4050724165, end=6110356878, disk end=3907029168)
BAD_RS LBA=3758391594 175
HPFS - NTFS 3758391594 5275397854 1517006261
This partition ends after the disk limits. (start=3758391594, size=1517006261, end=5275397854, disk end=3907029168)
BAD_RS LBA=1682591690 1064
FAT32 LBA 1682591690 5799061176 4116469487
This partition ends after the disk limits. (start=1682591690, size=4116469487, end=5799061176, disk end=3907029168)
BAD_RS LBA=3888111232 4294967295
FAT12 3888111232 7761901143 3873789912
This partition ends after the disk limits. (start=3888111232, size=3873789912, end=7761901143, disk end=3907029168)
BAD_RS LBA=2204355594 952
FAT32 2204355594 4316161958 2111806365
This partition ends after the disk limits. (start=2204355594, size=2111806365, end=4316161958, disk end=3907029168)
BAD_RS LBA=2280969619 1163
HPFS - NTFS 2280969619 5540421948 3259452330
This partition ends after the disk limits. (start=2280969619, size=3259452330, end=5540421948, disk end=3907029168)
BAD_RS LBA=583184041 1140
FAT16 >32M 583184041 1064174643 480990603
BAD_RS LBA=3580073860 1025
FAT32 3580073860 4285179297 705105438
This partition ends after the disk limits. (start=3580073860, size=705105438, end=4285179297, disk end=3907029168)
BAD_RS LBA=1755214046 768
FAT12 1755214046 1859964649 104750604
BAD_RS LBA=1322000652 827
FAT16 LBA 1322000652 3105058643 1783057992
BAD_RS LBA=942999294 614
FAT16 LBA 942999294 1408009796 465010503
BAD_RS LBA=3333644173 857
FAT12 3333644173 5426594288 2092950116
This partition ends after the disk limits. (start=3333644173, size=2092950116, end=5426594288, disk end=3907029168)
BAD_RS LBA=1196715941 691
FAT16 LBA 1196715941 4922720183 3726004243
This partition ends after the disk limits. (start=1196715941, size=3726004243, end=4922720183, disk end=3907029168)
BAD_RS LBA=194585779 159
HPFS - NTFS 194585779 3668198946 3473613168
BAD_RS LBA=2774089528 86
FAT32 2774089528 4948004451 2173914924
This partition ends after the disk limits. (start=2774089528, size=2173914924, end=4948004451, disk end=3907029168)
BAD_RS LBA=1367035904 315
FAT16 <32M 1367035904 4451384256 3084348353
This partition ends after the disk limits. (start=1367035904, size=3084348353, end=4451384256, disk end=3907029168)
BAD_RS LBA=951765747 405
FAT16 <32M 951765747 3328616965 2376851219
BAD_RS LBA=2761974547 972
FAT32 LBA 2761974547 5689897988 2927923442
This partition ends after the disk limits. (start=2761974547, size=2927923442, end=5689897988, disk end=3907029168)
BAD_RS LBA=2450749029 826
HPFS - NTFS 2450749029 6182852096 3732103068
This partition ends after the disk limits. (start=2450749029, size=3732103068, end=6182852096, disk end=3907029168)
BAD_RS LBA=3606289031 998
FAT32 LBA 3606289031 5779007497 2172718467
This partition ends after the disk limits. (start=3606289031, size=2172718467, end=5779007497, disk end=3907029168)
BAD_RS LBA=144361084 189
HPFS - NTFS 4439328380 4477077125 37748746
This partition ends after the disk limits. (start=4439328380, size=37748746, end=4477077125, disk end=3907029168)
BAD_RS LBA=692556470 175
FAT16 >32M 692556470 1482879328 790322859
BAD_RS LBA=163109861 601
HPFS - NTFS 4458077157 5841004012 1382926856
This partition ends after the disk limits. (start=4458077157, size=1382926856, end=5841004012, disk end=3907029168)
BAD_RS LBA=1315639703 553
FAT16 >32M 1315639703 4982831616 3667191914
This partition ends after the disk limits. (start=1315639703, size=3667191914, end=4982831616, disk end=3907029168)
BAD_RS LBA=3860899182 878
HPFS - NTFS 3860899182 5997051972 2136152791
This partition ends after the disk limits. (start=3860899182, size=2136152791, end=5997051972, disk end=3907029168)
BAD_RS LBA=2385291273 698
FAT16 >32M 2385291273 2894327232 509035960
BAD_RS LBA=3306451224 499
FAT16 >32M 3306451224 6528716650 3222265427
This partition ends after the disk limits. (start=3306451224, size=3222265427, end=6528716650, disk end=3907029168)
BAD_RS LBA=3330581587 790
HPFS - NTFS 3330581587 4782659929 1452078343
This partition ends after the disk limits. (start=3330581587, size=1452078343, end=4782659929, disk end=3907029168)
BAD_RS LBA=610431962 275
FAT16 <32M 610431962 1944652569 1334220608
BAD_RS LBA=2408717774 580
FAT16 <32M 2408717774 3891493055 1482775282
BAD_RS LBA=3725963033 973
FAT32 3725963033 3772952823 46989791
BAD_RS LBA=4292528796 1154
FAT16 LBA 4292528796 6261263289 1968734494
This partition ends after the disk limits. (start=4292528796, size=1968734494, end=6261263289, disk end=3907029168)
BAD_RS LBA=4176931689 352
FAT12 4176931689 6886203895 2709272207
This partition ends after the disk limits. (start=4176931689, size=2709272207, end=6886203895, disk end=3907029168)
BAD_RS LBA=1451859826 889
FAT16 <32M 1451859826 2925294085 1473434260
BAD_RS LBA=91308491 579
HPFS - NTFS 4386275787 4613366794 227091008
This partition ends after the disk limits. (start=4386275787, size=227091008, end=4613366794, disk end=3907029168)
BAD_RS LBA=3358082795 783
HPFS - NTFS 3358082795 4771696436 1413613642
This partition ends after the disk limits. (start=3358082795, size=1413613642, end=4771696436, disk end=3907029168)
BAD_RS LBA=1590293199 594
FAT32 1590293199 4094705263 2504412065
This partition ends after the disk limits. (start=1590293199, size=2504412065, end=4094705263, disk end=3907029168)
BAD_RS LBA=2031903355 1020
HPFS - NTFS 2031903355 3393665145 1361761791
BAD_RS LBA=736647556 1081
FAT16 LBA 736647556 3668871341 2932223786
BAD_RS LBA=4231724565 1199
FAT16 <32M 4231724565 4623840386 392115822
This partition ends after the disk limits. (start=4231724565, size=392115822, end=4623840386, disk end=3907029168)
BAD_RS LBA=1657270939 149
FAT12 1657270939 5020745344 3363474406
This partition ends after the disk limits. (start=1657270939, size=3363474406, end=5020745344, disk end=3907029168)
BAD_RS LBA=1512974228 912
FAT12 1512974228 2018691711 505717484
BAD_RS LBA=1311745197 454
HPFS - NTFS 1311745197 1644691274 332946078
BAD_RS LBA=2579844883 391
FAT32 2579844883 4465100220 1885255338
This partition ends after the disk limits. (start=2579844883, size=1885255338, end=4465100220, disk end=3907029168)
BAD_RS LBA=1654781350 1285
FAT16 LBA 1654781350 3437361458 1782580109
BAD_RS LBA=2266264828 496
HPFS - NTFS 2266264828 4430475731 2164210904
This partition ends after the disk limits. (start=2266264828, size=2164210904, end=4430475731, disk end=3907029168)
BAD_RS LBA=29712268 277
FAT32 LBA 4324679564 4980726142 656046579
This partition ends after the disk limits. (start=4324679564, size=656046579, end=4980726142, disk end=3907029168)
BAD_RS LBA=1642988112 474
FAT16 LBA 1642988112 2541832760 898844649
BAD_RS LBA=658923819 938
FAT16 <32M 658923819 4131557282 3472633464
This partition ends after the disk limits. (start=658923819, size=3472633464, end=4131557282, disk end=3907029168)
BAD_RS LBA=146572731 670
FAT16 <32M 4441540027 8506058195 4064518169
This partition ends after the disk limits. (start=4441540027, size=4064518169, end=8506058195, disk end=3907029168)
BAD_RS LBA=3985475623 791
FAT32 3985475623 6153290675 2167815053
This partition ends after the disk limits. (start=3985475623, size=2167815053, end=6153290675, disk end=3907029168)
BAD_RS LBA=4022699744 426
FAT32 4022699744 6891077259 2868377516
This partition ends after the disk limits. (start=4022699744, size=2868377516, end=6891077259, disk end=3907029168)
BAD_RS LBA=838019713 697
FAT32 LBA 838019713 938480170 100460458
BAD_RS LBA=1564564455 803
FAT16 LBA 1564564455 2109569831 545005377
BAD_RS LBA=1382011841 1142
FAT32 LBA 1382011841 3458561975 2076550135
BAD_RS LBA=3301148382 508
FAT16 >32M 3301148382 6665841412 3364693031
This partition ends after the disk limits. (start=3301148382, size=3364693031, end=6665841412, disk end=3907029168)
BAD_RS LBA=364972708 684
FAT16 >32M 364972708 2203489594 1838516887
BAD_RS LBA=1573308044 1089
FAT16 >32M 1573308044 4911379919 3338071876
This partition ends after the disk limits. (start=1573308044, size=3338071876, end=4911379919, disk end=3907029168)
BAD_RS LBA=3547625961 430
FAT32 3547625961 4200618652 652992692
This partition ends after the disk limits. (start=3547625961, size=652992692, end=4200618652, disk end=3907029168)
BAD_RS LBA=149921370 420
FAT12 4444888666 5960852749 1515964084
This partition ends after the disk limits. (start=4444888666, size=1515964084, end=5960852749, disk end=3907029168)
BAD_RS LBA=1067895421 308
FAT16 LBA 1067895421 4798137872 3730242452
This partition ends after the disk limits. (start=1067895421, size=3730242452, end=4798137872, disk end=3907029168)
BAD_RS LBA=3014233527 1091
FAT12 3014233527 7139521916 4125288390
This partition ends after the disk limits. (start=3014233527, size=4125288390, end=7139521916, disk end=3907029168)
BAD_RS LBA=847492317 583
HPFS - NTFS 847492317 2172245232 1324752916
BAD_RS LBA=1573317228 834
FAT32 LBA 1573317228 5678066348 4104749121
This partition ends after the disk limits. (start=1573317228, size=4104749121, end=5678066348, disk end=3907029168)
BAD_RS LBA=4138431989 365
FAT32 LBA 4138431989 4615121468 476689480
This partition ends after the disk limits. (start=4138431989, size=476689480, end=4615121468, disk end=3907029168)
BAD_RS LBA=770918649 237
FAT16 <32M 770918649 2328508615 1557589967
BAD_RS LBA=1867331909 672
FAT32 1867331909 3254169044 1386837136
BAD_RS LBA=3964717062 718
FAT32 LBA 3964717062 6141969021 2177251960
This partition ends after the disk limits. (start=3964717062, size=2177251960, end=6141969021, disk end=3907029168)
BAD_RS LBA=1565980301 580
FAT12 1565980301 4904930425 3338950125
This partition ends after the disk limits. (start=1565980301, size=3338950125, end=4904930425, disk end=3907029168)
BAD_RS LBA=1223031899 1001
HPFS - NTFS 1223031899 4841583765 3618551867
This partition ends after the disk limits. (start=1223031899, size=3618551867, end=4841583765, disk end=3907029168)
BAD_RS LBA=1267751676 1105
HPFS - NTFS 1267751676 3681074400 2413322725
BAD_RS LBA=929641880 989
FAT32 929641880 1843665120 914023241
BAD_RS LBA=2422001144 1000
FAT32 LBA 2422001144 6548873091 4126871948
This partition ends after the disk limits. (start=2422001144, size=4126871948, end=6548873091, disk end=3907029168)
BAD_RS LBA=1060053943 1056
FAT16 >32M 1060053943 3288418671 2228364729
BAD_RS LBA=562719908 851
FAT32 562719908 801453324 238733417
BAD_RS LBA=3680951134 708
FAT32 3680951134 3769768839 88817706
BAD_RS LBA=518383155 857
HPFS - NTFS 518383155 3958845406 3440462252
This partition ends after the disk limits. (start=518383155, size=3440462252, end=3958845406, disk end=3907029168)
BAD_RS LBA=4230336316 710
FAT16 <32M 4230336316 8096896390 3866560075
This partition ends after the disk limits. (start=4230336316, size=3866560075, end=8096896390, disk end=3907029168)
BAD_RS LBA=2339208249 622
FAT32 2339208249 3548641559 1209433311
BAD_RS LBA=1798596128 712
FAT12 1798596128 2280450814 481854687
BAD_RS LBA=2353301691 284
FAT12 2353301691 6362674511 4009372821
This partition ends after the disk limits. (start=2353301691, size=4009372821, end=6362674511, disk end=3907029168)
BAD_RS LBA=2552435242 331
HPFS - NTFS 2552435242 2583766897 31331656
BAD_RS LBA=383648890 695
HPFS - NTFS 383648890 2394805951 2011157062
BAD_RS LBA=586749730 1010
FAT16 LBA 586749730 1716628101 1129878372
BAD_RS LBA=1991409547 1033
FAT32 LBA 1991409547 4886782111 2895372565
This partition ends after the disk limits. (start=1991409547, size=2895372565, end=4886782111, disk end=3907029168)
BAD_RS LBA=1466579587 660
FAT32 1466579587 2311936877 845357291
BAD_RS LBA=2941848112 538
FAT16 <32M 2941848112 3637634873 695786762
BAD_RS LBA=2999271795 1067
FAT12 2999271795 3050275071 51003277
BAD_RS LBA=3733864131 845
FAT12 3733864131 6799679093 3065814963
This partition ends after the disk limits. (start=3733864131, size=3065814963, end=6799679093, disk end=3907029168)
BAD_RS LBA=3937485430 587
FAT12 3937485430 7221372556 3283887127
This partition ends after the disk limits. (start=3937485430, size=3283887127, end=7221372556, disk end=3907029168)
BAD_RS LBA=1060169110 802
HPFS - NTFS 1060169110 4791705900 3731536791
This partition ends after the disk limits. (start=1060169110, size=3731536791, end=4791705900, disk end=3907029168)
BAD_RS LBA=662421139 528
FAT32 662421139 735878892 73457754
BAD_RS LBA=3359790451 889
FAT32 LBA 3359790451 5027300770 1667510320
This partition ends after the disk limits. (start=3359790451, size=1667510320, end=5027300770, disk end=3907029168)
BAD_RS LBA=1654895421 603
FAT12 1654895421 5198804002 3543908582
This partition ends after the disk limits. (start=1654895421, size=3543908582, end=5198804002, disk end=3907029168)
BAD_RS LBA=368260653 446
FAT12 368260653 1447573819 1079313167
BAD_RS LBA=3575244690 965
FAT16 LBA 3575244690 5280085484 1704840795
This partition ends after the disk limits. (start=3575244690, size=1704840795, end=5280085484, disk end=3907029168)
BAD_RS LBA=1539077360 824
FAT16 LBA 1539077360 1811959087 272881728
BAD_RS LBA=2543329820 262
FAT32 2543329820 3403086878 859757059
BAD_RS LBA=3145477588 282
FAT32 LBA 3145477588 4490752367 1345274780
This partition ends after the disk limits. (start=3145477588, size=1345274780, end=4490752367, disk end=3907029168)
BAD_RS LBA=556340768 811
FAT12 556340768 2980960174 2424619407
BAD_RS LBA=3804539264 681
HPFS - NTFS 3804539264 5262920515 1458381252
This partition ends after the disk limits. (start=3804539264, size=1458381252, end=5262920515, disk end=3907029168)
BAD_RS LBA=2125858674 954
FAT12 2125858674 5347084921 3221226248
This partition ends after the disk limits. (start=2125858674, size=3221226248, end=5347084921, disk end=3907029168)
BAD_RS LBA=1360233146 752
HPFS - NTFS 1360233146 4758198325 3397965180
This partition ends after the disk limits. (start=1360233146, size=3397965180, end=4758198325, disk end=3907029168)
BAD_RS LBA=1745720777 52
FAT16 <32M 1745720777 3349356762 1603635986
BAD_RS LBA=400539000 167
FAT12 400539000 1678081882 1277542883
BAD_RS LBA=984508027 1092
FAT16 <32M 984508027 4669590131 3685082105
This partition ends after the disk limits. (start=984508027, size=3685082105, end=4669590131, disk end=3907029168)
BAD_RS LBA=2520741047 345
FAT16 <32M 1609248887 4963050282 3353801396
This partition ends after the disk limits. (start=1609248887, size=3353801396, end=4963050282, disk end=3907029168)
BAD_RS LBA=380353564 761
FAT12 380353564 586244034 205890471
BAD_RS LBA=458058239 138
FAT32 LBA 458058239 873702341 415644103
BAD_RS LBA=2148557980 851
FAT16 >32M 2148557980 3357903323 1209345344
BAD_RS LBA=2499777021 702
FAT12 2499777021 6711380077 4211603057
This partition ends after the disk limits. (start=2499777021, size=4211603057, end=6711380077, disk end=3907029168)
BAD_RS LBA=3218327329 122
FAT16 >32M 3218327329 5253179640 2034852312
This partition ends after the disk limits. (start=3218327329, size=2034852312, end=5253179640, disk end=3907029168)
BAD_RS LBA=4022903116 872
FAT32 LBA 4022903116 5619629673 1596726558
This partition ends after the disk limits. (start=4022903116, size=1596726558, end=5619629673, disk end=3907029168)
BAD_RS LBA=3461807565 1195
FAT16 >32M 3461807565 7557873238 4096065674
This partition ends after the disk limits. (start=3461807565, size=4096065674, end=7557873238, disk end=3907029168)
BAD_RS LBA=3130188331 108
FAT12 3130188331 4315619465 1185431135
This partition ends after the disk limits. (start=3130188331, size=1185431135, end=4315619465, disk end=3907029168)
BAD_RS LBA=4161912873 1159
FAT32 4161912873 4170305418 8392546
This partition ends after the disk limits. (start=4161912873, size=8392546, end=4170305418, disk end=3907029168)
BAD_RS LBA=2984782433 376
FAT32 LBA 2984782433 5473915642 2489133210
This partition ends after the disk limits. (start=2984782433, size=2489133210, end=5473915642, disk end=3907029168)
BAD_RS LBA=1054454841 439
FAT16 LBA 1054454841 4982757446 3928302606
This partition ends after the disk limits. (start=1054454841, size=3928302606, end=4982757446, disk end=3907029168)
BAD_RS LBA=596345554 345
FAT32 596345554 4788129322 4191783769
This partition ends after the disk limits. (start=596345554, size=4191783769, end=4788129322, disk end=3907029168)
BAD_RS LBA=198176402 699
FAT32 3075036192 4634004850 1558968659
This partition ends after the disk limits. (start=3075036192, size=1558968659, end=4634004850, disk end=3907029168)
The harddisk (2000 GB / 1863 GiB) seems too small! (< 14904093 TB / 13555194 TiB)
BeFS 413258843 29109558410597466 29109557997338624 [ˆ)ý­¿M@—P›¹æÙé뿐c֞›~F:#D6]
BeFS blocksize=32, 14904093 TB / 13555194 TiB
FAT16 >32M 466498047 4509251967 4042753921
FAT32 LBA 1293146100 5086451351 3793305252
FAT12 2097092284 4462322037 2365229754
FAT32 2159203408 5277518349 3118314942
FAT16 >32M 2240998857 5944166680 3703167824
FAT12 2310224945 6323614694 4013389750
FAT16 LBA 2520741047 5006249366 2485508320
HPFS - NTFS 2875200117 4674860498 1799660382
FAT32 LBA 2928266274 4983678151 2055411878
FAT16 LBA 2939389758 7176687668 4237297911
FAT32 2968547753 4002005969 1033458217
FAT32 3278507199 7065253085 3786745887
FAT12 3475335161 4986156081 1510820921
HPFS - NTFS 3476316162 6429081389 2952765228
FAT16 <32M 3539069085 6801865395 3262796311
FAT16 LBA 3647001423 7668913651 4021912229
FAT32 LBA 3717161815 6755772056 3038610242
FAT16 <32M 3776748630 4748544786 971796157
FAT16 >32M 3835466572 4247104154 411637583
FAT16 >32M 4062451832 5199775267 1137323436
FAT32 4172601352 7299818842 3127217491
FAT16 <32M 4183807079 8265255405 4081448327
FAT32 LBA 4236607463 8411381703 4174774241
FAT12 4275289727 5540407596 1265117870
FAT32 LBA 4325442396 7623627649 3298185254
FAT12 4380438580 7393267207 3012828628
HPFS - NTFS 4417199181 7801701461 3384502281
FAT16 <32M 4483595703 6791736189 2308140487
FAT12 4486063180 6589609371 2103546192
FAT32 4493143698 5577738609 1084594912
FAT16 <32M 4522775426 7772049036 3249273611
get_geometry_from_list_part_aux head=1 nbr=198
get_geometry_from_list_part_aux head=8 nbr=30
get_geometry_from_list_part_aux head=16 nbr=16
get_geometry_from_list_part_aux head=32 nbr=9
get_geometry_from_list_part_aux head=64 nbr=7
get_geometry_from_list_part_aux head=128 nbr=4
FAT16 LBA 381509682 2937779710 2556270029
FAT32 LBA 464511879 2048688881 1584177003
HPFS - NTFS 484245759 3282436702 2798190944
FAT32 608782983 1608776699 999993717
FAT32 674559459 2316318391 1641758933
FAT32 LBA 692623348 1770759044 1078135697
FAT16 LBA 850697186 3681275608 2830578423
FAT12 1247924929 2022726325 774801397
FAT32 1362290739 2176288901 813998163
FAT12 1514274906 2877578347 1363303442
FAT12 1516724565 1704795054 188070490
FAT12 2041873003 3843403774 1801530772
FAT16 <32M 2571242540 3871643235 1300400696
FAT16 <32M 2839841018 3254953751 415112734
FAT16 <32M 3454209879 3684293000 230083122
Re: RAID 1 disk recovery
There is currently an exFAT partition using the whole disk. This partition is mounted on your Mac OS X.
It looks like it's an empty exFAT. If this disk has been reformated, you can use PhotoRec to recover the data.
Be careful to not store the recovered files on this disk. You need enough space to store the data.
paded
#3 Post by paded »
I do not remember any formatting action on this disk. I'm trying to recover data with PhotoRec, but it takes so much time(ETR 152h) and the names of the files is like ... different :/
I'm wandering ... is there any chance to recover the file system structure... ?
BrianG
#4 Post by BrianG »
paded wrote: 24 Jul 2018, 09:05 2 TB disk, coming from UNITEK NAS Y 3357 cofigured as RAID 1
Compiler: GCC 4.0
I am getting the exact errors and and ETA of 540 hours. What can I do? please in need of serious help. I have so much of data.
Shane.
