PhotoRec on Mac - no hard disk found
antpicc
#1 Post by antpicc »
Hi! I'm trying to rune Photorec on my MacOS High Sierra partition. However, each time I run PhotoRec it says "no harddisk found". Any suggestion about how to fix it?
Re: PhotoRec on Mac - no hard disk found
Can you choose "sudo" in the menu ?
antpicc
#3 Post by antpicc »
Thanks for your answer. Would you please mind explaining me better how should I use the Sudo command? I tried to give Sudo in the Terminal, and then write the path corresponding to the PhotoRec executable, but it gives me the same answer (see attachments).
Schermata 2018-08-07 alle 10.39.11.png (37.3 KiB) Viewed 6522 times
Schermata 2018-08-07 alle 10.38.59.png (30.21 KiB) Viewed 6522 times
antpicc
#4 Post by antpicc »
So, PhotoRec does not run on High Sierra? :\
