Photorec in Scripted Mode won't accept destination
macker20
#1 Post by macker20 »
I'm using photorec from a bat file and when I set the destination with the /d switch I get "Unable to open file or device Results: No error"
The script looks like this.
E:\testdisk-7.1-WIP.win64\testdisk-7.1-WIP/photorec_win.exe /cmd /dev/sda /d Results  partition_none,fileopt,everything,disable,jpg,enable,wholespace,search
The results folder is at E:/Results and I'm running in admin mode and from the E: root. I've tried E:/Results/ and E:/Results nothing seems to work. When I use interactive mode I can pick this location without a problem.
Thanks
Re: Photorec in Scripted Mode won't accept destination
Can you try
E:\testdisk-7.1-WIP.win64\testdisk-7.1-WIP/photorec_win.exe /d Results /cmd /dev/sda partition_none,fileopt,everything,disable,jpg,enable,wholespace,search
