Recovery after potential crime
tomz
#1 Post by tomz »
Greetings Testdisk-Community,
A friend of mine came to me yesterday evening with one of two backup-hdds of a stolen NAS-System.
The guy who (they think) did this, also deleted the backup files on (at least) this backup storage.
As a first action, I mounted the drive into an ubuntu 18.04 VM read only and tried a quick search with no results.
The deep search is still running, but I don't quiet understand the output.
What did he do with the drive? Is it just deleted or really "safely" overwritten?
This HDD should be ext4 as formated by the Synology system's app "Hyper Backup".
Is there anything else I can do before we hand this over to officials, or a very costly data recovery company?
Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63
Analyse cylinder 84896/243196: 34%
  MS Data                      256 3906959799 3906959544 [1.42.6-23739]
  MS Data                      254 3906959797 3906959544 [1.42.6-23739]
Re: Recovery after potential crime
You should really avoid to modify anything if this disk will be use in an investigation.
Try to list the files from the 2 listed partitions and if needed, you can copy some files.
