[TestDisk] Need help with repairing a corrupt Samsung micro-SD card
Bleaknice
#1 Post by Bleaknice »
I want to copy some app data from my corrupt SD card "Android\Data" with TestDisk because I want to retrieve the original filenames, which PhotoRec cannot offer.
But how can I repair my SD card before I'm able to copy data?
Beforehand, I ran chkdsk a few times, but I got the following error messages every time:
  • * \[folder 1] first allocation unit is not valid. The entry will be truncated."
    * The \[folder 2] entry contains a nonvalid link. Unrecoverable error in folder \[folder 2]. Convert folder to file (Y/N)?" (I said no)
    * The \[folder 3] entry contains a nonvalid link. Folder \[folder 3] has bad clusters. Bad clusters removed from folder. Unrecoverable error in folder \[folder 3]. Convert folder to file (Y/N)?" (I said no)
    * \System Volume Information first allocation unit is not valid. The entry will be truncated.
    * Removing trailing folder entries from \[folder 4]. Then the scan was ended.
Most of the corrupted folders contained music and image files, but not all my folders (like the Android folder with app data) got that error message.
On TestDisk, I followed these steps:
* Choose Intel as detected
* Advanced > Boot
Then I got this message:
Disk /dev/sde - 32 GB / 29 GiB - CHS 3891 255 63
 1 P FAT32 LBA                0 130  3  3891 148 33   62510080
OK
OK
First sectors (boot code and partition information) are not identical.
A valid FAT Boot sector must be present in order to access any data; even if the partition is not bootable.
So what kind of corruption is going on here?
What should I do next if the First sectors are not identical, while the Boot sector and Backup boot sector are OK?
Re: [TestDisk] Need help with repairing a corrupt Samsung micro-SD card
Choose List and try to copy your files.
Bleaknice
#3 Post by Bleaknice »
Tried this weekend to plug in my SD card in different ways: with SD card adapter, without SD card adapter, with card reader, without card reader, different laptop, but the drive doesn't get recognized! Otherwise, I'd get the notification that "there is a problem with this driver". I did a run with "diskmgmt", but it stalled at "connecting for Virtual Disk Service".
What does this mean? What do I have to do first to let the SD card be recognized at least?
