Hard disk not recognised in OC after rebuild BS
MuthuSaravanan
#1 Post by MuthuSaravanan »
HI,
My external hard disk had issues reading in PC. I used test disk to rebuild BS. after that my hard disk not even recognized by PC. I could see the drive of the hard disk but not listed in my computer.
I have loads of data stored in the hard drive, could you help me recover them.
Muthu S
Re: Hard disk not recognised in OC after rebuild BS
If you run PhotoRec, does it recover your data ?
If there are read errors, clone the disk using ddrescue as described in https://www.cgsecurity.org/testdisk.pdf
