hi everyone,
when i started up my external disk, windows 7 said "windows need to format disk"
so i started searching for answers
i found testdisk and used it to copy my data over to another HDD
now i want to repair my disk
i have no idea how to do that
i think there is something wrong with the boot sector
i have copied my log
can someone help me??
thanks
JImmy
TestDisk 7.1-WIP, Data Recovery Utility, September 2018
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=60022480896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=60022480896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=60020490240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
Disk /dev/sda - 60 GB / 55 GiB - CHS 7297 255 63, sector size=512 - Inateck ASM1153E, S/N:111987654321
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EURS-63S48Y0, S/N:152D20337A0C
Disk \\.\PhysicalDrive2 - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EURS-63S48Y0, S/N:152D20337A0C
Drive E: - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EURS-63S48Y0, S/N:152D20337A0C
Disk /dev/sdc - 2000 GB / 1863 GiB - WDC WD20 EURS-63S48Y0
Analyse Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 30400 255 63
NTFS at 0/4/5
Info: size boot_sector 3907024896, partition 488378112
1 * HPFS - NTFS 0 4 5 30400 37 37 488378112 [Data]
NTFS at 0/4/5
filesystem size 3907024896
mftmirr_lcn 2
file_pread(5,1,buffer,488378650(30400/42/5)) lseek err Invalid argument
file_pread(5,1,buffer,488378687(30400/42/42)) lseek err Invalid argument
file_pread(5,1,buffer,488378713(30400/43/5)) lseek err Invalid argument
file_pread(5,1,buffer,488378879(30400/45/45)) lseek err Invalid argument
file_pread(5,1,buffer,488378880(30400/45/46)) lseek err Invalid argument
file_pread(5,1,buffer,488378656(30400/42/11)) lseek err Invalid argument
file_pread(5,1,buffer,488378672(30400/42/27)) lseek err Invalid argument
file_pread(5,1,buffer,488378688(30400/42/43)) lseek err Invalid argument
file_pread(5,1,buffer,488378704(30400/42/59)) lseek err Invalid argument
file_pread(5,1,buffer,488378720(30400/43/12)) lseek err Invalid argument
file_pread(5,1,buffer,488378736(30400/43/28)) lseek err Invalid argument
file_pread(5,1,buffer,488378752(30400/43/44)) lseek err Invalid argument
file_pread(5,1,buffer,488378768(30400/43/60)) lseek err Invalid argument
file_pread(5,1,buffer,488378784(30400/44/13)) lseek err Invalid argument
file_pread(5,1,buffer,488378800(30400/44/29)) lseek err Invalid argument
file_pread(5,1,buffer,488378816(30400/44/45)) lseek err Invalid argument
file_pread(5,1,buffer,488378832(30400/44/61)) lseek err Invalid argument
file_pread(5,1,buffer,488378848(30400/45/14)) lseek err Invalid argument
file_pread(5,1,buffer,488378864(30400/45/30)) lseek err Invalid argument
file_pread(5,1,buffer,488378881(30400/45/47)) lseek err Invalid argument
file_pread(5,1,buffer,488378882(30400/45/48)) lseek err Invalid argument
file_pread(5,2,buffer,488378887(30400/45/53)) lseek err Invalid argument
file_pread(5,2,buffer,488378889(30400/45/55)) lseek err Invalid argument
file_pread(5,3,buffer,488378895(30400/45/61)) lseek err Invalid argument
file_pread(5,1,buffer,488379136(30400/49/50)) lseek err Invalid argument
New options :
Dump : No
Align partition: Yes
Expert mode : No
Drive E: - 2000 GB / 1863 GiB - WDC WD20 EURS-63S48Y0
Partition table type: None
NTFS at 0/0/1
mftmirr_lcn 2
NTFS at 0/0/1
P NTFS 0 0 1 30400 33 33 488378112 [Data]
ntfs_boot_sector
NTFS at 0/0/1
filesystem size 3907024896 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
Status: Bad
Sectors are not identical.
ntfs_boot_sector
NTFS at 0/0/1
mft_lcn 786432 0
mftmirr_lcn 2 0
Status: OK
Status: Bad
Help with restoring disk
Re: Help with restoring disk
Run "cmd" using right click "run as administrator" and "chkdsk /f e:". What is the result/the output ?
Hi
Does not work because disk is not visible in Windows
I can not select it
Jimmy
I can not select it
Jimmy
It is also not visible in disk management in Windows
It does not show up
It does not show up
It happened When i removed the disk from an old computer and put it in an docking station wich i connect through usb on my new computer
Previously your partition was listed as E:
