GPT Protective Partition (inaccessible 3TB external disk, Windows)
chrisfox
#1 Post by chrisfox »
Disk is marked GPT Protective (Windows 10)
Need testdisk instructions to recover lost partition... my wife's photography :(
I have 3 physical disks. This is the 1 I need to recover:
Media: /dev/sdc 746 GiB WDS WD30 EZRX-00SPEB0
I've used a few other tools to see the data is there but the partition table is screwed up. I want to be able to recover the data. Looks like testdisk can do it but I need help - any help greatly appreciated.
I've followed earlier instructions in this forum re:
Run TestDisk 7.1-WIP, select the disk, EFI GPT, Analyse, Quick Search, Quit and copy/paste the content of the testdisk.log file:
Wed Nov 21 19:07:27 2018
TestDisk 7.1-WIP, Data Recovery Utility, September 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=224049579520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000333AS, S/N:9TE17X0Q, FW:CC1F
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO 250GB, S/N:S21MNSAG211773Y, FW:EMT01B6Q
Disk /dev/sdc - 801 GB / 746 GiB - CHS 97451 255 63, sector size=512 - WDC WD30 EZRX-00SPEB0, S/N:DCC4E7149888
Disk /dev/sdc - 801 GB / 746 GiB - WDC WD30 EZRX-00SPEB0
Partition table type: EFI GPT
Analyse Disk /dev/sdc - 801 GB / 746 GiB - CHS 97451 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1565565871 (expected 1565565871)
hdr_lba_start=34
hdr_lba_end=1565565838
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Bad GPT partition entries, invalid checksum.
Trying alternate GPT
file_pread(6,2,buffer,1565566975(97452/9/29)) lseek err Invalid argument
file_pread(6,1,buffer,1565566975(97452/9/29)) lseek err Invalid argument
Re: GPT Protective Partition (inaccessible 3TB external disk, Windows)
Looks like an hardware problem. You wrote it's a 3TB harddisk but the disk is reported as 800GB.
This problem need to be fixed before using a data recovery utility.
