I've been facing one weird issue since yesterday. I never encountered or came across such issue ever.
When I turn on my PC it shows the following message "Reboot and select proper boot device or insert boot media in selected boot device and press a key." What does it mean? I wanted to know what to do to solve this problem.
Any help would be appreciated.
Facing reboot and select proper device issue
Re: Facing reboot and select proper device issue
You need to check if your disk(s) are properly detected by your computer BIOS. An extra disk/dvd/usb key may also be responsible for this message.
Boot from an USB key by example and check if the partition table lists all your partitions/drives.
Check if you can browse correctly the files from each partition...
