MDT Deployment Disk does not create partitions properly
Charlie202
#1 Post by Charlie202 »
I am working on an offline DVD based deployment image and have created an .iso file that properly deploys to a Hyper-V virtual machine instance. My deployment requires me to have 3 standard hard drives; Windows, Data, and Logs.
The system is using UEFI partitions, but I have duplicated the appropriate drives on the BIOS option as well mobdro.
The resultant partitions are as follows (with obvious differences with the BIOS version):
Boot (EFI) 499 mb
(MSR) 128 mb
Windows (Primary) 65% remaining, NTFS (C:)
Data (Primary) 40% remaining, NTFS (D:)
Logs (Primary) 80% remaining, NTFS (E:)
Recovery (Recovery) 100% remaining NTFS
After testing to ensure that the .iso was working properly, I burned the .iso to disc with Poweriso. I have burned the disc twice to ensure there was no issue. The second time, I used a slow burn speed.
On the VM, the partitions function as expected with no errors, but when running the deployment from a dvd, the partitions I see are as follows:
Boot (EFI) 499 mb
(MSR) 128 mb
Windows (Primary) NTFS (C:)
Data (Primary) NTFS (D:)
Recovery (Recovery) NTFS
Unallocated
The E:\ drive is not accessible to manually create a drive during a suspense in the deployment.
What would be an effective method to fix this partition creation error?
Re: MDT Deployment Disk does not create partitions properly
Maybe the problem is linked to the PC Intel partitionning
PC Intel partitionning is limited to 4 entries, usually
- 4 primary partitions
- 3 primary and an extended partition containing one or more logical partitions.
