External 1TB Toshiba- Not sure where to go after locate
ozstar
#1 Post by ozstar »
I chose 'Analyse' an got a Bad Sectors error.
Chose 'Locate partition' and it went through all the files then ended up with no data under the heading Partition, Start, End, Size in sectors.
Bottom of screen says, Keys A: to add partition, L: load backup and Enter: to Continue
Chose Enter and the.. No partition found or selected for recovery with a Deeper Search option
It goes through numbers then nothing shows again under the titles except the options to Add, Load or Not sure what to do now.
Decided to stop it, reboot then start again and got this..
This is the log.
Wed Sep 26 18:26:50 2018
TestDisk 7.1-WIP, Data Recovery Utility, June 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdi)=1000204883968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=1000204883968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999626375168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=423485243392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000397883392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=576715751424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=314572800000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=338651250688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=314572800000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=8200571904
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=499529023488
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=2000395698176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=524288000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=2000397883392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=467713130496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=1000202657792
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-08WN4A0, S/N:WD-WCC6Y2VUYPFH, FW:02.01A02
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-08WN4A0, S/N:WD-WCC6Y7DCVVEP, FW:01.01A01
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00WN4A0, S/N:WD-WMC6Y0L4D168, FW:01.01A01
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Expansion Desk, S/N:NA4K0NY4, FW:0711
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Expansion Desk, S/N:NA4LFZBV, FW:070B
Disk /dev/sdf - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM0 02-1BC142, S/N:ST500DM002            Z2AE2DAA
Disk /dev/sdg - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - USB3.0 , S/N:00A12345AFD0, FW:8105
Disk /dev/sdh - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate External, S/N:2GHD3919, FW:SG16
Disk /dev/sdi - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA External USB 3.0, S/N:20150324031112, FW:5438
Disk /dev/sdi - 1000 GB / 931 GiB - TOSHIBA External USB 3.0
Analyse Disk /dev/sdi - 1000 GB / 931 GiB - CHS 121601 255 63
BAD_RS LBA=2048 63
NTFS at 0/32/33
 1 * HPFS - NTFS              0  32 33 121601  44 27 1953520816 [TOSHIBA EXT]
Bad relative sector.
NTFS at 0/32/33
filesystem size           1953520816
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
file_pread(12,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(12,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(12,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(12,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(12,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(12,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(12,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(12,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(12,6,buffer,1953525762(121601/90/28)) lseek err Invalid argument
file_pread(12,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(12,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(12,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(12,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(12,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(12,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
   * HPFS - NTFS              0  32 33 121601  57 56 1953521664 [TOSHIBA EXT]
I am sorry, but what should be my next move ?
Thanks
oz
ozstar
Re: External 1TB Toshiba- Not sure where to go after locate
#2 Post by ozstar »
Any help here please?
step21
#3 Post by step21 »
Well, on the second screen, it seems to have found the partition, did you try to press p to see if you can see your files?
As it also had bad sectors and maybe more damage, I would also recommend to make an image of the whole drive to a second disk, as bad sectors/hardware errors will probably get worse.
ozstar
#4 Post by ozstar »
Thank you for your reply.
Yes I did press P and saw the files but wasn't sure what to do next.
I couldn't wait any longer so went to a free trial partition program and it fixed it within a few seconds.
I have used this many times in the past to fix things but have forgotten what I did so didn't want to take any chances with important data.
I do understand the help here may not be forthcoming and that's fine. It is a great script.
Thanks again.
