Android SD card with RAW filesystem
Supergrover
#1 Post by Supergrover »
all of a sudden my android smartphone wasn't able to access it's sd card anymore. Windows shows two partitions with RAW filesystem.
I tried to analyze it with TestDisk. Both quick check and deep check gave me only cryptic file names when listing files.
Has anybody any idea on how to restore the data/filesystem?
As I was not able to attach a file, please see an excerpt from the testdisk.log file as follow:
Fri Aug 17 07:46:41 2018
TestDisk 7.1-WIP, Data Recovery Utility, June 2018
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=24015495168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=24015495168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=497924468224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=24013438976
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=16777216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=63846727168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=2147483648
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RBNXBH221637R, FW:EMT02B6Q
Disk /dev/sdb - 24 GB / 22 GiB - CHS 2919 255 63, sector size=512 - LITEONIT LSS-24L6G, S/N:S0C41176Z1ZSDW009729, FW:DSR2206
Disk /dev/sdc - 63 GB / 59 GiB - CHS 7764 255 63, sector size=512 - Realtek PCIE Card Reader, FW:1.00
Drive R: - 2147 MB / 2048 MiB - CHS 520 128 63, sector size=512
Disk /dev/sdc - 63 GB / 59 GiB - Realtek PCIE Card Reader
Partition table type: EFI GPT
Analyse Disk /dev/sdc - 63 GB / 59 GiB - CHS 7764 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=124735487 (expected 124735487)
hdr_lba_start=34
hdr_lba_end=124735454
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
19a710a2 b3ca 11e4 b0 26 10 60 4b 88 9d cf
193d1ea4 b3ca 11e4 b0 75 10 60 4b 88 9d cf
 1 P Unknown                     2048      34815      32768 [android_meta]
 2 P Unknown                    34816  124735454  124700639 [android_expand]
     MS Data                    32768  124735487  124702720
     exFAT, blocksize=131072, 63 GB / 59 GiB
file_pread(6,8,buffer,124735488(7764/108/25)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(6,1,buffer,124735488(7764/108/25)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(6,1,buffer,124735489(7764/108/26)) lseek err Invalid argument
file_pread(6,14,buffer,124735490(7764/108/27)) lseek err Invalid argument
file_pread(6,3,buffer,124735504(7764/108/41)) lseek err Invalid argument
file_pread(6,3,buffer,124735551(7764/109/25)) lseek err Invalid argument
file_pread(6,8,buffer,124735567(7764/109/41)) lseek err Invalid argument
file_pread(6,11,buffer,124735614(7764/110/25)) lseek err Invalid argument
file_pread(6,2,buffer,124737536(7764/140/57)) lseek err Invalid argument
   P MS Data                    32768  124735487  124702720
 1 P MS Data                    32768  124735487  124702720
dir_partition inode=0
exfat_ucstoutf8: iconv failed Invalid or incomplete multibyte or wide character
exfat_ucstoutf8: iconv failed Invalid argument
X      0 -r-xr-xr-x     0      0         0  1-Jan-2008 03:00
X      0 dr-xr-xr-x     0      0         0 24-Mar-1980 18:05
X2885858863 -rwxr-xr-x     0      0 6315356158193801877 14-Sep-1964 18:28 ‹ÆŽ*³G[µ‹Òû-
 1081037129 drwxr-xr-x     0      0 17363287985672168158 20-Jan-2010 09:03 赏⃥⳱ࣻ䥄띋楤慪ꌚ觨괶膓罍湝
X3491947174 drwxr-xr-x     0      0 1186564655739126117 27-Jun-2027 15:00
       0 dr-xr-xr-x     0      0         0 19-Nov-2013 14:24 ⭹刿৙뿲䆦쏴瞚ൺ룓풚魗܆쏘ཱྀ翺娶傱♞䄆癱ꗮҥ狎蔛ަ쮄똉풿
X1676174517 dr-xr-xr-x     0      0 16934511672186613762  3-Sep-1982 15:52 8™– £"t6­ð蓛﷧響㜝ʆ뫃磊됏䑻푡ጶ鱠꒫׶쇊ꉷ缚ੳ笾衮뼑헧㿥⩲霳✀숈먌ゝ咓횩혠她㺛⫥迃ぶ⢍偒㨼亏䪔
X      0 drwxr-xr-x     0      0         0 24-Mar-1942 14:32
       0 dr-xr-xr-x     0      0         0 15-Aug-1950 17:11
 854159992 -rwxr-xr-x     0      0 5390548495458458046 31-Dec-2032 06:03
X3527078784 drwxr-xr-x     0      0 10670260817202024059 18-Oct-2030 09:34 㣙렩쳢꟮阳浞⮝⺈閊ꏑ㒹鉖攉
 1007221402 -r-xr-xr-x     0      0 5128943306894372754 22-Feb-1907 21:16
       0 drwxr-xr-x     0      0         0  9-Mar-1991 06:24
X      0 drwxr-xr-x     0      0         0  7-Jun-1911 18:24
       0 dr-xr-xr-x     0      0         0 25-Dec-2034 06:40 軀失ﱊ蔅鷑隿쁺短᠛冤䃮騻ꢿ懟
       0 dr-xr-xr-x     0      0         0  5-Nov-1985 10:03
X      0 -r-xr-xr-x     0      0         0 26-Feb-2026 21:49 "Ž4$m¸z$ÈKЩ
X988941421 -r-xr-xr-x     0      0 14050987116119915159 13-Dec-1966 23:36 薩楕봗껐ᶳ瞙魥ì阶늓鐫樼魪펴
 380434498 dr-xr-xr-x     0      0 18308998556583386998  1-Jul-1916 10:06 蘹凄촌뢻㞠ɻ䈈㫭Ὥ琩垎鏡
X      0 dr-xr-xr-x     0      0         0  5-Feb-1971 16:52 둣衙ṥ즴쿗뱉ꐸ㶫ʌ␁駫鸘엷
X      0 -rwxr-xr-x     0      0         0 25-May-1969 07:54
X      0 -r-xr-xr-x     0      0         0  6-May-1911 20:02
       0 -rwxr-xr-x     0      0         0 23-Jan-2005 20:09 „ð<Eÿ6Ù{á¡h#1
X1772502842 -rwxr-xr-x     0      0 6955504437899645850  6-Dec-1911 10:09 皆䫮ᙦ⸵峰盧್末횭❆뗧鎭⛠䯳틼
X      0 drwxr-xr-x     0      0         0 18-Dec-1931 02:55
       0 -rwxr-xr-x     0      0         0  3-Dec-1957 10:48
 4095536251 drwxr-xr-x     0      0 15003451441645573761 16-Jan-2000 10:51 ᱃걷Ჰ盟駴飴뉡㮄煜嗃ⓗ釆섘
       0 -r-xr-xr-x     0      0         0 27-Aug-1924 20:20 ➿궳釰掏ⲃẎ㘗沅碾塸؆툔繹ÓQk!pI4s3
؅ᇴǽ⏅눩㻘૳䙎䴭鍣ᶻ페ₛ虊텧
X      0 -rwxr-xr-x     0      0         0 25-May-1955 21:04
X      0 drwxr-xr-x     0      0         0  5-Dec-1946 08:45 ð|·âkeù̼_L¼²
       0 -rwxr-xr-x     0      0         0 17-Jul-1941 23:00
X      0 drwxr-xr-x     0      0         0 23-Aug-2033 16:55
 1348144635 dr-xr-xr-x     0      0 16566273150026545438 20-Dec-1953 00:18 㧊躔갆如ࢡⵉ䞋鸍Ǖᮦ즞膻蓲vü¸cº–NŽ^ý1`‹Òó!˜n—Ð¥—`ꗕ雎冊湣月훅엇ᵪ꫓ᶛ뒉哳蔒河ҙ
       0 -r-xr-xr-x     0      0         0  3-Sep-1908 06:33
       0 -r-xr-xr-x     0      0         0 24-Jan-2022 11:00
X3948329359 -r-xr-xr-x     0      0 1339124064639516913 21-Nov-1922 20:08
X330534093 drwxr-xr-x     0      0 6829018517197357852 27-Mar-1920 18:17 힃篅谟믮莙⧀垨꿤芟㇧᎕ꔳ㉙ʶ윏ࡉꬕἢ䘃姍쟺﷛踇䣧⠌
X      0 -r-xr-xr-x     0      0         0  8-Apr-2017 21:11 S^qL&Zö+Jžª#
       0 drwxr-xr-x     0      0         0 25-Apr-2029 14:01
X      0 -rwxr-xr-x     0      0         0  2-Jan-2003 10:10
 2017388644 drwxr-xr-x     0      0 5537066656929761034 30-Nov-1948 20:19 )*û}2qïTö
MÖ¾œ
       0 dr-xr-xr-x     0      0         0  8-Feb-1905 00:46
X948130197 dr-xr-xr-x     0      0 4893032088398742437  4-Mar-1971 12:52
 1084378980 dr-xr-xr-x     0      0 10034701057231244393 15-Dec-1948 01:59 疒渦郈︇혳ﬠ꒱◇ᰳ㢣๓艊㫙窣낲᪖낻黉㽗책푡✰ꏆ㓦묺㙶㢂ðT»¹¡9_HÓœ±o\@ášÛ§¢iâémŽŸ]šT
X1564384229 -r-xr-xr-x     0      0 6202664099541128107 29-Jun-1925 22:39
       0 drwxr-xr-x     0      0         0 26-Oct-2012 01:37
X      0 -rwxr-xr-x     0      0         0  7-Dec-1959 00:13
       0 drwxr-xr-x     0      0         0 18-Oct-1931 02:23
 1186366766 -r-xr-xr-x     0      0 8312883793153037732 24-Dec-1962 18:29 韐岺䐑ࢱ繦槬缟ꃊ稕퐡ﱀꪘ뷀
X      0 -r-xr-xr-x     0      0         0 12-Jun-1952 01:37 ¨t~>.ïžê쩕ᐾ啞훃㩌阰왚ᯁ쐵紸譑介〮
 310542340 -rwxr-xr-x     0      0 347428987590823540  1-Jan-1930 02:31
X      0 dr-xr-xr-x     0      0         0 27-Jun-1971 21:50
X      0 -r-xr-xr-x     0      0         0 28-May-2035 00:13 షՕ퟾げ铗湓䭬쥼멳慲桯컯鞣ካ
X      0 dr-xr-xr-x     0      0         0  9-Apr-2024 08:20
X1200460682 -r-xr-xr-x     0      0 1293271094863238310 24-Nov-2005 04:27
 749856907 dr-xr-xr-x     0      0 784606016130947140 20-Dec-1922 17:04 黣쿘䈲닙ᙊ鮂䕑ﵷട愊烩掫닓Қ㊙쁀湝惨賃篯ꇶ鵾᯷_簰쳺닒従骀긡쏞᤼כּ叠理왇ㆃᴋ謣띬즗쥇
 3646920729 -r-xr-xr-x     0      0 7250437289992434056  4-Jan-1999 04:24
X      0 -r-xr-xr-x     0      0         0 21-Oct-1963 18:38 Ø=ûíú{ÚÂýÞ–óI-\
X      0 dr-xr-xr-x     0      0         0 19-Feb-1964 21:47
 3323964896 -r-xr-xr-x     0      0 17283504985226771703 31-Jan-2014 15:58 㖛疥襽꼭⺄걑ḻ첷鄆籯刴萀坈帜忢ꍁ䘜廚땪냾屇ꡄ¿롤童봶褤
 353404211 -r-xr-xr-x     0      0 11063421337547631343 15-Mar-2020 03:00 ꓯ炴ധ鮌⏸鋔֕뿳ྭ聶㖝叛㼄볬
X4094985609 -r-xr-xr-x     0      0 10458096974694849073 18-Feb-2010 01:54 ⪓䀨셄通ಀ욓ﮨ鷬⫙᣼쥷츜캧奋
X3819811050 drwxr-xr-x     0      0 3213253423428563729  8-Sep-1998 23:41
X      0 -rwxr-xr-x     0      0         0  8-Feb-1992 06:12
X      0 drwxr-xr-x     0      0         0  7-Nov-1985 17:02
X      0 -r-xr-xr-x     0      0         0  4-Dec-1902 17:07
X      0 drwxr-xr-x     0      0         0 28-Jul-2024 11:26
       0 -rwxr-xr-x     0      0         0 31-May-1963 11:41 ᜤꏡյ奃匈틫얯崽뼜尣譎ピ娓ᱚ
X2394669957 -r-xr-xr-x     0      0 1114141968641843670 26-Feb-2033 11:07 ꒊ擋棏牐珹裵隟省쌺礘䕌뼌rJ‰!Þq¿ÃØB%¹8ßh
X3392420196 -rwxr-xr-x     0      0 16164413531332414907 26-Sep-1903 04:51
       0 -r-xr-xr-x     0      0         0 18-Jan-2034 06:39
X      0 drwxr-xr-x     0      0         0 28-Jun-1942 04:04
       0 -r-xr-xr-x     0      0         0 19-Jan-2011 03:52
 2242830541 -rwxr-xr-x     0      0 13134871998105694302 27-Jan-1999 02:09
X345945862 -rwxr-xr-x     0      0 9111662501965420507 22-Nov-1931 03:43
X      0 -rwxr-xr-x     0      0         0 23-Dec-1959 23:29
 177100446 -rwxr-xr-x     0      0 492245226116962543 26-Jan-2015 08:39
X      0 -rwxr-xr-x     0      0         0 21-May-1939 18:26
 486860440 drwxr-xr-x     0      0 9274137487478759461 28-Jan-2025 04:46
X3265123816 -rwxr-xr-x     0      0 13470639375445560845 20-Mar-1911 12:05 뱝ŵヒⅭ幹ꆸ㥟ී썗逐桛豆溂螘ꅀﴄ룁䬅ꯏ쒗ꐛꀔ㯵楀좉⒂煽ᄁ꟒麅᷉緲蹰ﭸ쓍燯Ꚃᨕ康嵶뵨游䟖쐅둇䒔안稘ꀙ朌ኅ詟
X      0 -r-xr-xr-x     0      0         0  7-Mar-2011 19:35
       0 -rwxr-xr-x     0      0         0 30-Mar-2035 15:25 ü»"ø0­\Ñ<Û‘ºŒýÐÙE‰Æ$›{
       0 drwxr-xr-x     0      0         0  1-Sep-2015 07:12
X2303907999 dr-xr-xr-x     0      0 14340089516694938746 25-Nov-1945 12:22 –‹½®ÿ#n_;E&➐僿ો䩪ꡧ顢ﭗ⵰ቜ낮჋叉븼٦ߜæ4Ë©«êIfÏ9}:ÃÊôOÃèÇñð
X      0 -r-xr-xr-x     0      0         0 27-Jan-1946 20:01 /Dc­Íâ„k³á¥T Ðè
 1782443616 -rwxr-xr-x     0      0 3943838732983836039 30-Jan-2013 18:24
       0 -rwxr-xr-x     0      0         0 10-Oct-1903 10:53
 1266217754 -rwxr-xr-x     0      0 7938944408954078931  1-Jan-1985 15:15
X      0 -r-xr-xr-x     0      0         0 23-Dec-1946 14:38
       0 -r-xr-xr-x     0      0         0 17-Dec-1913 14:44
       0 -r-xr-xr-x     0      0         0  5-May-1958 00:00 墠쇂䀅㇔ನ楽᛾곸錠ᑺ刲쭝垞
X      0 -rwxr-xr-x     0      0         0 17-Dec-1910 07:36
       0 -rwxr-xr-x     0      0         0 18-Jan-1994 01:12
X1440327584 drwxr-xr-x     0      0 9779782518599472246  9-Oct-1997 21:03 ꬑ鎼綊⋙蓌志롶핶䰊狥㧃
X120467614 -r-xr-xr-x     0      0 10793809136922934539 19-Mar-1999 12:09 ѸM"øÊQq×Ò@К‘
 1049572922 -r-xr-xr-x     0      0 14674151814350645818 24-Dec-1948 20:57 鍊苍欿ᨯܔ걠詶髬줠跸灳NР㜵
 2322772395 drwxr-xr-x     0      0 12905166614103642878  4-Jul-2036 01:22 Ĭ~i}Z‰.8I=ËÚÀ˜ÆÀEzѬ
„hs{N¬á¶Šá»¹ï»ˆæ—í™»ã—⾯黧䣷荳恂䧆旚ӊ鐍
X      0 -r-xr-xr-x     0      0         0 21-Jan-2017 19:22
       0 -r-xr-xr-x     0      0         0  6-Jan-2019 04:23
X      0 -rwxr-xr-x     0      0         0 11-Nov-1917 22:10
X      0 -rwxr-xr-x     0      0         0 24-Dec-1989 02:51
       0 dr-xr-xr-x     0      0         0 27-May-1938 22:31
X716567935 -rwxr-xr-x     0      0 3088258774430873838 14-Jan-1995 09:36
X1490965645 -r-xr-xr-x     0      0 12508111549974421276 16-Jan-2002 10:15 湮⸳뷆⧜㫽ᜆ楤吊촔竪鲉ḑ뙹耑ˆXo‚l·uÿ;­¸½p¾
       0 drwxr-xr-x     0      0         0 11-Jan-2021 17:07 앤옦덯쵈賈䮽兠䉀押喱芄뀹둥
X3886726565 -rwxr-xr-x     0      0 2483954129433598183 28-May-1987 22:50 ꐰ禥醜⍛ཿ認Έ廀䣧펚厹뻚茒葨
X      0 drwxr-xr-x     0      0         0 19-Jan-1991 20:55
       0 dr-xr-xr-x     0      0         0 18-Dec-1917 09:47
X      0 -r-xr-xr-x     0      0         0 31-Dec-1997 17:06
       0 drwxr-xr-x     0      0         0  8-Sep-1970 17:23
X      0 drwxr-xr-x     0      0         0  3-Mar-1913 21:43
X2853092755 dr-xr-xr-x     0      0 14821874956656093965 14-Jan-2007 09:28 Ꜧ⮖栦뵬ὺⶐ跈曊ा엁ꪭ뭟ラ
X      0 -r-xr-xr-x     0      0         0 20-Nov-1964 00:22 铌Ⱏ攇覾재熭పﮘ瞐洟ᆙ䢸
       0 -rwxr-xr-x     0      0         0  3-Aug-1913 21:29
X2316458468 -rwxr-xr-x     0      0 14068810535036117510  3-Dec-2024 12:11 7–Ãì$*
|ò«
       0 drwxr-xr-x     0      0         0 30-Nov-1939 18:31
 2242041548 dr-xr-xr-x     0      0 16715795534189767231 26-Nov-1981 16:29
X2500338311 drwxr-xr-x     0      0 17455581599098757499 14-Mar-1904 21:42 £3$øÿa]}hP%§
       0 -r-xr-xr-x     0      0         0 30-Aug-1965 06:38
X2696493297 drwxr-xr-x     0      0 3565637274894347025 15-Jun-1971 20:24
X3100967217 -r-xr-xr-x     0      0 14392314427792885014 20-Dec-1928 05:18
       0 -rwxr-xr-x     0      0         0 13-May-1981 00:07
       0 drwxr-xr-x     0      0         0 26-Oct-1963 05:36
       0 -rwxr-xr-x     0      0         0 16-Feb-2016 23:10
X      0 dr-xr-xr-x     0      0         0 13-Apr-2006 00:19 ᢈ抑垖ꢿ墖鸚ℤ萡㧮제靛랦ᜡ뭷nei0¢ÞŽí¶àl¡‡§ç«ºã· î­½é˜‘㦋삐ੂ敱蹕䯢ꩱẘ煫蟨筿䳠覃煉ѡ읰등ᡞ틱賲䀹劻á~H܉_uf2ê
X      0 dr-xr-xr-x     0      0         0  7-Dec-1927 13:17
X4184917824 drwxr-xr-x     0      0 3064490799917033172 24-Sep-1934 18:01
X2685479566 dr-xr-xr-x     0      0 2430742465102578662 10-Dec-1948 22:26 ⋇筝鱻෡腱ܝ酐봏コ돕鱔耥娲쥊㶸
 2643623909 -r-xr-xr-x     0      0 15204280539530268125 24-Feb-2025 23:34 藰ꔲ(Ṿ븐涴쨨덪龓簲螲羡桪䇬叨哒䳟ᑗ赁纖狥吩庯ﴉമ㧯➒݁
       0 dr-xr-xr-x     0      0         0 20-Oct-2034 04:58
       0 -r-xr-xr-x     0      0         0 31-Mar-1990 04:09
X      0 -rwxr-xr-x     0      0         0  9-May-1906 00:35
 133560293 -r-xr-xr-x     0      0 1262469252722488509  6-Jul-1948 06:56
X      0 drwxr-xr-x     0      0         0  3-Sep-1915 13:35
 2554670346 dr-xr-xr-x     0      0 14570485490720924749 11-Dec-1913 20:20
 2479209369 -rwxr-xr-x     0      0 15661722284758416608 17-Jan-2038 18:49
 3393119411 dr-xr-xr-x     0      0 6152638819594194290  3-Aug-1961 06:00
       0 drwxr-xr-x     0      0         0 18-May-1931 18:06
X      0 drwxr-xr-x     0      0         0 30-Nov-1944 17:02
 1953179032 -rwxr-xr-x     0      0 2666707444500584008 30-Jan-2013 02:15
       0 drwxr-xr-x     0      0         0  5-Apr-1942 03:06
       0 -rwxr-xr-x     0      0         0 30-Nov-1931 18:31
X      0 drwxr-xr-x     0      0         0 25-Jan-1996 22:13
X      0 drwxr-xr-x     0      0         0  4-Jul-2028 22:21
X      0 dr-xr-xr-x     0      0         0  5-Aug-2025 07:47
       0 -rwxr-xr-x     0      0         0 29-Jul-1923 21:34
       0 -r-xr-xr-x     0      0         0 19-Jan-2026 04:50
X      0 -r-xr-xr-x     0      0         0 10-Jul-1961 23:32
       0 -r-xr-xr-x     0      0         0 21-Dec-1946 07:43
X      0 -rwxr-xr-x     0      0         0 17-Jun-1948 08:29
       0 drwxr-xr-x     0      0         0  1-May-2026 14:33
X      0 drwxr-xr-x     0      0         0  2-Apr-1922 23:23
X2374520413 dr-xr-xr-x     0      0 6417407589186188358  5-Sep-1997 00:11
X1009364009 drwxr-xr-x     0      0 4797439952732889661 29-Jan-1906 09:06
       0 dr-xr-xr-x     0      0         0 13-Jan-1966 14:36 퐊詞肂﹊샍갞赕౥둋҄ﳄᐝ뛗揵箇
X      0 drwxr-xr-x     0      0         0  3-Jul-1909 23:32
X      0 -r-xr-xr-x     0      0         0  1-Nov-1937 10:55
       0 dr-xr-xr-x     0      0         0  4-Jan-1996 07:01 洒俎倹茹㔙쫦滤ﻛ벌뵴쯑ٯ曻쭸
X      0 -rwxr-xr-x     0      0         0 25-Sep-1929 20:57
       0 -rwxr-xr-x     0      0         0  2-Jan-1934 06:45 [Tõ™DÇñϰž/T㊀妺艪⠵飣㩒렆ΰ敚鏦毗Ĭ韤읿侞섲ᡪ垠楎雧댃턧໽
       0 -r-xr-xr-x     0      0         0 13-Feb-1956 01:56
X1870500048 -r-xr-xr-x     0      0 7309314061985788139  9-Feb-1965 21:08
X3199791473 -rwxr-xr-x     0      0 16099887233736188013 26-May-1970 20:35 쇱뼘⳾⹙渲尬༂緣㼳塥᨜ᇾ굠
       0 -rwxr-xr-x     0      0         0 16-Jul-1985 04:04
 3878697935 dr-xr-xr-x     0      0 10377822341381216990  6-Dec-2003 23:50 “¡"²âó¢m$Ü,ƒêª¢è½¥èž¸ì¾¨ç®ˆâ’½æ½©ê´¢ã™ªáŒ®ê»¦ã±ë ¼ä¬‘㯚
       0 drwxr-xr-x     0      0         0  1-Jan-2000 00:24
       0 -rwxr-xr-x     0      0         0 27-Jul-1955 01:14
X301561625 -rwxr-xr-x     0      0 9951366089459238324 24-Mar-1908 23:34
       0 -r-xr-xr-x     0      0         0 29-Jan-1960 04:35 ᐝ侮櫽꾺懂癃܍꫞텚法༣嘖㨿
       0 dr-xr-xr-x     0      0         0 28-Sep-1946 17:30
 469156501 -rwxr-xr-x     0      0 4230697214567360440  3-Dec-1950 12:24 Û1•Y0ìÏ¥ý òÅÝ
 3516945665 -rwxr-xr-x     0      0 17459553705500607084 12-May-1966 10:49 䘄緵낡霨뾊΀ᙊ쑄붿哞⹣㬌兦栗
 1390564727 -rwxr-xr-x     0      0 6164052677192268525 28-Jun-1995 16:21
X1326362987 dr-xr-xr-x     0      0 1831249241622298312 14-Jan-2017 03:26 ·ˆ¾	(ÁÝ©¸/íF
X      0 -r-xr-xr-x     0      0         0 22-Jan-1992 18:48
 1405629067 drwxr-xr-x     0      0 12443752060039701046  1-Feb-2002 04:30
X      0 -r-xr-xr-x     0      0         0 29-Dec-2005 23:02 簸㹮姧㠌㮴鈴졵냩玧邌䏞匩꼧鰂喝
       0 -r-xr-xr-x     0      0         0  8-Jan-2038 06:24
       0 -rwxr-xr-x     0      0         0 10-Feb-1956 01:20 ڮ翚㓲䟥ᬘԪ눳欋楘鐫ꀍ㸬䟝໘
X      0 dr-xr-xr-x     0      0         0 17-Dec-1969 15:14 ೺ᨎ胉꧞⥒ꗩࠔ릊상숆ꮡ桊욵엻
X2543349677 drwxr-xr-x     0      0 12840725596291156394 21-Jul-1982 11:13 䇿ᩦ秼챃呎㬄汼й뒶璷侾⪳褹ో
X      0 -rwxr-xr-x     0      0         0 15-Nov-1919 09:35
       0 dr-xr-xr-x     0      0         0 11-Jul-1990 04:09 ­Sš+ïÉðý`ðÌÅ:²3估硛⁹씏ᩎ␅瑱囚掌禧ឍꙌ㘯췝y]Ô><n
Ùó×ފ秐䖞豧ᓃൡ葇ꢹ缷ᘴ脆䑨繒栙㛺漂
       0 -rwxr-xr-x     0      0         0  7-Dec-2036 18:21
X      0 -r-xr-xr-x     0      0         0  2-Dec-1965 10:43
 1768626983 dr-xr-xr-x     0      0 15285635268400958756 21-Dec-1903 12:23
       0 -r-xr-xr-x     0      0         0 26-Jan-1999 18:37
X948083675 -rwxr-xr-x     0      0 17656836309953943280  6-Jul-1949 00:22 RmB‡U“PÁ²À¼›ÉÙ
X      0 drwxr-xr-x     0      0         0 22-Sep-1942 08:34
çwš$€#+66<V@
X4180684451 drwxr-xr-x     0      0 7472922050311750257 31-Aug-1932 11:40 첳Ƛꮻ晻᳎볁迴褃먉蹚饯듕찀䀩
       0 dr-xr-xr-x     0      0         0 17-Jan-1986 21:45
X3633714738 drwxr-xr-x     0      0 180626957065119579 27-Feb-1961 08:13 ”Ì;œY ¦ÈIªƒkƒÐîî®;tióچ喱譈嵎ޅ㫈尰䱮沾꟣甞碘䐗
 3158205852 drwxr-xr-x     0      0 9191533871089906240 25-Mar-1965 07:40 輑굁ȯ獭䳨隞꺯컅珛펟췭ᄄ稿
       0 -rwxr-xr-x     0      0         0  8-Dec-1919 14:07
       0 dr-xr-xr-x     0      0         0 10-Sep-2001 02:53 ãÙSÍ®‡™Næ#tP.
       0 drwxr-xr-x     0      0         0  5-Dec-1997 08:05
X      0 -r-xr-xr-x     0      0         0  4-Jan-2011 00:00 龍ꒁ铞썲崜灁眭좊蹔軓揥뉜婙
       0 drwxr-xr-x     0      0         0 14-Aug-1925 18:12
       0 dr-xr-xr-x     0      0         0 24-Jul-2002 18:24 楔쐀쁴확૑ꥸ옑䭵嵛躭⼒炙
 2402554389 -r-xr-xr-x     0      0 9260665702705302507 29-Jan-2014 18:28
 224151148 dr-xr-xr-x     0      0 2694753171132290203 21-Sep-2001 17:36 l$|8É4ÛϳªÍ)‘¼ê¯žî‘—윖렢ᅰ䖯뻟멹蔣⪙ᆝ௾
 2356396036 dr-xr-xr-x     0      0 6352021915013973517 11-Nov-2018 02:59
X      0 -r-xr-xr-x     0      0         0  9-Jan-2013 13:17
X2357581172 dr-xr-xr-x     0      0 2243210681709298194 30-Sep-1940 06:33 ူﭳ鮋긬蠟酎冟髐뷙㫠㯱ಙဓ厛驷젊㾝௾獶ꎉ퓈⓲掂蔽࿽挖籘㩅ᴡ켫唨뵓栩栭昩寧䭡
 1849978271 dr-xr-xr-x     0      0 10963301289795789817 10-Jan-2037 12:34 튆㔓แݍⳀ笪硒Ⲡ曳㕲ꕄᯌ鵅입
 3249569589 -r-xr-xr-x     0      0 3572207917613007662  9-Jun-1908 19:32 7A<áÿ¸ÒD)¨¥ÙiY5Œ;y
¥k¶l2Ÿýˆp
X      0 -r-xr-xr-x     0      0         0 19-Mar-1951 10:44 [ÔÅj&î‡ZX
X      0 drwxr-xr-x     0      0         0  7-Oct-1906 08:35 Ⓐ㒗쳋匛镻ﱦ쟂銑Ǖ㕫辥蚚㝞㼾볎썭팥됍懵缒銚ӊ汞ૉ6⦉劂aã
       0 dr-xr-xr-x     0      0         0 22-Dec-1939 20:27
       0 drwxr-xr-x     0      0         0 27-Feb-1903 02:33
X      0 drwxr-xr-x     0      0         0 16-Aug-1925 16:42
X      0 dr-xr-xr-x     0      0         0  8-Apr-1982 01:35
X2332836147 -r-xr-xr-x     0      0 1232181072342265185 20-Aug-1970 00:47 ྏ荫샥ꭠ胿閅䜶졳淥䬬侍ꆧᅮ㟭鏫鿂츉ꚾ拲ͦៅⰞӚ紅
 564897387 -r-xr-xr-x     0      0 759648556829064195  6-Jan-1981 02:00 ~>®÷¤çØí•ÎâMÛå’
       0 -r-xr-xr-x     0      0         0 25-Mar-1936 21:32 ᭙ᬲꯙ濆惤鑑㨗䪭敖ܹ뽗ୀ∻亼
 280399286 -rwxr-xr-x     0      0 1718826967447616155 29-Aug-1966 22:38 ꔂ裰쀂솴﹔鹂쪍⪖ᒏ彚ᙃ焵䊅㑦஌
 877255133 drwxr-xr-x     0      0 12073690233613421437 24-Oct-2013 02:21 쇩븖‶傸ꤖ圓豍訫ꐉ췚及뻥ꈟ圻摧⧿﮺퀮튽თ푋ཉ膪멒Խ⦛ꞗ寔竇
X      0 -rwxr-xr-x     0      0         0 14-Feb-1917 20:46 JûH®L5ë¿D‘Üm\
X2439723038 dr-xr-xr-x     0      0 3845374840167921188 24-Jan-2008 13:13  ¯ío-sCšðüÅA
X      0 dr-xr-xr-x     0      0         0  6-Apr-1906 23:23
 691297264 drwxr-xr-x     0      0 4138963991428467977 11-Feb-1921 07:17 i_È„0Æ¡™vžÌ{ýO
X      0 dr-xr-xr-x     0      0         0 12-Jan-2033 00:19 E
X      0 dr-xr-xr-x     0      0         0  6-Dec-1925 10:55
X      0 -rwxr-xr-x     0      0         0 26-Sep-1993 00:09
       0 dr-xr-xr-x     0      0         0  8-Oct-2011 15:51
 841106826 drwxr-xr-x     0      0 12719009189688626125 11-Jan-1902 14:07 #^C´¶ÃÁ?©½ÁöœãÙ
       0 drwxr-xr-x     0      0         0 12-Oct-1936 17:32
X3743945057 dr-xr-xr-x     0      0 16726341297426649872 24-Nov-1921 18:18 簸ꂔﴚ絊郘䥈ⱜ᰷ꊎʾ딿㽤煪䒋
X      0 drwxr-xr-x     0      0         0 14-Feb-1985 17:24 썳ﺇ壷力틦᪰띫雔Ⱶ䌬踞聧뗞붧놳⢛갪샔뽜䌃뵮귺ⳋ⩖쑶ᐽ㪬穻
       0 -rwxr-xr-x     0      0         0  3-Apr-1909 18:25 ⩭谁ዉ引喁쳓닛앏㙣찼⛆㰟촴ᾘ⟨ᤠ렘쬑쐿⮣耱䛣僮똱㽥熐쭖⻆ꪊ銏׋齗厥훺﹵偿⒖밗枖ື꺽絊ᮨ
 2356487297 -rwxr-xr-x     0      0 50603166375955153 15-Dec-1910 21:09 ᡹矜᭿ᩭ␶Ή啵ꑬ墰搪ꅁ梧戯
       0 drwxr-xr-x     0      0         0  1-Dec-1958 23:54 ∹푽रǕ륰췱ᗸ癔藍룓墆䶪逿蟕楊ꄍ엘䯏ቷꉅ旝饪굩ꯒ糭
       0 -rwxr-xr-x     0      0         0 23-Jun-2031 16:28
X      0 -r-xr-xr-x     0      0         0 15-Jul-1983 13:10 ⍲䡣䟅ᇤٹ츳䉓䛭暷蠔ᅍ醵
X      0 dr-xr-xr-x     0      0         0 25-Mar-2021 03:32
       0 -r-xr-xr-x     0      0         0 14-Dec-1914 01:41
X      0 -r-xr-xr-x     0      0         0 22-Dec-1902 00:23
X      0 dr-xr-xr-x     0      0         0 27-Jun-1946 12:20 暔룰Æ漇囜鬘螺筫២备频䕡鈢
       0 -r-xr-xr-x     0      0         0 17-Jan-1998 07:06
 2436339385 dr-xr-xr-x     0      0 10391183477027271482 26-Mar-1927 10:09
X      0 -rwxr-xr-x     0      0         0  4-Dec-1956 05:55
X      0 -rwxr-xr-x     0      0         0 27-Jan-2012 20:03
 3756103505 dr-xr-xr-x     0      0 13479249349425695677 28-May-2033 16:07 ‹Ùë·óõœúÕƒ*Qb¢æ‚”骡뇰⋧꾕Ѫ埅
ჟ妾霬똾ꠤ吮ﲄϾ妅꣢ὶ㠇墅䄰ρᰫ
 1992204762 dr-xr-xr-x     0      0 4771868871368620101  2-Dec-1937 09:51 x~1æJIK޶
X      0 -rwxr-xr-x     0      0         0  9-Mar-1989 22:21 ×åc[5pP´a–ú}Þ¹
X2004641894 -rwxr-xr-x     0      0 11236254163869962309 31-Aug-1958 13:36 榒ⶍ爺蛁쫴༵컢ﲔ퀳끠瀽欜ﶿ恀‹®Ã2´ò(¦ãY8ÓÔÄ
 3633833638 drwxr-xr-x     0      0 17586729951838338168 23-Jan-1966 22:10 yù(ü##מ‡¡–%"ò
X3703243396 -r-xr-xr-x     0      0 13610594003981376650 14-Dec-1963 02:21
       0 drwxr-xr-x     0      0         0 26-Mar-1920 09:36
X      0 -rwxr-xr-x     0      0         0 26-May-1902 14:35 ꑑⲀ ̄鬹瘁и⡊ય샶찁Ἦ㎨
X118665393 -rwxr-xr-x     0      0 9018911969268486371 30-Aug-2028 01:12
X      0 drwxr-xr-x     0      0         0  6-Feb-2025 07:21
       0 -r-xr-xr-x     0      0         0  5-Aug-1997 08:55
X2556045489 drwxr-xr-x     0      0 4579690532135734827 26-Dec-1922 04:46
X      0 drwxr-xr-x     0      0         0  6-Aug-1981 08:58
X3549080381 -rwxr-xr-x     0      0 6103199381581871237 12-Jan-2026 10:01 xnÏÜÞiFðÅ~³­©
       0 -r-xr-xr-x     0      0         0 16-Dec-1913 00:24
       0 -rwxr-xr-x     0      0         0 28-Jul-1950 14:52
       0 -rwxr-xr-x     0      0         0 21-Oct-2001 03:57
X      0 -rwxr-xr-x     0      0         0  5-May-1968 01:47 Ü@ž.¼}	Dü:
X      0 drwxr-xr-x     0      0         0 22-Jan-1911 18:42
       0 -rwxr-xr-x     0      0         0 15-Oct-1946 22:13
       0 -rwxr-xr-x     0      0         0 29-Jan-1909 00:30 칑㮥帝縱䞠峳瓸ኧ㨯乾쯣率鹕䡿
X      0 dr-xr-xr-x     0      0         0 25-Nov-1997 23:06 ˆ„MèZ¢Æš¿4æJ”Ê
 376379199 drwxr-xr-x     0      0 3469744051248110008 18-Mar-1914 22:58
X      0 -r-xr-xr-x     0      0         0 27-Dec-2025 03:49
       0 drwxr-xr-x     0      0         0  3-Dec-1918 04:08
 3536552980 dr-xr-xr-x     0      0 2572000851286273564 14-Dec-1904 18:48 愅킨ꆉﬖ윅ꖥ芠輓ᓕ懔毶⅍㛳鮬
X1903436617 drwxr-xr-x     0      0 11072897454056751071 27-Nov-1941 01:52
X      0 drwxr-xr-x     0      0         0 18-Oct-2019 07:06 JÀ(æ<Ù‡TK üÄÈ庀ᝋ萾俟⊉驍䥬懾䵹᤽◊䘪哼쐕
X      0 dr-xr-xr-x     0      0         0  3-Oct-2033 16:00
       0 -r-xr-xr-x     0      0         0 21-Jun-1907 23:53 ὢ与螅榚泡盶뤚ꬼ≆鐮쿭䘴䛁孄㱜ᴇ䃅ᔵ뫉ૠ屈ᦫ復꩑嵹ꥱ聪㡩
X      0 -rwxr-xr-x     0      0         0  4-Dec-1955 22:27
X1301432383 dr-xr-xr-x     0      0 13024530034498633329 23-May-1944 17:44
X      0 -r-xr-xr-x     0      0         0 30-Jan-1928 09:13 ñ©bõ¼Ò¡¯hõeãÙ
v)'j­Hù7qÿbZ
X      0 -r-xr-xr-x     0      0         0 21-Feb-1923 11:50 e±“ÛÍ…ÿÞò¿pb€"á
X      0 dr-xr-xr-x     0      0         0 25-Apr-1943 20:23
       0 dr-xr-xr-x     0      0         0 27-Jan-2002 03:01
       0 dr-xr-xr-x     0      0         0  9-Jun-2026 05:15
       0 dr-xr-xr-x     0      0         0 29-Oct-1997 14:52
       0 drwxr-xr-x     0      0         0 27-Nov-1955 05:31 ꅟ誔맙띆礡晛覐콇ꡕ⽪厑륟땐듴㥤
X      0 -r-xr-xr-x     0      0         0 31-Jan-1907 11:41 n-^)8òùŠ¡Ú­xÌðl
X      0 -rwxr-xr-x     0      0         0 18-Nov-1949 21:33
       0 dr-xr-xr-x     0      0         0  5-May-1931 06:32
X28854150 drwxr-xr-x     0      0 578149741345171362 25-Mar-1982 04:47 ª¶­m¯‹,òP9I†Þ
X1016206826 -r-xr-xr-x     0      0 11867650623266602545  7-Dec-1967 14:54
X      0 dr-xr-xr-x     0      0         0 27-Aug-1924 20:33
X607729563 -rwxr-xr-x     0      0 16233108888360052570 25-Mar-1962 03:02
X      0 -rwxr-xr-x     0      0         0  8-Feb-2035 09:36 ힺ놎쑅辍孬枰蟸ₛ咐綒ᆐ킽ᕮ础
X      0 dr-xr-xr-x     0      0         0  1-Oct-1906 22:13
X3114696981 -rwxr-xr-x     0      0 12375267592230536240 17-May-1998 19:46 틶鰭኶㪆䴷쥽♼羹ꕎଛ埞਋꿁읠뀎輨뙕婑ἅ䍈蚎兊㢱데Ҷ঵ꐣ沝䉍膪ᄇᾋຜ힕톺燖戆臯䂴
       0 drwxr-xr-x     0      0         0 12-May-1980 05:35
X      0 -r-xr-xr-x     0      0         0  8-Jan-2036 13:00
X      0 -r-xr-xr-x     0      0         0  1-Oct-1924 18:01
 29840802 -rwxr-xr-x     0      0 15175716970545710762  4-Oct-1912 17:58 鎇⛲ķ䗋䗛ᵊ䘂⻩顅秐嶂툭
X      0 -rwxr-xr-x     0      0         0 16-May-2032 22:35
X2365926802 dr-xr-xr-x     0      0 13629664213683228910 26-Oct-1987 14:05 ᖎﺩ╠チ炞颸ੈ뉢䜫㼊婤ꑟ墩޿茸쌠ꏿ젱﫳鼌刜鸝꺄ፍ꼢虒祲
 576238006 drwxr-xr-x     0      0 17132755396743088111 18-Dec-1948 01:31 笤쇞爎㠼ﴱ槓ᘘ┟裫ꡐ䴐澉Û7.—º<ÒºÅHcX²ê’µâ“‰æ©µè³å³àª±ë¥¯æ²Žê„’ꁔⰞ圆뻔ണ瑉
X      0 drwxr-xr-x     0      0         0 13-Jan-2025 15:49
 3058898692 -rwxr-xr-x     0      0 11610612748312567551  3-Feb-1906 17:39
 1724805671 drwxr-xr-x     0      0 15463025576688494636 18-Jan-2027 06:20
 245520118 -rwxr-xr-x     0      0 12540108112238157035  3-Apr-1957 10:38
X3664040850 drwxr-xr-x     0      0 3604226662805533713 17-Apr-1987 15:57 름ⓦ弝㶲聣䯅琉饨☇얒슨ﯠ䕡
       0 -rwxr-xr-x     0      0         0 24-Oct-1988 11:51
X263515030 dr-xr-xr-x     0      0 3096871587670681090 25-Nov-1902 03:46 ㎡䘬㧚݁瑕᪄㜵鏅촟旡伯苃䒜䠐퉇ᑆ筼︠Ҟ䒜—䎙깺숑
       0 dr-xr-xr-x     0      0         0 17-May-1919 04:42 ‚“Ö֏³úL·Ð@'
X      0 -r-xr-xr-x     0      0         0 11-Apr-1963 04:36
X      0 -rwxr-xr-x     0      0         0 31-Jan-2028 20:53
       0 drwxr-xr-x     0      0         0  1-Aug-1931 02:25
X      0 -r-xr-xr-x     0      0         0  6-Jan-2002 19:20
       0 -rwxr-xr-x     0      0         0 14-Oct-1954 09:14
 978256092 -rwxr-xr-x     0      0 4011131105717779444 15-Jan-2023 01:14 Ë3Ø¢Ÿé™Êkãðæ×¤å¤¶ê¦ŠÖƒà«°â•»êª¥å“ꈩᡫﵚ嵝销焾
X      0 drwxr-xr-x     0      0         0 27-Aug-1957 02:54
X1547572095 drwxr-xr-x     0      0 4187520670823767861 24-Dec-1915 05:19 ⍟ߞ뼙ᘧ䢳뇊싡秃Ꮃ়⃣诬䝪蒆
       0 -rwxr-xr-x     0      0         0 15-Feb-1960 23:58 áŒèjâè#ß´eÚ
       0 drwxr-xr-x     0      0         0  8-May-1909 20:21
       0 -r-xr-xr-x     0      0         0  8-Jul-1951 09:32
       0 -rwxr-xr-x     0      0         0  7-Dec-1912 00:11
       0 -r-xr-xr-x     0      0         0 16-Sep-1936 19:54
 2995944073 drwxr-xr-x     0      0 6599450190175702715 15-Dec-1964 09:05
X4236209330 dr-xr-xr-x     0      0 6678651288737684185  8-Jun-1983 07:36 荋匝ꯧ熮冒蔌鞄߶떕Փ翏Ï⵲⚙
X2538931058 -r-xr-xr-x     0      0 13761744575549142143  7-Jan-1988 21:14
X1885582467 dr-xr-xr-x     0      0 15684866271597227414 30-Mar-2010 06:39 ønÔ;ThnLcï†ý—Þ‡›Åóø}ºWožÄ?G
X1456084467 -r-xr-xr-x     0      0 129995095075326624  1-Jan-1961 03:56
 2447214754 -rwxr-xr-x     0      0 15359676283274825687  5-Mar-1995 00:57 쭪ꜽ抴恼嫃ଡ଼혮ﵑ灮餑ꀓ洒愥‰枝툀쨘넧ꣀᒐﭼ杜瑃햹ᓌḮ岋
X      0 dr-xr-xr-x     0      0         0 30-Sep-2001 12:31 阭័䍳⵹乎㑢㸀能첬쒘疹릇·쯸
 3213636767 dr-xr-xr-x     0      0 129688819979537539 15-Dec-1928 07:53
X      0 -r-xr-xr-x     0      0         0 12-Apr-1989 04:47
       0 drwxr-xr-x     0      0         0 22-Jan-1930 22:24
X      0 -rwxr-xr-x     0      0         0 14-Feb-2005 02:36
       0 -rwxr-xr-x     0      0         0 22-Jan-1937 23:03
X2406632237 drwxr-xr-x     0      0 9368498268677365822 15-Jun-1917 21:57
       0 drwxr-xr-x     0      0         0 29-Jan-2011 04:50
X      0 dr-xr-xr-x     0      0         0 10-Aug-1926 23:48
X      0 -rwxr-xr-x     0      0         0  9-Oct-2006 23:37
       0 -r-xr-xr-x     0      0         0 19-Sep-2003 16:22 è–´ì²²é¸²çŒ‹Ã ã­»Â¦ëƒºæ´±ä¶ªê°­ï›¡á¾–ì¨ºá˜¯ÞØÂÙ‚ 2o> ¼!ä&{
       0 -rwxr-xr-x     0      0         0 11-Dec-1924 02:12 얐妕躦뛌澪챉温볘垄꺡깑쀼
X      0 drwxr-xr-x     0      0         0 16-Aug-1948 14:27 üèjÁ2xÊJG‡Sê{ž
 1822935861 dr-xr-xr-x     0      0 11610969385870720056 31-Jul-1989 18:55
       0 drwxr-xr-x     0      0         0 19-Feb-1932 11:23
 2782085034 -r-xr-xr-x     0      0 15806026109924063144 26-Dec-1964 01:35 ᅱ⫵⯭쩟嗕ᦇ᏾驫㎀瞧㉂ꄊ䏗
 2594274498 dr-xr-xr-x     0      0 12351177841058486349  7-Aug-1959 13:40 Øâ»lË»{ÿ ôb6ÒÕۼݷ—Czü±J¯N
X3493262610 -rwxr-xr-x     0      0 16771022373153512631 20-Jun-1916 23:15 AQfß<\9“×98¤ë¢²è©Šå‚°â‹áµ¸ä·¥î’ç”Œå§¢ì–±ê¶»èªµéžžê‰›ê‚’
       0 -rwxr-xr-x     0      0         0  5-Feb-1935 02:22
       0 -r-xr-xr-x     0      0         0 26-Apr-1980 17:30 ›°T7B²¢Aœ¼`H>
       0 -r-xr-xr-x     0      0         0 23-Jan-1991 05:16
X      0 -r-xr-xr-x     0      0         0 20-Oct-1984 21:56 䵣傳෌봌Ȃ斋좊횷瘇ﮦỸ෵
       0 -rwxr-xr-x     0      0         0 22-Mar-2005 01:15
X      0 -r-xr-xr-x     0      0         0 21-Dec-1921 19:18
       0 -rwxr-xr-x     0      0         0 20-Jun-1911 05:49 æô»qâ­–—âDÓôÚ­
       0 -r-xr-xr-x     0      0         0 28-Apr-1995 01:33
X1815571317 dr-xr-xr-x     0      0 1644300359955910560 31-Dec-2000 03:54 퍰⽝9푰ꠄᘎ䁙뛩ꔼ쐲貆
       0 -r-xr-xr-x     0      0         0 20-Apr-1969 09:34
X2963327331 dr-xr-xr-x     0      0 11480215553687289192 31-Aug-1963 01:11 ᭅ읮⧏᷄맰䗬膷ษℳ왯뾃喯㚉敍∾
 1224649631 dr-xr-xr-x     0      0 13053378973070943801 29-Oct-2012 09:16 䆀牕쐥冠蔉蔞쮇糐細녚ﶾ瘵℡
 1940441961 -r-xr-xr-x     0      0 8022199896744620632 28-Oct-1921 08:47
X      0 drwxr-xr-x     0      0         0 11-Dec-1912 00:40
X      0 -r-xr-xr-x     0      0         0 10-Jan-2018 02:39
X      0 dr-xr-xr-x     0      0         0 19-Dec-1901 21:08
X      0 -r-xr-xr-x     0      0         0 28-Jun-2027 21:38
X2924916385 drwxr-xr-x     0      0 11179382319076609469  2-Dec-1951 19:39
X      0 drwxr-xr-x     0      0         0 27-Dec-1963 06:12
X      0 drwxr-xr-x     0      0         0  7-May-2037 23:39
X365980269 -rwxr-xr-x     0      0 3228169262284296267 20-Mar-1940 19:01
 1327033533 -rwxr-xr-x     0      0 16964300871457829585 11-Jan-1924 19:15 ᯄ믑鼵≻༘䕟ᕘ痀✳朼餠뫼光
 2458956181 -r-xr-xr-x     0      0 3937593784711048608 16-Sep-2002 09:23
       0 dr-xr-xr-x     0      0         0 14-Dec-1922 10:00
 3237662460 -rwxr-xr-x     0      0 14999846418797736092 13-Mar-2014 22:09 ⋕븺┚骜ࠣ鲦嶚ꏝ珲즴鿺⨹㋱蕪굅䔕部쇉킼갥给⡜췄둠⁅獚竊嶸㪕䇩⷟ᄶ됴飑嫒๯婫佂淥鿩
X      0 dr-xr-xr-x     0      0         0 30-Mar-1946 17:47
       0 drwxr-xr-x     0      0         0 22-Feb-1981 00:22
       0 dr-xr-xr-x     0      0         0 23-Jan-2033 13:17 歰럇돋땅恽빉䷽흖ꂥ઀絺㳩菷¤ Ó¬4f®õöǑ靈荎᳠情熟Ꞇ鋤ꔢ끤㑍肻甶
X      0 dr-xr-xr-x     0      0         0 14-Oct-1949 02:36 嗣椆젂᩼깣끢鍧걸趟꯼ឤ鋩巰唤ੋ˪↜黤륥㧟睦岍挿臚ₕ澸瘤
X      0 drwxr-xr-x     0      0         0 23-Jun-1919 03:38
 1585265790 dr-xr-xr-x     0      0 14012894835872744856  2-Dec-1944 21:33
X1108454273 dr-xr-xr-x     0      0 6729917315469005482 29-Nov-1947 23:33 yíÊ8ՁÅò}R„け낡馠ꯗଘ䦊㐷砥밒喝鷢岌铅辡幤楠ಖ솳ࣕ䠠腌鬰瓞㩇틆죦鈦
       0 drwxr-xr-x     0      0         0 24-Jan-2004 04:48
       0 -rwxr-xr-x     0      0         0  7-Feb-2008 08:31
X      0 -rwxr-xr-x     0      0         0  6-Nov-1903 08:33 犥䏁춠唄렴洔惂뱅ﺃ覹㵋軷ﴀ﷘
       0 -rwxr-xr-x     0      0         0  5-Jul-1928 00:00 䄮淝ᵛ쫞뼰䙑郳쬩㡔䴆၅伮愽
X347698937 -rwxr-xr-x     0      0 9348632747924468308 28-Apr-2011 01:36 ï·aDÀ =°kÝ2Ø™jÖ
 3269100507 dr-xr-xr-x     0      0 14366833784623370493  2-Jun-1994 10:11
       0 -rwxr-xr-x     0      0         0 20-Dec-2003 09:29
       0 -rwxr-xr-x     0      0         0  4-Jul-2035 03:16 uï]A'º1nÓµjÒëÄ
 401325575 dr-xr-xr-x     0      0 3597269716888955925  7-Dec-1945 08:12 ⚊鉉塩읙䍛㸌峷내꤈驛✅຋
 2531953117 -rwxr-xr-x     0      0 232644387990827133 11-Nov-1951 20:50 묁ᴙ᩼櫄긹ቯ䖳䣗잀廸덳ⷃ㘵閸倸ﰝ㓗봖᭗㈒ɧ䉖蕪䥃Ⱝ癭
X      0 -r-xr-xr-x     0      0         0 13-Jan-1987 06:44
X623206982 -rwxr-xr-x     0      0 15587422478314440420 28-Sep-2009 18:00 䩕ᮾ䯭泰櫚扽⟌䑔쿃᫓䤐裀⩌傑ἆ
       0 dr-xr-xr-x     0      0         0  6-Nov-1938 15:01 ”‚uôÏá
}Á3r4HÇßÔÈLü{Ö¾FæCWè
X      0 -r-xr-xr-x     0      0         0 26-Jan-1918 08:51
X      0 -r-xr-xr-x     0      0         0 22-Dec-1931 17:30
       0 -rwxr-xr-x     0      0         0  4-Jul-1969 06:01
X      0 -rwxr-xr-x     0      0         0 18-Jun-1921 06:17 ‘—âÍ`ÝQ{C£*w[
X      0 -r-xr-xr-x     0      0         0 31-Mar-2019 09:36 ꬃ绻℞㔙ꐛ榧嬠䕽痱樂⼤坞峴캃
       0 -rwxr-xr-x     0      0         0  1-Jan-1982 08:47
X      0 dr-xr-xr-x     0      0         0 13-Feb-1943 22:46
X2557417688 -r-xr-xr-x     0      0 13754822405403973787 25-Mar-1923 15:21
X3869635237 dr-xr-xr-x     0      0 7782274536360820908  4-Jan-2026 23:01 ÐÙaÈn[²­§êòœ•
X      0 -r-xr-xr-x     0      0         0 17-Jan-2013 06:04
X      0 -r-xr-xr-x     0      0         0 19-May-2007 06:16
       0 -r-xr-xr-x     0      0         0  3-Oct-1969 17:52
       0 -r-xr-xr-x     0      0         0  1-Dec-2000 11:03
X      0 dr-xr-xr-x     0      0         0 25-Jun-1925 09:53 •H¤»×¦t|‹êFþª+沌珗ๅꑾ㙻秢啔璹קּ涵챥抇뒆úY¼6Îð®ÆõËOÚÃ
 2775726671 drwxr-xr-x     0      0 1803673039314772073 14-Feb-2025 01:33 àVí“PšF߿
X      0 dr-xr-xr-x     0      0         0 16-Jun-2006 04:59
X      0 drwxr-xr-x     0      0         0  5-Sep-1938 14:52
 2987778337 dr-xr-xr-x     0      0 14523432551551325220 23-Aug-2000 04:54
       0 drwxr-xr-x     0      0         0 22-Apr-1928 11:07
X      0 -rwxr-xr-x     0      0         0 17-Dec-2013 02:18
X1839818961 dr-xr-xr-x     0      0 2058326232540978115  7-Feb-1915 22:08 ô_UuØ$F ³Y4Q
X1237565484 drwxr-xr-x     0      0 13503698926314114198 10-Nov-2028 17:21 fŒ¦#FmA'nm Ÿ­
       0 drwxr-xr-x     0      0         0 11-Jan-1986 00:12
X      0 -rwxr-xr-x     0      0         0 21-Dec-1926 22:44
X      0 dr-xr-xr-x     0      0         0  8-Dec-2035 01:07
 64750790 -r-xr-xr-x     0      0 1883556786138597471 20-Jul-2025 06:55
       0 -r-xr-xr-x     0      0         0  5-Dec-1938 21:15
 3797638295 dr-xr-xr-x     0      0 8677152828378407813 23-Feb-1969 07:26 5Èß¡@·­9•Ø"
       0 -rwxr-xr-x     0      0         0  4-May-1950 15:30 °×5><˜–Oa¼7>è¿
X      0 -rwxr-xr-x     0      0         0 21-Dec-1911 06:56
 545949917 drwxr-xr-x     0      0 9804420890645983212 23-Sep-1946 03:35
       0 -r-xr-xr-x     0      0         0  9-Jan-1961 21:22 诮ⶰ뺩⠙ꁒ潍ו秝쩪欤쾡ࡤ㌳댈ꚬ竊鉜↸뻍覭ᅩņﱒ퓅袋䍥褿
X      0 -rwxr-xr-x     0      0         0 28-Sep-2006 03:12 츺諻柟쪵귋ᐁ缅狃洰웂
X      0 dr-xr-xr-x     0      0         0  2-Jun-2032 21:17
X      0 drwxr-xr-x     0      0         0 15-Jan-2034 23:17
 2372142344 -rwxr-xr-x     0      0 9535632114912633710 16-May-2015 22:56 㓺器啑뮢稻륢㨈❁⺭ᜌ譻楨굤⽥௃᮶⺣糭끉璗吔ᶽ藈᫥滉锐㻹錎䞭
       0 -rwxr-xr-x     0      0         0 27-Jul-1961 18:40
X      0 drwxr-xr-x     0      0         0 18-Dec-1919 15:34
       0 -rwxr-xr-x     0      0         0  2-Jan-1932 13:31
X2894553205 -rwxr-xr-x     0      0 1557322149536644916 30-Apr-1990 23:31
X      0 dr-xr-xr-x     0      0         0 13-Jul-1940 13:28
 4079378247 dr-xr-xr-x     0      0 8461005511710149319 26-Aug-1969 02:05 㪳ೖ䷼ò텧廉ǫ욈ꡡ୳残ઘۺ쎦䗍퉿嵒卭멎痀淖傁䏘麮疬娵ⶂ탞쮝
       0 dr-xr-xr-x     0      0         0  1-Jan-2032 23:18 ¿’?/Í&_Ú¾§
uK—xkØµ¨~åM~ò
X      0 drwxr-xr-x     0      0         0 24-Dec-1965 21:33 ᷈ㅖ耇韅ႅᬼ橠曪鰧៎唒끎
 3167264308 dr-xr-xr-x     0      0 7469977262703051710 12-Apr-2030 19:28
       0 dr-xr-xr-x     0      0         0  6-Oct-2032 05:50
 2413170405 drwxr-xr-x     0      0 11389889156171629388 21-Jan-2031 02:55 øî+K{jBÜ,Ê.m`=
X      0 -rwxr-xr-x     0      0         0 19-Aug-2016 01:26
X      0 dr-xr-xr-x     0      0         0 17-Jun-1903 10:47
X      0 dr-xr-xr-x     0      0         0  6-Dec-1907 22:07 âÚš†9vv®L˜¼%膩䢰滕㬊毺魯⑁鐋ۛ粙㦚㼡Ѧࠔᶬᯧ昷捞쵱₥⇵墫捆ᢸ愋莞嘹
X      0 -rwxr-xr-x     0      0         0 23-May-1905 19:14 勡箦䲎뫾囘坢唜摣껍ꗎ䦄뫹뉵쁰
 1563673641 -r-xr-xr-x     0      0 8118309932373485630  6-Jan-1966 02:33 ¾¹˜RætÖxc˜="
 1155805314 drwxr-xr-x     0      0 6208047416285215202  8-Jun-1917 21:57
       0 drwxr-xr-x     0      0         0 13-Dec-1924 18:27
 2086319415 drwxr-xr-x     0      0 9070420653600621617 30-Aug-2021 19:05
X3030035120 -r-xr-xr-x     0      0 16670235905146023390  1-Jul-2017 21:44 鮁석좈嶴뛙⚙뫓椄阄ቷ젡癶
X      0 dr-xr-xr-x     0      0         0  6-Dec-1928 18:31 舉ꤰ厓ᄫ疡銳瓍㨖娊⟟絅⻿ഃ솥虙
X      0 dr-xr-xr-x     0      0         0  1-Aug-1918 17:56
X      0 -rwxr-xr-x     0      0         0 11-Dec-2010 23:45
X      0 drwxr-xr-x     0      0         0  6-Oct-1902 21:32
X516241533 drwxr-xr-x     0      0 11634701505926017657  6-Oct-1943 00:23
X      0 -r-xr-xr-x     0      0         0 18-May-1922 04:07
X      0 dr-xr-xr-x     0      0         0 24-Dec-1932 20:33 ƒÖùåµ°VpÙ·¬.Öû
X      0 dr-xr-xr-x     0      0         0 13-Jun-1983 16:10 `¬9ŽNÉ
²±,Šò©Í
X210747460 dr-xr-xr-x     0      0 11255034636415520961 19-Jun-1908 17:46 ÉÞv;;Ç8õX[ÆÚ
X      0 -r-xr-xr-x     0      0         0 26-Nov-1949 09:50
X      0 -rwxr-xr-x     0      0         0 12-Dec-1958 20:07 錍愤蔈༦꓂퉵⤚Ꚏ䵻텇墝ẫ䑐꽊
       0 -rwxr-xr-x     0      0         0 13-Jan-2016 09:20 ÖœyúÃCVXJ´©¨õl&
 2744309466 -rwxr-xr-x     0      0 10997743500249914299 18-Nov-1917 21:16 袆ꡪ巆‱꯳멛㪬奕紡ﯲ咴マᄘ퍓ඳ
X      0 dr-xr-xr-x     0      0         0 14-Feb-2018 21:08 圀ﲹ໸肱뉹÷쫼␩㕩떪撘殊툞戯
X1467927448 -rwxr-xr-x     0      0 16881808933397682130 11-Aug-1932 06:46 ᛐ╁髓૚䋿옥᛼셲䎾뎉蠌젘ૹᘦ
X      0 dr-xr-xr-x     0      0         0 23-Aug-1908 22:29 僭私쪝媱쌬꿍䄫鵷߶캹ꣷ瀔㭼呐㈘
 1469364872 dr-xr-xr-x     0      0 8416516432716917632 29-Nov-1952 19:53 0·Ä8Ïíì½êÁ[Á
 2130045348 drwxr-xr-x     0      0 9154087496558420466 28-Dec-1986 23:00 蟦怭୛姛뒴熝李ሗ៰ꆽᄔ継垄벯
X      0 -r-xr-xr-x     0      0         0 27-Jun-2008 21:40
 2390865229 -r-xr-xr-x     0      0 5597244146258962717  6-Feb-2009 15:44
       0 -rwxr-xr-x     0      0         0 25-Nov-1967 11:26
X      0 dr-xr-xr-x     0      0         0 23-Apr-2030 17:12
X30011696 dr-xr-xr-x     0      0 16061586489932288300 29-Oct-1925 20:24
 3838121256 dr-xr-xr-x     0      0 3936112652718829627  4-Oct-2035 15:20 롧㣲Ꞥ鋓ꔮŨ曱괸よ▪ꉑ갴པ⾚
X      0 -r-xr-xr-x     0      0         0  1-Dec-2010 13:57
 3499433810 dr-xr-xr-x     0      0 17837062223802472031  2-May-1945 17:07 J
       0 -r-xr-xr-x     0      0         0 29-Dec-2005 04:38
       0 -rwxr-xr-x     0      0         0 28-Dec-1918 14:09
X      0 dr-xr-xr-x     0      0         0 29-May-1992 01:57 裬擖뇍ﯵ꺵ߡ窇孹듧㳛ꧤ਱䵼
X      0 -rwxr-xr-x     0      0         0 24-Jan-1933 05:01 싦ꇪꤴ䁅齚鱖퍍䆧撗鬎ⓚ缓ඥ쵾촓
 3511631095 dr-xr-xr-x     0      0 1395080363708994366 27-Dec-1907 08:00 됯ਞ켁銓䚻৊釒懮싵榞ᣒ킿嘏깋螿⨆洅࢐쓘⫪ゕ绹빵涿㩦銏⮈픮塍ÓnÔç6	w,Å€a
X2245062326 -rwxr-xr-x     0      0 12325256593335571246 17-Dec-1926 12:19
       0 drwxr-xr-x     0      0         0 20-Jan-2037 10:06
X1230959588 -rwxr-xr-x     0      0 4727987413941468018  9-Jan-2018 03:50 (¦óçv6é¡ÇßÍáh磻⺙枦垿㟡䘭㊏᫒跳ﶰᲜ䦠孅炽찧
X      0 -rwxr-xr-x     0      0         0  3-Dec-1907 00:04
X      0 -rwxr-xr-x     0      0         0  9-Dec-1963 20:02 {«K0/Üù,4ÙŽ
       0 -rwxr-xr-x     0      0         0 22-Jan-1998 03:34
X      0 dr-xr-xr-x     0      0         0  7-May-2009 06:30
       0 -rwxr-xr-x     0      0         0 20-Jan-2025 23:04 遜叇份硠⅚鑰໡謙䥑躯ͳ䈽쾮ᘛ䶺烹づ嗤ᕤኞ詐㭽걌꟬갳鸁ᵶ켏靷췖찳垿敒谧߷址휚뤔௟홍鯓亊
 3763924757 drwxr-xr-x     0      0 489541633859775249  2-Sep-1948 06:48
X      0 dr-xr-xr-x     0      0         0 23-Oct-1982 08:40 嘽탳※篲큙પ苐枴爭鮽殾횳슟㐯
X1236378116 drwxr-xr-x     0      0 13527700603579086467 25-Oct-1933 07:52
X      0 drwxr-xr-x     0      0         0  2-Apr-1991 06:02
 3198186004 -rwxr-xr-x     0      0 3655005924804160989 26-Mar-1950 09:51 﨡챷扳ꚕꃉ씉믁꘽㣊マ昱⹽ᴊ滋
       0 dr-xr-xr-x     0      0         0 23-Apr-1997 02:33
       0 -rwxr-xr-x     0      0         0 26-Jun-2033 22:37 膘ꏞ鯳砟䇣톊歪Ⲛ㕛쭍⎀礽敪睃쏦僺뺁內賷桹垍醙췥㲰Ⱚ锔뮬妕璷╏ڑꨍᶛ꾠㿜綶놡Ƙ餯힔덬
 4070275792 dr-xr-xr-x     0      0 8633069326916319747  2-Jun-1964 18:33 뮕뼢௿终ꎊ堺⍾쾪ᡪ⌗兗ᣁ︀߅媹³/ÇZS}>@9‘½¢Cá
 2426321134 -rwxr-xr-x     0      0 1685201519760289085 23-Nov-1952 12:02
X      0 -rwxr-xr-x     0      0         0 11-Feb-2037 22:33 龏젢ﲿ즬軬弃猲ಹᒤ뷟ꔩ┆¥wèËRÆÚ„pjîØÕÜ!
       0 drwxr-xr-x     0      0         0  4-Jun-2032 23:33
 199749738 -rwxr-xr-x     0      0 8125147743140903611  1-Nov-1947 11:32 黉᭘㽛昂ﵡ闝뭀꩜铄灏껀䶥ྡ⠭왝䳘㸜䢪뚃뮅ꒄ蕒̀Ḛ᎛憆
 2754740193 -rwxr-xr-x     0      0 5063811276451171203  3-Oct-1987 02:48 䵨ꌮ㯿ꕾ婃当둭㝘눛쮸ꉆ♆熆෻휯蘲➌劢䮌솟暸鼂팎酭ꅍ᥻̌쌤
 1977585057 dr-xr-xr-x     0      0 1183718661850586348  5-Aug-1928 05:02
X2840334249 -rwxr-xr-x     0      0 5772258364189502544 14-Sep-1961 12:03
       0 -r-xr-xr-x     0      0         0  6-Sep-2037 23:25 ±ýŸ±g€	^
X1210821857 -rwxr-xr-x     0      0 11733042428410334056  5-Feb-2032 05:55 "ï,9„´¾o˜>T×§i
 74230592 dr-xr-xr-x     0      0 1213187417237907060  8-Nov-1915 20:06 뗚物㔧蟭禫ఘ숏ᣐ舒껬⋫ፆ䩫⫱
       0 dr-xr-xr-x     0      0         0 13-Apr-1959 00:53
X      0 -rwxr-xr-x     0      0         0  7-Jan-1951 05:16
 1859657015 -rwxr-xr-x     0      0 1073399635134023218 19-Jul-1923 11:45 ᑩ璀窙濛뉪皘븢疉灩줤┤䨵瞟᫁섯瑢햦Ⅎ简措쉊烉ᛦ覅쿽燒
X1369474205 -r-xr-xr-x     0      0 15510537808678870786 25-Dec-1916 18:51 ȡ근ꍮ㧵凞ᅙ떣ٓ蜁뙪㣘₤ﺡ솀﶑룣酎谽鉩丣嚸绘椰롡䄆㬅䔝辵邮
       0 drwxr-xr-x     0      0         0 12-Jul-1967 18:02
X4209848971 -rwxr-xr-x     0      0 16382682845610053831 21-Jun-1995 20:23
X1524747704 drwxr-xr-x     0      0 2549832838985427400 18-Jun-2007 04:45
 4077631583 -rwxr-xr-x     0      0 7526790220159772565 29-Jul-1998 06:34 㐠䃥ᢦ뇁ᘟꇔ톯ᕦ쮧뱈쐄懑㣃昳
X      0 -r-xr-xr-x     0      0         0 13-May-2014 19:44 냘꒭ힺ꼜䘑稉㣡底ힻ讳⸥꯻궶ᕸ歩
 1669817006 drwxr-xr-x     0      0 17457449415431277303 26-Apr-1937 03:33
       0 -r-xr-xr-x     0      0         0 20-Dec-1921 19:23
X1159034868 -rwxr-xr-x     0      0 4346216484841354648  3-May-2034 06:02 贎ᄼ녾ꄼ庈Ꙝ菵頝꾟ᔑ땸꾥ꢺ秡䡴讙Ք譊ꚟ冖⠞藋끋㊰싫펒乜ﰗ밣
X      0 drwxr-xr-x     0      0         0 27-Aug-1946 18:00
 299173110 -r-xr-xr-x     0      0 3259667652489597767  6-Feb-1945 00:21 ꋉ롗զ䞰∶ⅶ瓺竹ᣘ䴤꽏ᨢ츮餅
X3837782045 drwxr-xr-x     0      0 4990921864222502415 23-Aug-2025 00:53 ﶬ䚿沿骓ꙍ뀋ௐ勗﯆嚓ﱥ槩ᎌ
       0 -r-xr-xr-x     0      0         0 28-Apr-1945 17:35 ÂÒó¡7ÀÔ!’µºå
X3883026120 dr-xr-xr-x     0      0 17664372073528913134 22-Jul-1926 00:13 ú¬,×çsªoù&Ö‘Þꊘ忱苅촯轱볙崋䃘弒졆蜜议戀濤
       0 -rwxr-xr-x     0      0         0 18-Sep-2030 00:29
       0 drwxr-xr-x     0      0         0  4-Apr-1999 05:29
X3969418596 -rwxr-xr-x     0      0 16992911791371619805 13-Apr-1992 20:55 野書᭛㔸話必摘蓋犂ബ⠙軕䩙뿺㯟燠ﰶ뽮唟ม똻㜁엫께첄ⱦ
X4290779457 dr-xr-xr-x     0      0 10580268176985634880  7-Jan-2038 00:33
       0 -rwxr-xr-x     0      0         0 20-May-2004 18:28
       0 dr-xr-xr-x     0      0         0 17-Aug-2021 04:58
X      0 -r-xr-xr-x     0      0         0 27-Jan-1991 18:51
       0 -r-xr-xr-x     0      0         0 25-Jul-1907 17:58
 3687892849 drwxr-xr-x     0      0 3038034515332715122 12-Mar-2032 00:34 햾뫂䇝蠛巕чⰙ窻䛿춾ó°Ò·ÌØ^îÿØÀã“Ï_
X4187926834 -r-xr-xr-x     0      0 12518617650299803023  5-Feb-2034 06:10
X2841828931 -rwxr-xr-x     0      0 1234355118432277523 28-Nov-1911 14:11
 1263059358 drwxr-xr-x     0      0 11256677758185370291 24-Jun-1939 16:08 ÊLÁAl_·jEZ/áü
       0 drwxr-xr-x     0      0         0  8-Jan-1986 21:27
X3104916254 drwxr-xr-x     0      0 6922173285459607015  9-Dec-1953 23:43 ໡­庚⾙瘔萿⫆길ꦃ랩匝묊骃鑬ᑡ
X      0 -r-xr-xr-x     0      0         0 16-Feb-1969 09:46
 1610920582 drwxr-xr-x     0      0 4569604074366275124  4-Mar-2017 22:07 ðm
üjz¶?y@iEò
       0 drwxr-xr-x     0      0         0 29-Mar-1947 07:53 閭ឲ㖧뚄℞迚긯ꖺ뽉㳧Ⱳ
X      0 -r-xr-xr-x     0      0         0 11-Apr-2012 07:44
X      0 drwxr-xr-x     0      0         0 25-Oct-1987 21:41
Re: Android SD card with RAW filesystem
Please try PhotoRec on the second partition. What are the results ?
sbearss
#3 Post by sbearss »
This was my exact problem.
After running PhotoRec on the second partition, it selected "Other" filesystem type and then the output was 10 .bz2 files that are unusable.
I have a 64GB microSD card with approximately 40GB of data. I removed the card from an Android phone (did not unmount the disk or shut the phone down) and the disk became RAW.
What is the easiest way to recover my 40GB? I read somewhere to format the disk and then use Recuva to recover deleted files. I'm hesitant to delete if either TestDisk or PhotoRec can help me instead.
Thanks!
sbearss, run Testdisk, select the physicaldrive corresponding to your 64GB SD card, Advanced, select the partition, Advanced, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit
sbearss
#5 Post by sbearss »
Hi Christophe - thanks for your reply. Unfortunately the steps you provided are not available to me.
Here is what I see after I choose my SD card:
1/
>[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
Hint: EFI GPT partition table type has been detected.
2/
>[ Advanced ] Filesystem Utils
3/
> 2 P Unknown 34816 122191838 122157023 [android_expand]
Then I have 2 choices:
1. Type
2. Image Creation
4/ I selected "Image Creation" and it created a 62GB image.dd file. If I choose "Type" it allows me to change from EFI GPT. I am stumped at this point.
Thanks for your help!
sbearss
#6 Post by sbearss »
Here are the steps (1-3 of 10) I experience:
Image 1.png (17.55 KiB) Viewed 19842 times
Image 2.png (22.63 KiB) Viewed 19842 times
Image 3.png (15.33 KiB) Viewed 19842 times
sbearss
#7 Post by sbearss »
Here are the steps (4-6 of 10) I experience:
Image 4.png (15.78 KiB) Viewed 19841 times
Image 5.png (13.96 KiB) Viewed 19841 times
Image 6.png (7.14 KiB) Viewed 19841 times
sbearss
#8 Post by sbearss »
Here are the steps (7-9 of 10) I experience:
Image 7.png (8.26 KiB) Viewed 19840 times
Image 8.png (14.93 KiB) Viewed 19840 times
After hitting "P" to show the file list:
Image 9.png (37.13 KiB) Viewed 19840 times
sbearss
#9 Post by sbearss »
I am not able to follow the steps to get to your suggestion:
"Advanced, select the partition, Advanced, Boot, RebuildBS, List"
and here is the final step, hitting "q" to quit:
Image 10.png (11.82 KiB) Viewed 19839 times
How am I able to do the Advanced > Boot > RebuildBS > List ??
Thanks Christophe!
sbearss
#10 Post by sbearss »
Really stumped, this seems to be as far as I can get. I am trying MS Data then
Any help is appreciated.
Image 11.png (13.27 KiB) Viewed 19030 times
Image 12.png (9.17 KiB) Viewed 19030 times
Image 13.png (21.08 KiB) Viewed 19030 times
