Made a stupid mistake while adding a second storage pool to my server. Was testing different options and after a reboot went to delete the new pool to change it and accidentally deleted my old data filled storage space.
This is on a windows 10 machine. Mirror storage space with 6 drives, I believe column number was 3. I am hoping all the data will still be there but nothing being recognized now by the server. Using EaseUS it finds some files but seems to find a lot of extra stuff as well. Before paying and recovering each individual file, is there a way to use Testdisk to recover the whole storage space setup/partition?
Thanks
Screenshot
Windows 10 Storage Space
hooraysimpsons
- drive.png (19.68 KiB) Viewed 2811 times
Re: Windows 10 Storage Space
Try TestDisk, Advanced, select the second partition, force the type to MS DATA and NTFS, Boot, List.
Does it work ?
Does it work ?
hooraysimpsons
Thank you for your response. Should I do this for all of the drives at once?
Edit:
Changed type to MS DATA and hen NTFS. Hit boot and got below screenshot.
Edit:
- tested change type and boot.png (17.31 KiB) Viewed 2806 times
