Hi.
Please help me with my problem.
I've just formatted HFS disc with Time Machine(OS x) backups. I formated it in HFS again.
So, i tried testdisk. it found 2 existing partitions.
EFI (40 - 409639)
HFS (409640-1953262983)
After deep scaning(NOT full - only first 40cyl) it found 2 more partitions(Screenshot)
I write new map. I set 2 found partitions to primary.
BUT! After writing new map I get error, while trying mount this drive.
Can you help me, please?
P.s. I start new deep scaning.
P.p.s. I can't press P to view list of files. There is no such option.
Thanks a lot!
Formatted HFS recovey
- Безымянный.JPG (57.32 KiB) Viewed 4855 times
Re: Formatted HFS recovey
Here is my log(I do this scan after rewriting partition map)
Sun Jul 8 13:15:18 2012
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=16039018496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4040748544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=16039018496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4040748544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=41940670464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=16039017472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=666251264
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=85888341504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=4040747520
file_pread(4,1,buffer,312592769(19457/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,31326749(1949/254/63)) lseek err Invalid argument
file_pread(6,1,buffer,7903979(491/254/63)) lseek err Invalid argument
file_pread(7,1,buffer,1953536129(121601/254/63)) lseek err Invalid argument
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST9160314AS, FW:0002SDM1
Disk /dev/sdb - 16 GB / 14 GiB - CHS 1949 255 63, sector size=512 - Corsair VoyagerGT, FW:1100
Disk /dev/sdc - 4040 MB / 3853 MiB - CHS 491 255 63, sector size=512 - Corsair Voyager Mini, FW:0.00
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EARS-00Y5B1, FW:80.0
Drive E: - 666 MB / 635 MiB - CHS 158 64 32, sector size=2048 - DTSOFT BDROM, FW:1.05
Disk /dev/sdd - 1000 GB / 931 GiB - WDC WD10 EARS-00Y5B1
Partition table type: EFI GPT
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : No
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525167 (expected 1953525167)
hdr_lba_start=34
hdr_lba_end=1953525134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 46 409645 409600
2 P Mac HFS 469351 1953322694 1952853344
FAT32 at 0/0/41
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
heads/cylinder 16 (FAT) != 255 (HD)
FAT32 at 0/0/41
EFI System 40 409639 409600 [EFI]
FAT32, 209 MB / 200 MiB
HFS+ magic value at 25/127/15
part_size 1952853344
Mac HFS 409640 1953262983 1952853344
HFS+, 999 GB / 931 GiB
P EFI System 40 409639 409600 [EFI]
P Mac HFS 409640 1953262983 1952853344
1 P EFI System 40 409639 409600 [EFI]
2 P Mac HFS 409640 1953262983 1952853344
The problem is, HFS+ doesn't list any files.
Formatting is overriding your previous file system.
TestDisk will find only an empty partition.
In your case it's advisable to use dataracovery software.
You can have a try to use PhotoRec.
Info;
It's advisable to go into File Opt and deselct all files.
Check only needed files.
It saves a lot of time to sort files after recovery.
If you need file names and directories you should use commercial software.
Info;
