3TB mounted incorrectly was then re-formatted
ac2334
#1 Post by ac2334 »
Ok, I am in a crisis here and I need to do my best to rebuild the filesystem. I will list every step that has been taken and mistakes made along the way, as well as the current state of the drive. Thankfully, the first thing I did was run Testdisk before these mistakes, so perhaps the .log file can be of help now.
I attached a 3TB drive, formatted as a single partition HFS+ drive using a USB 2.0 disk cradle and noticed that only about 750GB were being recognized on the drive. Not thinking that it could be the cradle itself (which that was the problem) I then (from within windows) reformatted the drive as ExFAT but the problem of less disk space remained. Now I figured out the problem and attached the drive to a USB 3.0 enclosure and the 3TB was now showing properly. I am very angry to make this mistake because some essential work files are on this drive. Immediately I ran Testdisk from within the mac and I have a log file to assist if it can help.
From a Macintosh I then ran DiskDrill to scan for files, it did detect many files but began sorting them by file type and in this case this is not ideal because of the size of the drive and quantity of files - I must try to rebuild the original filesystem if possible. Then from DiskDrill I ran "scan for HFS+ file system" and to my surprise the entire correct folder structure appeared! So I then tried to preview the files/restore a few but they were corrupt :(
I only mention DiskDrill to give proof that the folder structure was being recognized when I scanned for HFS+.
Next I did a big mistake. The drive was not mounted and was in fact not mountable, however, Testdisk and DiskDrill could read it fine. Hoping to fix the issue on a mounted drive, I then did a quick format to HFS+ on the drive, understanding that only the partition table would be re-written. At this point I was not able to see the files as before in DiskDrill (only through a deep scan which then found many orphaned files) and I was panicking. I calmed down and opened Testdisk and having read Cristophe's guide I opted to use the backup superblock to overwrite the current.
Now when I run Testdisk (with 3TB disk unmounted) I can see that a quick search can find EFI system and Mac HFS. I am hoping that the superblock will give me a chance to rebuild my proper file structure.
I have both TestDisk and DiskDrill log files that were generated before my mistake. I am not able to see the complete folder structure as before in DiskDrill, but a deep scan can recover 2.6TB (the full used space) but the files are sorted by type with many orphans and so I am keeping hope that because the drive is healthy and only the partition table damaged I can make full recovery.
Please help me if possible
Thank you!
Re: 3TB mounted incorrectly was then re-formatted
At this stage (partition reformated as exFAT and next as HFS+), TestDisk will not be able to recover the original HFS+.
It's possible to sort the files recovered by PhotoRec (see the dedicated chapter in https://www.cgsecurity.org/testdisk.pdf) but original filenames won't be recovered.
ac2334
#3 Post by ac2334 »
Hi Cristophe, thank you for your quick reply.
I believe that I am incorrect, the drive was not formatted as ExFAT. It may have been formatted as NTFS or I may have only formatted it as HFS+ on the Mac.
I have two computers: a PC and a Mac. I noticed the incorrect disk size when I had attached the drive to the PC and afterwards worked from the Mac only.
Here is what I know: once attached to the Mac, the file recovery software Disk Drill was able to see my entire 100% folder structure (I checked it for accuracy) when I ran "scan for lost HFS+ partition". Therefore it seems this would not have been possible if I had accidentally formatted as ExFAT on WIndows, so there I think I am lucky.
Once on the Mac I would only have formatted as HFS+ - a quick search with Testdisk at that time was able to see the correct HFS partition. I am currently running a deeper search and will post here what it finds (so far it is listing about 8 Mac HFS formatted partitions).
If I attach my testdisk.log file would you consider to take a look? This data is important and I have hope for a full recovery still. The testdisk.log file was taken before I made the mistake of formatting to HFS+ (when I could still see the complete folder structure from within Disk Drill). I am hoping that if we can create a new partition with the correct cylinder value and start and end values I can be back up and running.
Again, I do not believe that I formatted as ExFAT.
Thank you for your help!
ac2334
#4 Post by ac2334 »
Deeper search is currently running (at 26%) - in other posts I see that you have advised others to select "Stop" once some partitions are found. I have attached my screen and will try to attach my log file.
I believe that this is simply a matter of restoring an HFS+ partition table that was overwritten by HFS+
Thank you for any help that you can provide!
Log file:
Wed Jan 9 23:20:10 2019
TestDisk 7.1-WIP, Data Recovery Utility, December 2018
OS: Darwin, kernel 18.2.0 (Darwin Kernel Version 18.2.0: Mon Nov 12 20:24:46 PST 2018; root:xnu-4903.231.4~2/RELEASE_X86_64) x86_64
Compiler: GCC 4.0
Compilation date: 2018-12-29T10:41:46
Disk /dev/disk3 - 3000 GB / 2794 GiB - 732566646 sectors, sector size=4096
Disk /dev/rdisk3 - 3000 GB / 2794 GiB - 732566646 sectors, sector size=4096
Partition table type: EFI GPT
Analyse Disk /dev/rdisk3 - 3000 GB / 2794 GiB - 732566646 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=732566645 (expected 732566645)
hdr_lba_start=6
hdr_lba_end=732566640
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 6 76805 76800 [EFI System Partition]
2 P Mac HFS 76806 732533871 732457066
FAT32 at 6/0/1
FAT1 : 32-106
FAT2 : 107-181
start_rootdir : 182 root cluster : 2
Data : 182-76799
sectors : 76800
cluster_size : 1
no_of_cluster : 76618 (2 - 76619)
fat_length 75 calculated 75
sect/track 32 (FAT) != 1 (HD)
FAT32 at 6/0/1
EFI System 6 76805 76800 [EFI System Partition] [EFI]
FAT32, blocksize=4096, 314 MB / 300 MiB
HFS+ magic value at 76806/0/1
part_size 732457066
HFS+ blocksize=8192, 3000 GB / 2794 GiB
P EFI System 6 76805 76800 [EFI System Partition] [EFI]
1 P EFI System 6 76805 76800 [EFI System Partition] [EFI]
FAT32 at 6/0/1
FAT1 : 32-106
FAT2 : 107-181
Data : 182-76799
sectors : 76800
cluster_size : 1
FAT32 at 6/0/1
FAT32 at 12/0/1
FAT1 : 32-106
FAT2 : 107-181
Data : 182-76799
sectors : 76800
cluster_size : 1
FAT differs, FAT sectors=64-75/75
FAT32 at 12/0/1
EFI System 12 76811 76800 [EFI System Partition] [EFI]
HFS+ magic value at 51205/0/1
part_size 732482668
Mac HFS 51205 732533872 732482668
HFS+ blocksize=8192 + Backup, 3000 GB / 2794 GiB
NTFS at 51456/0/1
filesystem size 1565153280
mftmirr_lcn 2
MS Data 51456 195695615 195644160 [New Volume]
NTFS, blocksize=4096, 801 GB / 746 GiB
HFS+ magic value at 67223/0/1
part_size 732482668
Mac HFS 67223 732549890 732482668
HFS+ magic value at 67235/0/1
part_size 732482668
Mac HFS 67235 732549902 732482668
HFS+ magic value at 67247/0/1
part_size 732482668
Mac HFS 67247 732549914 732482668
HFS+ magic value at 67265/0/1
part_size 732482668
Mac HFS 67265 732549932 732482668
HFS+ magic value at 67280/0/1
part_size 732482668
Mac HFS 67280 732549947 732482668
HFS+ magic value at 67312/0/1
part_size 732482668
Mac HFS 67312 732549979 732482668
HFS+ magic value at 67358/0/1
part_size 732482668
Mac HFS 67358 732550025 732482668
HFS+ magic value at 67370/0/1
part_size 732482668
Mac HFS 67370 732550037 732482668
HFS+ magic value at 67382/0/1
part_size 732482668
Mac HFS 67382 732550049 732482668
HFS+ magic value at 67401/0/1
part_size 732482668
Mac HFS 67401 732550068 732482668
HFS+ magic value at 67416/0/1
part_size 732482668
Mac HFS 67416 732550083 732482668
HFS+ magic value at 67433/0/1
part_size 732482668
Mac HFS 67433 732550100 732482668
HFS+ magic value at 67455/0/1
part_size 732482668
Mac HFS 67455 732550122 732482668
HFS+ magic value at 67471/0/1
part_size 732482668
Mac HFS 67471 732550138 732482668
HFS+ magic value at 67483/0/1
part_size 732482668
Mac HFS 67483 732550150 732482668
HFS+ magic value at 67499/0/1
part_size 732482668
Mac HFS 67499 732550166 732482668
HFS+ magic value at 67519/0/1
part_size 732482668
Mac HFS 67519 732550186 732482668
HFS+ magic value at 67531/0/1
part_size 732482668
Mac HFS 67531 732550198 732482668
HFS+ magic value at 67545/0/1
part_size 732482668
Mac HFS 67545 732550212 732482668
HFS+ magic value at 67557/0/1
part_size 732482668
Mac HFS 67557 732550224 732482668
HFS+ magic value at 67569/0/1
part_size 732482668
Mac HFS 67569 732550236 732482668
HFS+ magic value at 67581/0/1
part_size 732482668
Mac HFS 67581 732550248 732482668
HFS+ magic value at 67591/0/1
part_size 732482668
Mac HFS 67591 732550258 732482668
HFS+ magic value at 67609/0/1
part_size 732482668
Mac HFS 67609 732550276 732482668
HFS+ magic value at 67639/0/1
part_size 732482668
Mac HFS 67639 732550306 732482668
HFS+ magic value at 67662/0/1
part_size 732482668
Mac HFS 67662 732550329 732482668
HFS+ magic value at 67679/0/1
part_size 732482668
Mac HFS 67679 732550346 732482668
HFS+ magic value at 67692/0/1
part_size 732482668
Mac HFS 67692 732550359 732482668
HFS+ magic value at 67709/0/1
part_size 732482668
Mac HFS 67709 732550376 732482668
HFS+ magic value at 67724/0/1
part_size 732482668
Mac HFS 67724 732550391 732482668
HFS+ magic value at 67752/0/1
part_size 732482668
Mac HFS 67752 732550419 732482668
HFS+ magic value at 67773/0/1
part_size 732482668
Mac HFS 67773 732550440 732482668
HFS+ magic value at 67783/0/1
part_size 732482668
Mac HFS 67783 732550450 732482668
HFS+ magic value at 67794/0/1
part_size 732482668
Mac HFS 67794 732550461 732482668
HFS+ magic value at 67812/0/1
part_size 732482668
Mac HFS 67812 732550479 732482668
HFS+ magic value at 67850/0/1
part_size 732482668
Mac HFS 67850 732550517 732482668
HFS+ magic value at 67887/0/1
part_size 732482668
Mac HFS 67887 732550554 732482668
HFS+ magic value at 67899/0/1
part_size 732482668
Mac HFS 67899 732550566 732482668
HFS+ magic value at 67922/0/1
part_size 732482668
Mac HFS 67922 732550589 732482668
HFS+ magic value at 67937/0/1
part_size 732482668
Mac HFS 67937 732550604 732482668
HFS+ magic value at 67961/0/1
part_size 732482668
Mac HFS 67961 732550628 732482668
HFS+ magic value at 67972/0/1
part_size 732482668
Mac HFS 67972 732550639 732482668
HFS+ magic value at 67987/0/1
part_size 732482668
Mac HFS 67987 732550654 732482668
HFS+ magic value at 68000/0/1
part_size 732482668
Mac HFS 68000 732550667 732482668
HFS+ magic value at 68013/0/1
part_size 732482668
Mac HFS 68013 732550680 732482668
HFS+ magic value at 68024/0/1
part_size 732482668
Mac HFS 68024 732550691 732482668
HFS+ magic value at 68039/0/1
part_size 732482668
Mac HFS 68039 732550706 732482668
HFS+ magic value at 68052/0/1
part_size 732482668
Mac HFS 68052 732550719 732482668
HFS+ magic value at 68060/0/1
part_size 732482668
Mac HFS 68060 732550727 732482668
HFS+ magic value at 68092/0/1
part_size 732482668
Mac HFS 68092 732550759 732482668
HFS+ magic value at 68112/0/1
part_size 732482668
Mac HFS 68112 732550779 732482668
HFS+ magic value at 68148/0/1
part_size 732482668
Mac HFS 68148 732550815 732482668
HFS+ magic value at 68182/0/1
part_size 732482668
Mac HFS 68182 732550849 732482668
HFS+ magic value at 68482/0/1
part_size 732482668
Mac HFS 68482 732551149 732482668
HFS+ magic value at 68801/0/1
part_size 732482668
Mac HFS 68801 732551468 732482668
HFS+ magic value at 68811/0/1
part_size 732482668
Mac HFS 68811 732551478 732482668
HFS+ magic value at 68829/0/1
part_size 732482668
Mac HFS 68829 732551496 732482668
HFS+ magic value at 68841/0/1
part_size 732482668
Mac HFS 68841 732551508 732482668
HFS+ magic value at 68979/0/1
part_size 732482668
Mac HFS 68979 732551646 732482668
HFS+ magic value at 69199/0/1
part_size 732482668
Mac HFS 69199 732551866 732482668
HFS+ magic value at 69237/0/1
part_size 732482668
Mac HFS 69237 732551904 732482668
HFS+ magic value at 69255/0/1
part_size 732482668
Mac HFS 69255 732551922 732482668
HFS+ magic value at 69269/0/1
part_size 732482668
Mac HFS 69269 732551936 732482668
HFS+ magic value at 69300/0/1
part_size 732482668
Mac HFS 69300 732551967 732482668
HFS+ magic value at 69312/0/1
part_size 732482668
Mac HFS 69312 732551979 732482668
HFS+ magic value at 69328/0/1
part_size 732482668
Mac HFS 69328 732551995 732482668
HFS+ magic value at 69350/0/1
part_size 732482668
Mac HFS 69350 732552017 732482668
HFS+ magic value at 69372/0/1
part_size 732482668
Mac HFS 69372 732552039 732482668
HFS+ magic value at 69386/0/1
part_size 732482668
Mac HFS 69386 732552053 732482668
HFS+ magic value at 69406/0/1
part_size 732482668
Mac HFS 69406 732552073 732482668
HFS+ magic value at 69422/0/1
part_size 732482668
Mac HFS 69422 732552089 732482668
HFS+ magic value at 69444/0/1
part_size 732482668
Mac HFS 69444 732552111 732482668
HFS+ magic value at 69484/0/1
part_size 732482668
Mac HFS 69484 732552151 732482668
HFS+ magic value at 69506/0/1
part_size 732482668
Mac HFS 69506 732552173 732482668
HFS+ magic value at 69516/0/1
part_size 732482668
Mac HFS 69516 732552183 732482668
HFS+ magic value at 69538/0/1
part_size 732482668
Mac HFS 69538 732552205 732482668
HFS+ magic value at 69571/0/1
part_size 732482668
Mac HFS 69571 732552238 732482668
HFS+ magic value at 69593/0/1
part_size 732482668
Mac HFS 69593 732552260 732482668
HFS+ magic value at 69609/0/1
part_size 732482668
Mac HFS 69609 732552276 732482668
HFS+ magic value at 69621/0/1
part_size 732482668
Mac HFS 69621 732552288 732482668
HFS+ magic value at 69647/0/1
part_size 732482668
Mac HFS 69647 732552314 732482668
HFS+ magic value at 69679/0/1
part_size 732482668
Mac HFS 69679 732552346 732482668
HFS+ magic value at 69705/0/1
part_size 732482668
Mac HFS 69705 732552372 732482668
HFS+ magic value at 69723/0/1
part_size 732482668
Mac HFS 69723 732552390 732482668
HFS+ magic value at 69755/0/1
part_size 732482668
Mac HFS 69755 732552422 732482668
HFS+ magic value at 69821/0/1
part_size 732482668
Mac HFS 69821 732552488 732482668
HFS+ magic value at 70361/0/1
part_size 732482668
Mac HFS 70361 732553028 732482668
HFS+ magic value at 71027/0/1
part_size 732482668
Mac HFS 71027 732553694 732482668
HFS+ magic value at 71277/0/1
part_size 732482668
Mac HFS 71277 732553944 732482668
HFS+ magic value at 71931/0/1
part_size 732482668
Mac HFS 71931 732554598 732482668
HFS+ magic value at 71977/0/1
part_size 732482668
Mac HFS 71977 732554644 732482668
HFS+ magic value at 72039/0/1
part_size 732482668
Mac HFS 72039 732554706 732482668
HFS+ magic value at 72500/0/1
part_size 732482668
Mac HFS 72500 732555167 732482668
HFS+ magic value at 72662/0/1
part_size 732482668
Mac HFS 72662 732555329 732482668
HFS+ magic value at 72696/0/1
part_size 732482668
Mac HFS 72696 732555363 732482668
HFS+ magic value at 72728/0/1
part_size 732482668
Mac HFS 72728 732555395 732482668
HFS+ magic value at 72888/0/1
part_size 732482668
Mac HFS 72888 732555555 732482668
HFS+ magic value at 73102/0/1
part_size 732482668
Mac HFS 73102 732555769 732482668
HFS+ magic value at 73650/0/1
part_size 732482668
Mac HFS 73650 732556317 732482668
HFS+ magic value at 74026/0/1
part_size 732482668
Mac HFS 74026 732556693 732482668
HFS+ magic value at 74128/0/1
part_size 732482668
Mac HFS 74128 732556795 732482668
HFS+ magic value at 74136/0/1
part_size 732482668
Mac HFS 74136 732556803 732482668
HFS+ magic value at 74164/0/1
part_size 732482668
Mac HFS 74164 732556831 732482668
HFS+ magic value at 74184/0/1
part_size 732482668
Mac HFS 74184 732556851 732482668
HFS+ magic value at 74207/0/1
part_size 732482668
Mac HFS 74207 732556874 732482668
HFS+ magic value at 74227/0/1
part_size 732482668
Mac HFS 74227 732556894 732482668
HFS+ magic value at 74245/0/1
part_size 732482668
Mac HFS 74245 732556912 732482668
HFS+ magic value at 74265/0/1
part_size 732482668
Mac HFS 74265 732556932 732482668
HFS+ magic value at 74283/0/1
part_size 732482668
Mac HFS 74283 732556950 732482668
HFS+ magic value at 74308/0/1
part_size 732482668
Mac HFS 74308 732556975 732482668
HFS+ magic value at 74326/0/1
part_size 732482668
Mac HFS 74326 732556993 732482668
HFS+ magic value at 74342/0/1
part_size 732482668
Mac HFS 74342 732557009 732482668
HFS+ magic value at 74364/0/1
part_size 732482668
Mac HFS 74364 732557031 732482668
HFS+ magic value at 74394/0/1
part_size 732482668
Mac HFS 74394 732557061 732482668
HFS+ magic value at 74416/0/1
part_size 732482668
Mac HFS 74416 732557083 732482668
HFS+ magic value at 74434/0/1
part_size 732482668
Mac HFS 74434 732557101 732482668
HFS+ magic value at 74459/0/1
part_size 732482668
Mac HFS 74459 732557126 732482668
HFS+ magic value at 74481/0/1
part_size 732482668
Mac HFS 74481 732557148 732482668
HFS+ magic value at 74503/0/1
part_size 732482668
Mac HFS 74503 732557170 732482668
HFS+ magic value at 74529/0/1
part_size 732482668
Mac HFS 74529 732557196 732482668
HFS+ magic value at 74557/0/1
part_size 732482668
Mac HFS 74557 732557224 732482668
HFS+ magic value at 74573/0/1
part_size 732482668
Mac HFS 74573 732557240 732482668
HFS+ magic value at 74587/0/1
part_size 732482668
Mac HFS 74587 732557254 732482668
HFS+ magic value at 74605/0/1
part_size 732482668
Mac HFS 74605 732557272 732482668
HFS+ magic value at 74633/0/1
part_size 732482668
Mac HFS 74633 732557300 732482668
HFS+ magic value at 74665/0/1
part_size 732482668
Mac HFS 74665 732557332 732482668
HFS+ magic value at 74683/0/1
part_size 732482668
Mac HFS 74683 732557350 732482668
HFS+ magic value at 74693/0/1
part_size 732482668
Mac HFS 74693 732557360 732482668
HFS+ magic value at 74716/0/1
part_size 732482668
Mac HFS 74716 732557383 732482668
HFS+ magic value at 74746/0/1
part_size 732482668
Mac HFS 74746 732557413 732482668
HFS+ magic value at 74784/0/1
part_size 732482668
Mac HFS 74784 732557451 732482668
HFS+ magic value at 74806/0/1
part_size 732482668
Mac HFS 74806 732557473 732482668
HFS+ magic value at 74826/0/1
part_size 732482668
Mac HFS 74826 732557493 732482668
HFS+ magic value at 74848/0/1
part_size 732482668
Mac HFS 74848 732557515 732482668
HFS+ magic value at 74870/0/1
part_size 732482668
Mac HFS 74870 732557537 732482668
HFS+ magic value at 74884/0/1
part_size 732482668
Mac HFS 74884 732557551 732482668
HFS+ magic value at 74909/0/1
part_size 732482668
Mac HFS 74909 732557576 732482668
HFS+ magic value at 74929/0/1
part_size 732482668
Mac HFS 74929 732557596 732482668
HFS+ magic value at 74945/0/1
part_size 732482668
Mac HFS 74945 732557612 732482668
HFS+ magic value at 74961/0/1
part_size 732482668
Mac HFS 74961 732557628 732482668
HFS+ magic value at 74973/0/1
part_size 732482668
Mac HFS 74973 732557640 732482668
HFS+ magic value at 74991/0/1
part_size 732482668
Mac HFS 74991 732557658 732482668
HFS+ magic value at 75005/0/1
part_size 732482668
Mac HFS 75005 732557672 732482668
HFS+ magic value at 75018/0/1
part_size 732482668
Mac HFS 75018 732557685 732482668
HFS+ magic value at 75040/0/1
part_size 732482668
Mac HFS 75040 732557707 732482668
HFS+ magic value at 75056/0/1
part_size 732482668
Mac HFS 75056 732557723 732482668
HFS+ magic value at 75082/0/1
part_size 732482668
Mac HFS 75082 732557749 732482668
HFS+ magic value at 75106/0/1
part_size 732482668
Mac HFS 75106 732557773 732482668
HFS+ magic value at 75124/0/1
part_size 732482668
Mac HFS 75124 732557791 732482668
HFS+ magic value at 75145/0/1
part_size 732482668
Mac HFS 75145 732557812 732482668
HFS+ magic value at 75169/0/1
part_size 732482668
Mac HFS 75169 732557836 732482668
HFS+ magic value at 75195/0/1
part_size 732482668
Mac HFS 75195 732557862 732482668
HFS+ magic value at 75219/0/1
part_size 732482668
Mac HFS 75219 732557886 732482668
HFS+ magic value at 75244/0/1
part_size 732482668
Mac HFS 75244 732557911 732482668
HFS+ magic value at 75258/0/1
part_size 732482668
Mac HFS 75258 732557925 732482668
HFS+ magic value at 75287/0/1
part_size 732482668
Mac HFS 75287 732557954 732482668
HFS+ magic value at 75329/0/1
part_size 732482668
Mac HFS 75329 732557996 732482668
HFS+ magic value at 75363/0/1
part_size 732482668
Mac HFS 75363 732558030 732482668
HFS+ magic value at 75383/0/1
part_size 732482668
Mac HFS 75383 732558050 732482668
HFS+ magic value at 75395/0/1
part_size 732482668
Mac HFS 75395 732558062 732482668
HFS+ magic value at 75425/0/1
part_size 732482668
Mac HFS 75425 732558092 732482668
HFS+ magic value at 75450/0/1
part_size 732482668
Mac HFS 75450 732558117 732482668
HFS+ magic value at 75478/0/1
part_size 732482668
Mac HFS 75478 732558145 732482668
HFS+ magic value at 75502/0/1
part_size 732482668
Mac HFS 75502 732558169 732482668
HFS+ magic value at 75528/0/1
part_size 732482668
Mac HFS 75528 732558195 732482668
HFS+ magic value at 75552/0/1
part_size 732482668
Mac HFS 75552 732558219 732482668
HFS+ magic value at 75574/0/1
part_size 732482668
Mac HFS 75574 732558241 732482668
HFS+ magic value at 75602/0/1
part_size 732482668
Mac HFS 75602 732558269 732482668
HFS+ magic value at 75632/0/1
part_size 732482668
Mac HFS 75632 732558299 732482668
HFS+ magic value at 75650/0/1
part_size 732482668
Mac HFS 75650 732558317 732482668
HFS+ magic value at 75670/0/1
part_size 732482668
Mac HFS 75670 732558337 732482668
HFS+ magic value at 75704/0/1
part_size 732482668
Mac HFS 75704 732558371 732482668
HFS+ magic value at 75722/0/1
part_size 732482668
Mac HFS 75722 732558389 732482668
HFS+ magic value at 75748/0/1
part_size 732482668
Mac HFS 75748 732558415 732482668
HFS+ magic value at 75774/0/1
part_size 732482668
Mac HFS 75774 732558441 732482668
HFS+ magic value at 75796/0/1
part_size 732482668
Mac HFS 75796 732558463 732482668
HFS+ magic value at 75818/0/1
part_size 732482668
Mac HFS 75818 732558485 732482668
HFS+ magic value at 75846/0/1
part_size 732482668
Mac HFS 75846 732558513 732482668
HFS+ magic value at 75874/0/1
part_size 732482668
Mac HFS 75874 732558541 732482668
HFS+ magic value at 75888/0/1
part_size 732482668
Mac HFS 75888 732558555 732482668
HFS+ magic value at 75896/0/1
part_size 732482668
Mac HFS 75896 732558563 732482668
HFS+ magic value at 75918/0/1
part_size 732482668
Mac HFS 75918 732558585 732482668
HFS+ magic value at 75940/0/1
part_size 732482668
Mac HFS 75940 732558607 732482668
HFS+ magic value at 75960/0/1
part_size 732482668
Mac HFS 75960 732558627 732482668
HFS+ magic value at 75976/0/1
part_size 732482668
Mac HFS 75976 732558643 732482668
HFS+ magic value at 75992/0/1
part_size 732482668
Mac HFS 75992 732558659 732482668
HFS+ magic value at 76004/0/1
part_size 732482668
Mac HFS 76004 732558671 732482668
Buffer can't store more than 200 lines.
HFS+ magic value at 76033/0/1
part_size 732482668
Mac HFS 76033 732558700 732482668
HFS+ magic value at 76077/0/1
part_size 732482668
Mac HFS 76077 732558744 732482668
HFS+ magic value at 76093/0/1
part_size 732482668
Mac HFS 76093 732558760 732482668
HFS+ magic value at 76115/0/1
part_size 732482668
Mac HFS 76115 732558782 732482668
HFS+ magic value at 76129/0/1
part_size 732482668
Mac HFS 76129 732558796 732482668
HFS+ magic value at 76157/0/1
part_size 732482668
Mac HFS 76157 732558824 732482668
HFS+ magic value at 76171/0/1
part_size 732482668
Mac HFS 76171 732558838 732482668
HFS+ magic value at 76200/0/1
part_size 732482668
Mac HFS 76200 732558867 732482668
HFS+ magic value at 76214/0/1
part_size 732482668
Mac HFS 76214 732558881 732482668
HFS+ magic value at 76246/0/1
part_size 732482668
Mac HFS 76246 732558913 732482668
HFS+ magic value at 76262/0/1
part_size 732482668
Mac HFS 76262 732558929 732482668
HFS+ magic value at 76290/0/1
part_size 732482668
Mac HFS 76290 732558957 732482668
part_size 732457066
HFS+ magic value at 87996/0/1
part_size 732457066
Mac HFS 87996 732545061 732457066
HFS+ magic value at 88006/0/1
part_size 732457066
Mac HFS 88006 732545071 732457066
HFS+ magic value at 88026/0/1
part_size 732457066
Mac HFS 88026 732545091 732457066
HFS+ magic value at 88032/0/1
part_size 732457066
Mac HFS 88032 732545097 732457066
HFS+ magic value at 88040/0/1
part_size 732457066
Mac HFS 88040 732545105 732457066
HFS+ magic value at 88054/0/1
part_size 732457066
Mac HFS 88054 732545119 732457066
HFS+ magic value at 88080/0/1
part_size 732457066
Mac HFS 88080 732545145 732457066
HFS+ magic value at 88094/0/1
part_size 732457066
Mac HFS 88094 732545159 732457066
HFS+ magic value at 88113/0/1
part_size 732457066
Mac HFS 88113 732545178 732457066
HFS+ magic value at 88123/0/1
part_size 732457066
Mac HFS 88123 732545188 732457066
HFS+ magic value at 88135/0/1
part_size 732457066
Mac HFS 88135 732545200 732457066
HFS+ magic value at 88145/0/1
part_size 732457066
Mac HFS 88145 732545210 732457066
HFS+ magic value at 88157/0/1
part_size 732457066
Mac HFS 88157 732545222 732457066
HFS+ magic value at 88173/0/1
part_size 732457066
Mac HFS 88173 732545238 732457066
HFS+ magic value at 88193/0/1
part_size 732457066
Mac HFS 88193 732545258 732457066
HFS+ magic value at 88215/0/1
part_size 732457066
Mac HFS 88215 732545280 732457066
HFS+ magic value at 88229/0/1
part_size 732457066
Mac HFS 88229 732545294 732457066
HFS+ magic value at 88246/0/1
part_size 732457066
Mac HFS 88246 732545311 732457066
HFS+ magic value at 88272/0/1
part_size 732457066
Mac HFS 88272 732545337 732457066
HFS+ magic value at 88296/0/1
part_size 732457066
Mac HFS 88296 732545361 732457066
HFS+ magic value at 88315/0/1
part_size 732457066
Mac HFS 88315 732545380 732457066
HFS+ magic value at 88331/0/1
part_size 732457066
Mac HFS 88331 732545396 732457066
HFS+ magic value at 88347/0/1
part_size 732457066
Mac HFS 88347 732545412 732457066
HFS+ magic value at 88355/0/1
part_size 732457066
Mac HFS 88355 732545420 732457066
HFS+ magic value at 88367/0/1
part_size 732457066
Mac HFS 88367 732545432 732457066
HFS+ magic value at 88385/0/1
part_size 732457066
Mac HFS 88385 732545450 732457066
HFS+ magic value at 88404/0/1
part_size 732457066
Mac HFS 88404 732545469 732457066
HFS+ magic value at 88422/0/1
part_size 732457066
Mac HFS 88422 732545487 732457066
HFS+ magic value at 88439/0/1
part_size 732457066
Mac HFS 88439 732545504 732457066
HFS+ magic value at 88465/0/1
part_size 732457066
Mac HFS 88465 732545530 732457066
HFS+ magic value at 88486/0/1
part_size 732457066
Mac HFS 88486 732545551 732457066
HFS+ magic value at 88502/0/1
part_size 732457066
Mac HFS 88502 732545567 732457066
HFS+ magic value at 88528/0/1
part_size 732457066
Mac HFS 88528 732545593 732457066
HFS+ magic value at 88542/0/1
part_size 732457066
Mac HFS 88542 732545607 732457066
HFS+ magic value at 88562/0/1
part_size 732457066
Mac HFS 88562 732545627 732457066
HFS+ magic value at 88586/0/1
part_size 732457066
Mac HFS 88586 732545651 732457066
HFS+ magic value at 88604/0/1
part_size 732457066
Mac HFS 88604 732545669 732457066
HFS+ magic value at 88625/0/1
part_size 732457066
Mac HFS 88625 732545690 732457066
HFS+ magic value at 88641/0/1
part_size 732457066
Mac HFS 88641 732545706 732457066
HFS+ magic value at 88653/0/1
part_size 732457066
Mac HFS 88653 732545718 732457066
HFS+ magic value at 88669/0/1
part_size 732457066
Mac HFS 88669 732545734 732457066
HFS+ magic value at 88696/0/1
part_size 732457066
Mac HFS 88696 732545761 732457066
HFS+ magic value at 88712/0/1
part_size 732457066
Mac HFS 88712 732545777 732457066
HFS+ magic value at 88730/0/1
part_size 732457066
Mac HFS 88730 732545795 732457066
HFS+ magic value at 88744/0/1
part_size 732457066
Mac HFS 88744 732545809 732457066
HFS+ magic value at 88760/0/1
part_size 732457066
Mac HFS 88760 732545825 732457066
HFS+ magic value at 88785/0/1
part_size 732457066
Mac HFS 88785 732545850 732457066
HFS+ magic value at 88807/0/1
part_size 732457066
Mac HFS 88807 732545872 732457066
HFS+ magic value at 88817/0/1
part_size 732457066
Mac HFS 88817 732545882 732457066
HFS+ magic value at 88825/0/1
part_size 732457066
Mac HFS 88825 732545890 732457066
HFS+ magic value at 88844/0/1
part_size 732457066
Mac HFS 88844 732545909 732457066
HFS+ magic value at 88860/0/1
part_size 732457066
Mac HFS 88860 732545925 732457066
HFS+ magic value at 88870/0/1
part_size 732457066
Mac HFS 88870 732545935 732457066
HFS+ magic value at 88878/0/1
part_size 732457066
Mac HFS 88878 732545943 732457066
HFS+ magic value at 88890/0/1
part_size 732457066
Mac HFS 88890 732545955 732457066
HFS+ magic value at 88904/0/1
part_size 732457066
Mac HFS 88904 732545969 732457066
HFS+ magic value at 88916/0/1
part_size 732457066
Mac HFS 88916 732545981 732457066
HFS+ magic value at 88928/0/1
part_size 732457066
Mac HFS 88928 732545993 732457066
HFS+ magic value at 88940/0/1
part_size 732457066
Mac HFS 88940 732546005 732457066
HFS+ magic value at 88954/0/1
part_size 732457066
Mac HFS 88954 732546019 732457066
HFS+ magic value at 88973/0/1
part_size 732457066
Mac HFS 88973 732546038 732457066
HFS+ magic value at 88985/0/1
part_size 732457066
Mac HFS 88985 732546050 732457066
HFS+ magic value at 88989/0/1
part_size 732457066
Mac HFS 88989 732546054 732457066
HFS+ magic value at 89020/0/1
part_size 732457066
Mac HFS 89020 732546085 732457066
HFS+ magic value at 89046/0/1
part_size 732457066
Mac HFS 89046 732546111 732457066
HFS+ magic value at 89066/0/1
part_size 732457066
Mac HFS 89066 732546131 732457066
HFS+ magic value at 89082/0/1
part_size 732457066
Mac HFS 89082 732546147 732457066
HFS+ magic value at 89096/0/1
part_size 732457066
Mac HFS 89096 732546161 732457066
HFS+ magic value at 89123/0/1
part_size 732457066
Mac HFS 89123 732546188 732457066
HFS+ magic value at 89139/0/1
part_size 732457066
Mac HFS 89139 732546204 732457066
HFS+ magic value at 89151/0/1
part_size 732457066
Mac HFS 89151 732546216 732457066
HFS+ magic value at 89161/0/1
part_size 732457066
Mac HFS 89161 732546226 732457066
HFS+ magic value at 89191/0/1
part_size 732457066
Mac HFS 89191 732546256 732457066
HFS+ magic value at 89203/0/1
part_size 732457066
Mac HFS 89203 732546268 732457066
HFS+ magic value at 89216/0/1
part_size 732457066
Mac HFS 89216 732546281 732457066
HFS+ magic value at 89264/0/1
part_size 732457066
Mac HFS 89264 732546329 732457066
HFS+ magic value at 89281/0/1
part_size 732457066
Mac HFS 89281 732546346 732457066
HFS+ magic value at 89307/0/1
part_size 732457066
Mac HFS 89307 732546372 732457066
HFS+ magic value at 89317/0/1
part_size 732457066
Mac HFS 89317 732546382 732457066
HFS+ magic value at 89330/0/1
part_size 732457066
Mac HFS 89330 732546395 732457066
HFS+ magic value at 89343/0/1
part_size 732457066
Mac HFS 89343 732546408 732457066
HFS+ magic value at 89361/0/1
part_size 732457066
Mac HFS 89361 732546426 732457066
HFS+ magic value at 89373/0/1
part_size 732457066
Mac HFS 89373 732546438 732457066
HFS+ magic value at 89393/0/1
part_size 732457066
Mac HFS 89393 732546458 732457066
HFS+ magic value at 89403/0/1
part_size 732457066
Mac HFS 89403 732546468 732457066
HFS+ magic value at 89417/0/1
part_size 732457066
Mac HFS 89417 732546482 732457066
HFS+ magic value at 89436/0/1
part_size 732457066
Mac HFS 89436 732546501 732457066
HFS+ magic value at 89452/0/1
part_size 732457066
Mac HFS 89452 732546517 732457066
HFS+ magic value at 89464/0/1
part_size 732457066
Mac HFS 89464 732546529 732457066
HFS+ magic value at 89482/0/1
part_size 732457066
Mac HFS 89482 732546547 732457066
HFS+ magic value at 89499/0/1
part_size 732457066
Mac HFS 89499 732546564 732457066
HFS+ magic value at 89521/0/1
part_size 732457066
Mac HFS 89521 732546586 732457066
HFS+ magic value at 89538/0/1
part_size 732457066
Mac HFS 89538 732546603 732457066
HFS+ magic value at 89564/0/1
part_size 732457066
Mac HFS 89564 732546629 732457066
HFS+ magic value at 89585/0/1
part_size 732457066
Mac HFS 89585 732546650 732457066
HFS+ magic value at 89603/0/1
part_size 732457066
Mac HFS 89603 732546668 732457066
HFS+ magic value at 89631/0/1
part_size 732457066
Mac HFS 89631 732546696 732457066
HFS+ magic value at 89645/0/1
part_size 732457066
Mac HFS 89645 732546710 732457066
HFS+ magic value at 89661/0/1
part_size 732457066
Mac HFS 89661 732546726 732457066
HFS+ magic value at 89691/0/1
part_size 732457066
Mac HFS 89691 732546756 732457066
(continued)
ac2334
#5 Post by ac2334 »
HFS+ magic value at 89709/0/1
part_size 732457066
Mac HFS 89709 732546774 732457066
HFS+ magic value at 89730/0/1
part_size 732457066
Mac HFS 89730 732546795 732457066
HFS+ magic value at 89746/0/1
part_size 732457066
Mac HFS 89746 732546811 732457066
HFS+ magic value at 89758/0/1
part_size 732457066
Mac HFS 89758 732546823 732457066
HFS+ magic value at 89774/0/1
part_size 732457066
Mac HFS 89774 732546839 732457066
HFS+ magic value at 89801/0/1
part_size 732457066
Mac HFS 89801 732546866 732457066
HFS+ magic value at 89817/0/1
part_size 732457066
Mac HFS 89817 732546882 732457066
HFS+ magic value at 89835/0/1
part_size 732457066
Mac HFS 89835 732546900 732457066
HFS+ magic value at 89879/0/1
part_size 732457066
Mac HFS 89879 732546944 732457066
HFS+ magic value at 89897/0/1
part_size 732457066
Mac HFS 89897 732546962 732457066
HFS+ magic value at 89909/0/1
part_size 732457066
Mac HFS 89909 732546974 732457066
HFS+ magic value at 89921/0/1
part_size 732457066
Mac HFS 89921 732546986 732457066
HFS+ magic value at 89933/0/1
part_size 732457066
Mac HFS 89933 732546998 732457066
HFS+ magic value at 89951/0/1
part_size 732457066
Mac HFS 89951 732547016 732457066
HFS+ magic value at 89975/0/1
part_size 732457066
Mac HFS 89975 732547040 732457066
HFS+ magic value at 89992/0/1
part_size 732457066
Mac HFS 89992 732547057 732457066
HFS+ magic value at 90005/0/1
part_size 732457066
Mac HFS 90005 732547070 732457066
HFS+ magic value at 90018/0/1
part_size 732457066
Mac HFS 90018 732547083 732457066
HFS+ magic value at 90031/0/1
part_size 732457066
Mac HFS 90031 732547096 732457066
HFS+ magic value at 90041/0/1
part_size 732457066
Mac HFS 90041 732547106 732457066
HFS+ magic value at 90053/0/1
part_size 732457066
Mac HFS 90053 732547118 732457066
HFS+ magic value at 90068/0/1
part_size 732457066
Mac HFS 90068 732547133 732457066
HFS+ magic value at 90086/0/1
part_size 732457066
Mac HFS 90086 732547151 732457066
HFS+ magic value at 90100/0/1
part_size 732457066
Mac HFS 90100 732547165 732457066
HFS+ magic value at 90115/0/1
part_size 732457066
Mac HFS 90115 732547180 732457066
HFS+ magic value at 90123/0/1
part_size 732457066
Mac HFS 90123 732547188 732457066
HFS+ magic value at 90141/0/1
part_size 732457066
Mac HFS 90141 732547206 732457066
HFS+ magic value at 90155/0/1
part_size 732457066
Mac HFS 90155 732547220 732457066
HFS+ magic value at 90175/0/1
part_size 732457066
Mac HFS 90175 732547240 732457066
HFS+ magic value at 90193/0/1
part_size 732457066
Mac HFS 90193 732547258 732457066
HFS+ magic value at 90207/0/1
part_size 732457066
Mac HFS 90207 732547272 732457066
HFS+ magic value at 90226/0/1
part_size 732457066
Mac HFS 90226 732547291 732457066
HFS+ magic value at 90242/0/1
part_size 732457066
Mac HFS 90242 732547307 732457066
HFS+ magic value at 90254/0/1
part_size 732457066
Mac HFS 90254 732547319 732457066
HFS+ magic value at 90272/0/1
part_size 732457066
Mac HFS 90272 732547337 732457066
HFS+ magic value at 90289/0/1
part_size 732457066
Mac HFS 90289 732547354 732457066
HFS+ magic value at 90313/0/1
part_size 732457066
Mac HFS 90313 732547378 732457066
HFS+ magic value at 90330/0/1
part_size 732457066
Mac HFS 90330 732547395 732457066
HFS+ magic value at 90354/0/1
part_size 732457066
Mac HFS 90354 732547419 732457066
HFS+ magic value at 90375/0/1
part_size 732457066
Mac HFS 90375 732547440 732457066
HFS+ magic value at 90393/0/1
part_size 732457066
Mac HFS 90393 732547458 732457066
HFS+ magic value at 90421/0/1
part_size 732457066
Mac HFS 90421 732547486 732457066
HFS+ magic value at 90435/0/1
part_size 732457066
Mac HFS 90435 732547500 732457066
HFS+ magic value at 90451/0/1
part_size 732457066
Mac HFS 90451 732547516 732457066
HFS+ magic value at 90485/0/1
part_size 732457066
Mac HFS 90485 732547550 732457066
HFS+ magic value at 90503/0/1
part_size 732457066
Mac HFS 90503 732547568 732457066
HFS+ magic value at 90524/0/1
part_size 732457066
Mac HFS 90524 732547589 732457066
HFS+ magic value at 90540/0/1
part_size 732457066
Mac HFS 90540 732547605 732457066
HFS+ magic value at 90552/0/1
part_size 732457066
Mac HFS 90552 732547617 732457066
HFS+ magic value at 90568/0/1
part_size 732457066
Mac HFS 90568 732547633 732457066
HFS+ magic value at 90595/0/1
part_size 732457066
Mac HFS 90595 732547660 732457066
HFS+ magic value at 90611/0/1
part_size 732457066
Mac HFS 90611 732547676 732457066
HFS+ magic value at 90629/0/1
part_size 732457066
Mac HFS 90629 732547694 732457066
HFS+ magic value at 90653/0/1
part_size 732457066
Mac HFS 90653 732547718 732457066
HFS+ magic value at 90671/0/1
part_size 732457066
Mac HFS 90671 732547736 732457066
HFS+ magic value at 90683/0/1
part_size 732457066
Mac HFS 90683 732547748 732457066
HFS+ magic value at 90695/0/1
part_size 732457066
Mac HFS 90695 732547760 732457066
HFS+ magic value at 90721/0/1
part_size 732457066
Mac HFS 90721 732547786 732457066
HFS+ magic value at 90739/0/1
part_size 732457066
Mac HFS 90739 732547804 732457066
HFS+ magic value at 90754/0/1
part_size 732457066
Mac HFS 90754 732547819 732457066
HFS+ magic value at 90762/0/1
part_size 732457066
Mac HFS 90762 732547827 732457066
HFS+ magic value at 90779/0/1
part_size 732457066
Mac HFS 90779 732547844 732457066
HFS+ magic value at 90791/0/1
part_size 732457066
Mac HFS 90791 732547856 732457066
HFS+ magic value at 90807/0/1
part_size 732457066
Mac HFS 90807 732547872 732457066
HFS+ magic value at 90813/0/1
part_size 732457066
Mac HFS 90813 732547878 732457066
HFS+ magic value at 90835/0/1
part_size 732457066
Mac HFS 90835 732547900 732457066
HFS+ magic value at 90871/0/1
part_size 732457066
Mac HFS 90871 732547936 732457066
HFS+ magic value at 90899/0/1
part_size 732457066
Mac HFS 90899 732547964 732457066
HFS+ magic value at 90911/0/1
part_size 732457066
Mac HFS 90911 732547976 732457066
HFS+ magic value at 90927/0/1
part_size 732457066
Mac HFS 90927 732547992 732457066
HFS+ magic value at 90953/0/1
part_size 732457066
Mac HFS 90953 732548018 732457066
HFS+ magic value at 90973/0/1
part_size 732457066
Mac HFS 90973 732548038 732457066
HFS+ magic value at 90991/0/1
part_size 732457066
Mac HFS 90991 732548056 732457066
HFS+ magic value at 91005/0/1
part_size 732457066
Mac HFS 91005 732548070 732457066
HFS+ magic value at 91030/0/1
part_size 732457066
Mac HFS 91030 732548095 732457066
HFS+ magic value at 91068/0/1
part_size 732457066
Mac HFS 91068 732548133 732457066
HFS+ magic value at 91086/0/1
part_size 732457066
Mac HFS 91086 732548151 732457066
HFS+ magic value at 91103/0/1
part_size 732457066
Mac HFS 91103 732548168 732457066
HFS+ magic value at 91117/0/1
part_size 732457066
Mac HFS 91117 732548182 732457066
HFS+ magic value at 91131/0/1
part_size 732457066
Mac HFS 91131 732548196 732457066
HFS+ magic value at 91150/0/1
part_size 732457066
Mac HFS 91150 732548215 732457066
HFS+ magic value at 91166/0/1
part_size 732457066
Mac HFS 91166 732548231 732457066
HFS+ magic value at 91170/0/1
part_size 732457066
Mac HFS 91170 732548235 732457066
HFS+ magic value at 91205/0/1
part_size 732457066
Mac HFS 91205 732548270 732457066
HFS+ magic value at 91229/0/1
part_size 732457066
Mac HFS 91229 732548294 732457066
HFS+ magic value at 91249/0/1
part_size 732457066
Mac HFS 91249 732548314 732457066
HFS+ magic value at 91261/0/1
part_size 732457066
Mac HFS 91261 732548326 732457066
HFS+ magic value at 91275/0/1
part_size 732457066
Mac HFS 91275 732548340 732457066
HFS+ magic value at 91300/0/1
part_size 732457066
Mac HFS 91300 732548365 732457066
HFS+ magic value at 91312/0/1
part_size 732457066
Mac HFS 91312 732548377 732457066
HFS+ magic value at 91330/0/1
part_size 732457066
Mac HFS 91330 732548395 732457066
HFS+ magic value at 91342/0/1
part_size 732457066
Mac HFS 91342 732548407 732457066
HFS+ magic value at 91359/0/1
part_size 732457066
Mac HFS 91359 732548424 732457066
HFS+ magic value at 91375/0/1
part_size 732457066
Mac HFS 91375 732548440 732457066
HFS+ magic value at 91395/0/1
part_size 732457066
Mac HFS 91395 732548460 732457066
HFS+ magic value at 91407/0/1
part_size 732457066
Mac HFS 91407 732548472 732457066
HFS+ magic value at 91421/0/1
part_size 732457066
Mac HFS 91421 732548486 732457066
HFS+ magic value at 91440/0/1
part_size 732457066
Mac HFS 91440 732548505 732457066
HFS+ magic value at 91458/0/1
part_size 732457066
Mac HFS 91458 732548523 732457066
HFS+ magic value at 91468/0/1
part_size 732457066
Mac HFS 91468 732548533 732457066
HFS+ magic value at 91482/0/1
part_size 732457066
Mac HFS 91482 732548547 732457066
HFS+ magic value at 91494/0/1
part_size 732457066
Mac HFS 91494 732548559 732457066
HFS+ magic value at 91512/0/1
part_size 732457066
Mac HFS 91512 732548577 732457066
HFS+ magic value at 91531/0/1
part_size 732457066
Mac HFS 91531 732548596 732457066
HFS+ magic value at 91553/0/1
part_size 732457066
Mac HFS 91553 732548618 732457066
HFS+ magic value at 91570/0/1
part_size 732457066
Mac HFS 91570 732548635 732457066
HFS+ magic value at 91600/0/1
part_size 732457066
Mac HFS 91600 732548665 732457066
HFS+ magic value at 91621/0/1
part_size 732457066
Mac HFS 91621 732548686 732457066
HFS+ magic value at 91639/0/1
part_size 732457066
Mac HFS 91639 732548704 732457066
HFS+ magic value at 91675/0/1
part_size 732457066
Mac HFS 91675 732548740 732457066
HFS+ magic value at 91689/0/1
part_size 732457066
Mac HFS 91689 732548754 732457066
HFS+ magic value at 91705/0/1
part_size 732457066
Mac HFS 91705 732548770 732457066
HFS+ magic value at 91745/0/1
part_size 732457066
Mac HFS 91745 732548810 732457066
HFS+ magic value at 91763/0/1
part_size 732457066
Mac HFS 91763 732548828 732457066
HFS+ magic value at 91784/0/1
part_size 732457066
Mac HFS 91784 732548849 732457066
HFS+ magic value at 91800/0/1
part_size 732457066
Mac HFS 91800 732548865 732457066
HFS+ magic value at 91812/0/1
part_size 732457066
Mac HFS 91812 732548877 732457066
HFS+ magic value at 91828/0/1
part_size 732457066
Mac HFS 91828 732548893 732457066
HFS+ magic value at 91855/0/1
part_size 732457066
Mac HFS 91855 732548920 732457066
HFS+ magic value at 91871/0/1
part_size 732457066
Mac HFS 91871 732548936 732457066
HFS+ magic value at 91889/0/1
part_size 732457066
Mac HFS 91889 732548954 732457066
HFS+ magic value at 91903/0/1
part_size 732457066
Mac HFS 91903 732548968 732457066
HFS+ magic value at 91922/0/1
part_size 732457066
Mac HFS 91922 732548987 732457066
HFS+ magic value at 91938/0/1
part_size 732457066
Mac HFS 91938 732549003 732457066
HFS+ magic value at 91958/0/1
part_size 732457066
Mac HFS 91958 732549023 732457066
HFS+ magic value at 91962/0/1
part_size 732457066
Mac HFS 91962 732549027 732457066
HFS+ magic value at 91991/0/1
part_size 732457066
Mac HFS 91991 732549056 732457066
HFS+ magic value at 92001/0/1
part_size 732457066
Mac HFS 92001 732549066 732457066
HFS+ magic value at 92019/0/1
part_size 732457066
Mac HFS 92019 732549084 732457066
HFS+ magic value at 92031/0/1
part_size 732457066
Mac HFS 92031 732549096 732457066
HFS+ magic value at 92043/0/1
part_size 732457066
Mac HFS 92043 732549108 732457066
HFS+ magic value at 92051/0/1
part_size 732457066
Mac HFS 92051 732549116 732457066
HFS+ magic value at 92070/0/1
part_size 732457066
Mac HFS 92070 732549135 732457066
HFS+ magic value at 92086/0/1
part_size 732457066
Mac HFS 92086 732549151 732457066
HFS+ magic value at 92096/0/1
part_size 732457066
Mac HFS 92096 732549161 732457066
HFS+ magic value at 92117
ac2334
#6 Post by ac2334 »
This is what I see when I stopped deeper search:
ac2334
#7 Post by ac2334 »
I have provided some additional information, could I please have some help to advise the next step?
Thank you :D
ac2334
#8 Post by ac2334 »
Some help please
