Sketch files or ZIP files
atommat
#1 Post by atommat »
im tryign to recover a bunch of .SKETCH files. these are effectively ZIPPED folders containing resources and various other data. i know this because by changing the extension and extracting it with unzip, i have access to to the compressed contents.
i did try and set up a custom file type but it recognises it as a ZIP and there seems no way to tell it otherwise.
so the question is this:
will it recover the files as ZIPS and retain the extension or convert them to ZIPS ... or even at all, seeing as the extension is different? i dunno! : (
any thoughts or comments welcome
a sample SKETCH file attached. ironically, the post page wont allow me to upload a sketch file unless it is zipped so be aware the attached zip is infact a sketch file with the SKETCH extension changed to ZIP...so change the ZIP back to SKETCH and youre good to go!
sample.zip
(20.67 KiB) Downloaded 711 times
thanks in advance
Mat
Re: Sketch files or ZIP files
I have uploaded a new 7.1-WIP. Can you try it ?
