Hello people!
(First of all, sorry for my somewhat incorrect english!)
So recently i tried to copy a file onto my 2tbb seagate external drive, as i was copying - it came up with a error that something had happend so the file could not be copied. As i tried to make a secure unplug, it said it could not be peformed as the drive was still in use. In my frustration, i just unpluged it. Dang..
After i put it back into my usb, the drive came up as a Local drive :G, instead of the orginal name "Blue" (that i named it)
When i try to acces it, it says curropted files and the drive cannot be accesable.
The drive changed in the diskmanagment to RAW.
I could use the drive on my MAC and PC - so i guess it was EXfat.
Im using Windows10.
I tried Recuve, where it found 195xxx files. After trying to recover with it, the files that came up was like 10% and the files that got saved, was weird stuff from games and sough that i dont really need.
My hdd has been used for storage from older computer. So i know there is also alot of files that i dont really need.
The pictures/video files is the most important.
I found out about Testdisk and Photorec, but im not sure how exactaly what to do from here. I have the programs downloaded. But want to make sure im doing everything right.
i hope i'm posting in the right forum and i hope one of you can help me! Thanks.
External drive - Stopped working/Damaged files
simonstrandskov
Re: External drive - Stopped working/Damaged files
You can always sort the recovered files by PhotoRec or another utility and only keep your jpg. It's possible to sort the jpg by date/time as explained in https://www.cgsecurity.org/testdisk.pdf
Have you try "cmd" (right click run as administrator) and "chkdsk /f g:" (replace d: by the correct drive letter) ? What is the result ?
