<t>Hello!<br/>
I would like to recovery my EXT4 1TB partition. Working on Windows 10, forgot it is EXT4 partition. Entered computer managment ->storage and switched the disk from offline to online. Windows asks should it create GPT or MBR partition table (something like https://www.partitionwizard.com/images/ ... rive-2.png). Chose GPT and then windows created 17MB partition and remaining space marked as raw data. Below some infomration from test disk.</t>
<quote>
Tue Aug 7 00:26:11 2018
OS: Linux, kernel 4.15.0-20-generic (#21-Ubuntu SMP Tue Apr 24 06:16:15 UTC 2018) x86_64
Compiler: GCC 7.2
ext2fs lib: 1.44.1, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco 1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-21M2NA0, S/N:WCC3FC37H2E3, FW:01.01A01
Disk /dev/sda - 1000 GB / 931 GiB - WDC WD10EZEX-21M2NA0
Partition table type: None
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
P ext4 0 0 1 121601 80 63 1953525168 [DANE]
block_group_nr 1
recover_EXT2: part_offset problem
block_group_nr 1
recover_EXT2: s_block_group_nr=1/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244190646
recover_EXT2: part_size 1953525168
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 1000 GB / 931 GiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1953525168 linear /dev/sda 0" | dmsetup create test0
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571387.
Write isn't available because the partition table type "None" has been selected.
block_group_nr 1
block_group_nr 1
block_group_nr 3
block_group_nr 3
recover_EXT2: s_block_group_nr=3/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
</quote>
and so on...
Recover deleted 1TB EXT4 partition and created 17MB MS GPT partition
Re: Recover deleted 1TB EXT4 partition and created 17MB MS GPT partition
Your disk was not partitioned. Run "fsck.ext4 /dev/sda".
