I attempted to recover a SSD used to shoot video, was able to recover priceless videos in the past using photorec, thanks a lot for that!! But this one I got seems unrecoverable and I wanted to makes sure that is the case since nothing of interest showed up on this one (a few xml and plist that's it).
The SSD was empty when I got it, they forgot to backup before formatting the card.
Anyway, I thought I would backup the SSD image using testdisk and give the SSD back and when I inspected the image.dd (120GB) into a hex editor I saw that it was pretty much at 99.9% filled with 1s (0xFFFF). Is that common for formatting software to fill the disk with 1s? I guess whoever used that card last didn't do a quick format and actually went full on erase everything and it filled the whole disk with 1s.
Could that be the case or did I used the wrong option in testdisk to save the image?
The card is a Sony XQD which seems to be using exFAT as the filesystem.
I think I know the answer is probably going to be, yes nothing is recoverable, but I would've expected 0s and not 1s, so just want to makes sure.
Question about SSD formatting filled with 1s
Re: Question about SSD formatting filled with 1s
When the SSD has been formatted, a trim operation has probably been issued. It informs a solid-state drive (SSD) which blocks of data are no longer considered in use and can be wiped internally.
Unfortunately no data can be recovered after that by software. To be more accurate, some data recovery company can open the SSD and bypass the flash controller to access old data and recover lost files. It's usually destructive for the SSD and an expensive service.
