partition ends after the disk limits
abiyi
#1 Post by abiyi »
Hi everyone! first post...
I've been trying unsuccessfully to restore a FAT32 partition in a Samsung STORY Station using TestDisk 7.0 on Debian GNU/Linux, but I only get the message "The following partitions can't be recovered", and "This partition ends after the disk limits." in the log file.
In first place I wanted to change the file system from FAT32 to NTFS, so I backed up up some directories with no problem to make room to create a NTFS partition. Everything was fine until I backed up the Pictures folder (93 GB), which required the use of rsync, many times. Because I noticed a 5 GB gap between the size of the source folder (FAT32) and the destiny folder (NTFS) I decided to run TestDisk to undelete the missing files. There the things went down: I restored a very old FAT32 partition with just a few video files and now the partition Audio (773 GB) and Video (853 GB) seems to be wiped out.
To make things worst I decided to follow the instructions of How to clean an MBR and recover drive partitions so I deleted the Boot Sector with GParted to write a new one... and decided to deleted both partitions: FAT32 and NTFS and somehow restore the old FAT32 partition with the Audio and Video folder... but now TestDisk cannot restore anything because a wrong geometry issue.
Thu Oct 11 09:13:44 2018
OS: Linux, kernel 4.18.0-0.bpo.1-686-pae (#1 SMP Debian 4.18.6-1~bpo9+1 (2018-09-13)) i686
Compiler: GCC 6.3
ext2fs lib: 1.44.2, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BPVT-55HXZT4, S/N:WD-WXU1EB1MMHDW, FW:01.01A01
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung STORY Station
Disk /dev/sdb - 2000 GB / 1863 GiB - Samsung STORY Station
New options :
 Dump : Yes
 Align partition: Yes
 Expert mode : Yes
BAD_RS LBA=1311815976 5532187
     FAT32 LBA            349006  29 56 522761 215 38 2791385776
This partition ends after the disk limits. (start=5606783272, size=2791385776, end=8398169047, disk end=3907029168)
BAD_RS LBA=3719113507 9528184
     FAT12                231504  27 47 467773 232 55 3795674409
This partition ends after the disk limits. (start=3719113507, size=3795674409, end=7514787915, disk end=3907029168)
NTFS at 225353/239/39
filesystem size           286717952
sectors_per_cluster       8
mft_lcn                   4
mftmirr_lcn               17919871
clusters_per_mft_record   -10
     HPFS - NTFS          225353 239 39 243201  78 13  286717952
     NTFS, blocksize=4096, 146 GB / 136 GiB
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4299 GB / 4004 GiB)
   * HPFS - NTFS          225353 239 39 243201  78 13  286717952
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 286717952 linear /dev/sdb 3620311040" | dmsetup create test0
 1 * HPFS - NTFS          225353 239 39 243201  78 13  286717952
mft_lcn                   4
NTFS at 243201/78/13
mft_lcn                   4
     NTFS found using backup sector, blocksize=4096, 146 GB / 136 GiB
Now I'd would think that all those gigabytes of audio and video are lost forever... except that I haven't modify any data on that disk (besides the partition table in the boot sector, which I hope it haven't affect my data). I don't want to messing around with PhotoRec yet (every scanning of the 2TB hard disk takes around 8 hours, and I've run TestDisk on the Story Station too many times this week).
So, there's a solution to this monumental mess I've made?
changing the disk geometry could restore the FAT32 partition with the Video and Audio folders...? (I don't care about the NTFS with the Pictures folder).
Re: partition ends after the disk limits
Run TestDisk, in Geometry, set the number of heads to 16, Analyse, Quick Search, Stop, Deeper Search. Does it find your lost partitions ?
abiyi
#3 Post by abiyi »
Thanks for the replay!
Seems like the lost partitions are always visible, but can not be recovered... I changed the number of heads to 16, as you advised and after more than a day the result is basically the same:
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63
>  FAT32 LBA            2035958  13 63 6044969   0  2 4041082209
   FAT12                3689596  11 47 7455146  11 55 3795674409
   FAT32                3758431  13 11 5180470  11 62 1433415238
   HPFS - NTFS          4330947  12 58 7849819   8 52 3547022719
   FAT32 LBA            5562284  15 56 8331516  14 38 2791385776
[ Continue ]
2069 GB / 1926 GiB
The duplicated partitions seems to be the result of the manual creation of another boot sector. Before that I did run another search changing partition table type from Intel to EFI GPT, but I stopped hours later of reading your replay. No writing was made under that setting.
Here is the whole testdisk.log:
Sat Oct 13 14:24:58 2018
Compiler: GCC 6.3
New geometry
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63 sector_size=512
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63
BAD_RS LBA=2052246545 200462
This partition ends after the disk limits. (start=2052246545, size=4041082209, end=6093328753, disk end=3907029168)
The harddisk (2000 GB / 1863 GiB) seems too small! (< 3119 GB / 2905 GiB)
I haven't close that TestDisk session, after day and half of hard disk scanning I want to wait for more instructions, what else can I do at this point?
The geometry error message keeps displaying over and over again, how can it be fixed the partition size in order to recover it?
abiyi
#4 Post by abiyi »
What would happens to the data in that hard disk if I create a FAT32 partition and then try to recover it...? Seems like I'm stuck in the middle of nowhere.
