I've lost my RAID 5 partition. The raid drive is healthy (promise controller, 4x1TB drives, raid 5 size 3TB)
Testdisk finds 6 partitions labeled as Mac HFS. I'm not sure why they are Mac HFS, I don't recall how I set it up, but I'm on a PC with Win 7 Embedded.
When I click P, it says "this filesystem hasn't been implemented" so I can't tell which is the proper partition or how to recover the files. I"m afraid to "write" any of the partition structures to disk in case its the wrong partition choice. I'm not sure what to do next and would appreciate some advice.
Cheers.
Raid 5 partition lost
Re: Raid 5 partition lost
As your computer is running Windows, the HFS "partition" are probably false positive.
After selecting the disk, is EFI GPT auto-detetected ?
In Advanced, is a MS Data partition using the whole disk listed ?
Yes, EFI GPT was auto detected. Also, this is not a boot drive, just a data drive.
In Advanced, I have
1 P MS Reserved ..... [Microsoft reserved]
2 P MS Data ............[Basic data partition]
I just ran the tool again and it's searching for the two MS drives now with the below info given. Does the duplicate listing of 1 and 2 indicate corruption in a certain way?
No Fat, NTFS, ext2, JFS, Reiser, cramfs, or XFS marker
1 P MS Reserved 10 65545 65536 [Microsoft Reserved]
2 P MS Data 66048 1465045503 1464979456 [ Basic data partition]
It still just seems to be finding Mac HFS partions so far but I'm still in the first percent of the search.
In Advanced, I have
It's at 96% now after 2 days of running, here is the log file, still no really clear what is going on.
Thu Oct 11 09:59:34 2018
TestDisk 7.1-WIP, Data Recovery Utility, June 2018
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=320078872576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=3000413257728
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=320078872576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=3000413257728
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=319971917824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=185389056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000277925888
Disk /dev/sda - 320 GB / 298 GiB - CHS 38914 255 63, sector size=512 - Intel Raid 0 Volume, S/N:Volume0, FW:1.0.
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 91194 255 63, sector size=2048 - Promise 4 Disk RAID5, S/N:3456ef5078cd000400000000000000000000000000000000, FW:1.10
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 91194 255 63, sector size=2048 - Promise 4 Disk RAID5, S/N:3456ef5078cd000400000000000000000000000000000000, FW:1.10
Drive D: - 185 MB / 176 MiB - CHS 44 64 32, sector size=2048 - HL-DT-ST BD-RE BH10LS38, S/N:8KCAP25912 5, FW:1.00
Drive E: - 3000 GB / 2794 GiB - CHS 91190 255 63, sector size=2048 - Promise 4 Disk RAID5, S/N:3456ef5078cd000400000000000000000000000000000000, FW:1.10
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - Promise 4 Disk RAID5
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 91194 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1465045535 (expected 1465045535)
hdr_lba_start=10
hdr_lba_end=1465045526
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Reserved 10 65545 65536 [Microsoft reserved partition]
2 P MS Data 66048 1465045503 1464979456 [Basic data partition]
HFS+ magic value at 678/161/1
part_size 299120
Mac HFS 10902213 11201332 299120
HFS+ blocksize=2048 + Backup, 612 MB / 584 MiB
HFS+ magic value at 760/143/31
part_size 308851
Mac HFS 12218439 12527289 308851
HFS+ blocksize=2048 + Backup, 632 MB / 603 MiB
HFS+ magic value at 779/204/5
part_size 328850
Mac HFS 12527491 12856340 328850
HFS+ blocksize=2048 + Backup, 673 MB / 642 MiB
check_FAT: number of bytes per sector mismatches 512 (FAT) != 2048 (HD)
HFS+ magic value at 5740/97/11
part_size 299120
Mac HFS 92219221 92518340 299120
HFS+ magic value at 6149/116/53
part_size 308851
Mac HFS 98791045 99099895 308851
HFS+ magic value at 6186/183/5
part_size 328850
Mac HFS 99389623 99718472 328850
P Mac HFS 10902213 11201332 299120
P Mac HFS 12218439 12527289 308851
P Mac HFS 12527491 12856340 328850
P Mac HFS 92219221 92518340 299120
P Mac HFS 98791045 99099895 308851
P Mac HFS 99389623 99718472 328850
1 P Mac HFS 10902213 11201332 299120
2 P Mac HFS 12218439 12527289 308851
3 P Mac HFS 12527491 12856340 328850
4 P Mac HFS 92219221 92518340 299120
5 P Mac HFS 98791045 99099895 308851
6 P Mac HFS 99389623 99718472 328850
Support for this filesystem hasn't been implemented.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=10
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=10
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=10
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
part_size 299120
part_size 308851
part_size 328850
part_size 299120
part_size 308851
part_size 328850
hdr_size=92
hdr_lba_self=1
hdr_lba_start=10
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=10
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
