Corrupted partition name and incorrect partition type?
TestAnon
#1 Post by TestAnon »
After trying to recover the deleted boot partition after a failed windows install where the HDD was needed to be present in order to boot into Windows that was installed in a SSD partitions got messed up.
The drive used to be NTFS, never used HFS partitions on it.
TestDisk 7.1-WIP, Data Recovery Utility, February 2018
 P MS Data                  1026048    5220351    4194304 [OS]
 D MS Data                 11213083   11219256       6174
 D MS Data                 11219256   11225429       6174 [Boot]
 D MS Data                 11219275   11225448       6174
 D MS Data                 11225448   11231621       6174 [Boot]
 D MS Data                 11302651   11308824       6174
 D MS Data                 11308824   11314997       6174 [Boot]
 D MS Data                 11308843   11315016       6174
 D MS Data                 11315016   11321189       6174 [Boot]
 P EFI System              11344464   11347343       2880 [EFI System Partition]
 P EFI System              11347344   11350223       2880 [EFI System Partition]
>P Mac HFS                 14299334  895103175  880803842 [2^FPrM-{a]
 P MS Data                895105024 1953523711 1058418688 [New Volume]
                P=Primary  D=Deleted
Keys A: add partition, L: load backup, T: change type,
     Enter: to continue
HFS blocksize=16777216, 450 GB / 420 GiB
Anything could be done to recover the old partition layout or should i start running photorec to recover the files?
Re: Corrupted partition name and incorrect partition type?
Do you had one or 2 NTFS partitions on this disk ?
Can you try to list the files from the last partition ?
Please provide the full testdisk.log file.
