Still RAW after writing partition
kkangjiie
#1 Post by kkangjiie »
Hi, I have a WD elements 3.0TB that recently has failed to power on. Thus, I removed the HDD and connect it by SATA straight to the motherboard. However, it has difficulty reading the drive and Windows keep prompting me to format it.
I have went through the process of analysing, searching and writing a partition (with my files listed inside) but it is still showing as RAW and i'm kinda stucked with the sector size error:
Also, not entirely sure if it's correct to use EFI GPT! should I be using Intel instead?
Tue Sep 25 01:43:21 2018
TestDisk 7.1-WIP, Data Recovery Utility, June 2018
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=5000981077504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=5000981077504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999626375168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=240054697984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=5000845590528
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=3000589352960
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 860 EVO 1TB, S/N:S3Z9NB0K612711X, FW:RVT01B6Q
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40EFRX-68WT0N0, S/N:WD-WMC4E0010003, FW:80.00A80
Disk /dev/sdc - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - INTEL SSDSC2BW240A4, S/N:BTDA333507F32403GN, FW:DC32
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00MMMB0, S/N:WD-WCAWZ1591984, FW:80.00A80
Disk /dev/sde - 5000 GB / 4657 GiB - CHS 608001 255 63, sector size=512 - Seagate BUP BK, S/N:NA9FLQJ0, FW:0304
Disk /dev/sdd - 3000 GB / 2794 GiB - WDC WD30EZRX-00MMMB0
Partition table type: EFI GPT
Analyse Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
 1 P MS Data                     2048 5860528127 5860526080 [DRAMA]
NTFS at 0/32/33
filesystem size           732565760
sectors_per_cluster       1
mftmirr_lcn               366282879
clusters_per_mft_record   1
NTFS part_offset=1048576, part_size=3000589352960, sector_size=512
NTFS at 0/32/33
file_pread(7,1,buffer,1565565872(364801/81/1)) ReadFile Incorrect function.
file_pread(7,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(7,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(7,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(7,1,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(7,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(7,1,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(7,1,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(7,1,buffer,1565565880(364801/81/9)) lseek err Invalid argument
and the error just keeps continue going on... :(
Please help!
Regards,
KC
Re: Still RAW after writing partition
The partition table is OK. You need to check the filesystem, as described in https://www.cgsecurity.org/testdisk.pdf run "cmd" (right click Run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter).
kkangjiie
#3 Post by kkangjiie »
Maybe I should add this might situation might have happened after a power surge. (can't confirm since I did not use the external HDD for awhile but that was the only event that I can recall that might have killed the external HDD board)
Just an update also I have been running the deep search for past 2 days and still running at the moment:
This is what i am seeing and it definitely looks weird (to me at least)
Chkdsk returns this btw:
The type of the file system is RAW.
CHKDSK is not available for RAW drives.
and this is the disk management screen:
Disk 3 is the drive with problem
No need to search the lost partition (Quick Search/Deeper Search), the partition is not deleted.
Try TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
kkangjiie
#5 Post by kkangjiie »
Hi, thanks for the quick reply. Tried that, but results is not good:
List gave me the following error:
So I didn't write it. This is the 'Boot' screen btw:
Error backup sector?
Anyway, this was the Deep Search result that I quitted:
The first MS Data that was found using the backup sector gave me the same filesystem error and cannot list files. I can see my files in the second MS Data.
What can I do next?
kkangjiie
#6 Post by kkangjiie »
Hi, am I still able to rescue my disk on my own or do I have pay to engage the pros now?
#7 Post by cgrenier »
If TestDisk can list your files, copy them!
It may work when running TestDisk, Advanced, Boot, List.
