I cannot access my Adata CH94 external usb harddisk anymore. When I try to access it, my pc asks to format the disk (tried in more pc's).
I have run the testdisk tool and attached the logfile to this message.
I have some questions. The tool finds a backup for my partition after Deeper Search . Should I then Load this backup? I am able to view my directories. Is it better to copy the files first before I load the backup?
Maybe I can find an example somewhere how to do this. Please point me to this.
Thank you for your help. I will try to write a tutorial when I am able to fix this.
Tinka
*edit*
I don't seem to be able to upload the testdisklog. Here are the important parts (I think)
Mon Jul 9 21:11:23 2012
OS: Windows Vista (6002) SP2
Compilation date: 2012-07-05T08:08:04
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=3980394496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=3980394496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=47188399104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=21225275392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=251656142848
filewin32_getfilesize(\\.\F:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=640132383744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=3976200192
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200BEVT-22ZCT0, S/N:2020202057202d44585737453830484b34463631, FW:11.01A11
Disk /dev/sdb - 3980 MB / 3796 MiB - CHS 483 255 63, sector size=512 - Generic- Multi-Card, FW:1.00
Disk /dev/sdc - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - ADATA HDD CH94
Disk /dev/sdc - 640 GB / 596 GiB - ADATA HDD CH94
Analyse Disk /dev/sdc - 640 GB / 596 GiB - CHS 77825 255 63
test_FAT()
1 * FAT32 LBA 0 1 1 77824 254 63 1250258562
sector_size 0
cluster_size 0
reserved 10762
fats 0
dir_entries 0
sectors 16128
media 00
fat_length 512
secs_track 0
heads 0
hidden 3808428032
total_sect 1250258562
Invalid FAT boot sector
file_pread(6,2,buffer,1250265088(77825/102/38)) lseek err Invalid argument
file_pread(6,1,buffer,1250265088(77825/102/38)) lseek err Invalid argument
file_pread(6,7,buffer,1250265089(77825/102/39)) lseek err Invalid argument
file_pread(6,8,buffer,1250265096(77825/102/46)) lseek err Invalid argument
file_pread(6,3,buffer,1250265104(77825/102/54)) lseek err Invalid argument
file_pread(6,3,buffer,1250265151(77825/103/38)) lseek err Invalid argument
file_pread(6,8,buffer,1250265167(77825/103/54)) lseek err Invalid argument
file_pread(6,11,buffer,1250265214(77825/104/38)) lseek err Invalid argument
file_pread(6,2,buffer,1250267136(77825/135/7)) lseek err Invalid argument
FAT32 at 0/1/7
FAT1 : 32-152614
FAT2 : 152615-305197
start_rootdir : 305198 root cluster : 2
Data : 305198-1250258541
sectors : 1250258562
cluster_size : 64
no_of_cluster : 19530521 (2 - 19530522)
fat_length 152583 calculated 152583
heads/cylinder 1 (FAT) != 255 (HD)
sect/track 48519 (FAT) != 63 (HD)
FAT32 at 0/1/7
FAT32 0 1 1 140 254 15 2265054
FAT found using backup sector!, 1159 MB / 1105 MiB
file_pread(6,1,buffer,1250265087(77825/102/37)) lseek err Invalid argument
* FAT32 0 1 1 140 254 63 2265102
FAT found using backup sector!, 1159 MB / 1106 MiB
dir_partition inode=0
dir_partition inode=15138818
FAT: cluster=15138818(0xe70002), pos=969189485
Directory /backup_studeerkamer2
dir_partition inode=8006141
FAT: cluster=8006141(0x7a29fd), pos=512698157
Directory /backup_medion
FAT: cluster=2(0x2), pos=305261
FAT: cluster=512(0x200), pos=337901
FAT: cluster=513(0x201), pos=337965
FAT: cluster=514(0x202), pos=338029
FAT: cluster=515(0x203), pos=338093
FAT: cluster=516(0x204), pos=338157
FAT: cluster=517(0x205), pos=338221
FAT: cluster=518(0x206), pos=338285
FAT: cluster=519(0x207), pos=338349
FAT: cluster=520(0x208), pos=338413
FAT: cluster=521(0x209), pos=338477
FAT: cluster=522(0x20a), pos=338541
FAT: cluster=523(0x20b), pos=338605
FAT: cluster=524(0x20c), pos=338669
FAT: cluster=525(0x20d), pos=338733
FAT: cluster=526(0x20e), pos=338797
FAT: cluster=527(0x20f), pos=338861
FAT: cluster=528(0x210), pos=338925
FAT: cluster=529(0x211), pos=338989
FAT: cluster=530(0x212), pos=339053
FAT: cluster=531(0x213), pos=339117
FAT: cluster=532(0x214), pos=339181
FAT: cluster=533(0x215), pos=339245
FAT: cluster=534(0x216), pos=339309
FAT: cluster=535(0x217), pos=339373
FAT: cluster=536(0x218), pos=339437
FAT: cluster=537(0x219), pos=339501
FAT: cluster=538(0x21a), pos=339565
FAT: cluster=539(0x21b), pos=339629
FAT: cluster=540(0x21c), pos=339693
1 * FAT32 0 1 1 140 254 63 2265102
external harddisk not accessible anymore
Re: external harddisk not accessible anymore
Partition found by TestDisk is only 1.1 GB.
Probably wrong, because it's too small.
But in your partition table is a partition whicht fits.
Could you have a boot sector diagnose?
Confirm at Boot.
Please let us know, do you see your data or an error message.
Procedur would be like in this thread;
If you're able to watch your data, you could write your boot sector.
Confirm at Boot.
I followed the procedure and the screenshot is shown below. I was able to list the files. The directory listing gave zeros for each file.
As you can see it is a 640 Gb disk.
What is the best way to continue?
Thank you very much,
Tinka
Tinka
- screenshot
- screenshot1.png (40.61 KiB) Viewed 6596 times
Please confirm at "Write" with enter and y.
Close TestDisk using Quit.
Restart your PC that changes take effect.
Check the result.
If chckdsk (Autochk) appears, please stop it by pressing any key.
Let me know the result.
Check the result.
I can see my data again. You are wonderful! I will make a donation.
Thank you,
Tinka
Thank you,
Tinka
hi,
i also have a Adata CH94 external usb harddisk that suddenly stopped working. When I plug it in, My computer asks me to format the drive.
i followed the procedures above by
1. rebuild bs
2. when a list of files shown, pressed q to previous screen
3. pressed 'list', after which the screen says 'no file found, filesystem may be damaged'
can you advise what is the next step? thank you.
1. rebuild bs
- testdisk_list.png (55.98 KiB) Viewed 6377 times
- after i finished 'rebuild bs', shows list of files
- testdisk1.png (67.64 KiB) Viewed 6377 times
- after i finished 'rebuild bs' and pressed q to previous screen
- testdisk.png (69.44 KiB) Viewed 6377 times
