No Access to harddrive
rogerrabbit
#1 Post by rogerrabbit »
I have no access to my harddrive. It shows the harddrive on computer, but i am not able to open the drive. I ve analyzed it with TestDrive in Normal and Deeper Mode. Output in pictures.
The attachment hdd_log_1.png is no longer available
What could be next step?
Thanks for helping
Re: No Access to harddrive
It's useless to search partitions inside a partition.
Read the chapter "Repairing filesystem" from https://www.cgsecurity.org/testdisk.pdf
davidngoliath
#3 Post by davidngoliath »
I have the same thing, I looked in testdisk.pdf where it suggests use chkdsk /f which I did at the very start of this episode, it seemed to go into the "wait the rest of your life mode while it does something and yield nothing".
But I can get access to and get files off the unseen partition using testdisk which is the valuable part. I can only assume the mod is directing us to page 22 of the manual.
