Resuming testdisk copying/not overwriting already copied files?
smntov
#1 Post by smntov »
I was in the middle of copying files (testdisk was able to list them!) from a corrupted external hard drive to a new location, as the process was interrupted. Is there a way to resume from the same place, as many GBs were already copied. Or if I have to start from scratch - is there a way to tell testdisk, not to overwrite existing files?
Thank you!
Re: Resuming testdisk copying/not overwriting already copied files?
Currently the only way to restart the copy from scratch or to only select the directories that havn't been copied.
smntov
#3 Post by smntov »
It would be nice to have some sort of synchronization ability, like in rsync.
Anyway thank you very much for this wonderful tool!
