file recovery from a deleted partition on a image file. err hard drive too small
saffa747
#1 Post by saffa747 »
Please help. here is a screenshot and log file Image
Sun Dec 30 14:29:41 2018
TestDisk 7.1-WIP, Data Recovery Utility, September 2018
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=160040803840
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=160040803840
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249035405312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=160037863424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=250058113024
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 Series, S/N:S14GNEACB96348Y, FW:DXT08B0Q
Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST3160815AS, S/N:6RA0D24N, FW:3.AAC
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DL002-9TT153, S/N:W1V09B9C, FW:CC32
Drive G: - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Analyse Drive G: - 250 GB / 232 GiB - CHS 30401 255 63
block_group_nr 1
recover_EXT2: s_block_group_nr=1/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 61049344
recover_EXT2: part_size 488394752
Filesystem created: Sat Oct 20 00:02:24 2018
Linux 0 0 1 30401 42 41 488394752
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 250 GB / 232 GiB
Partition not added.
Linux Swap 17 86 6 278 107 5 4194288
SWAP2 version 1, pagesize=4096, 2147 MB / 2047 MiB
block_group_nr 25
recover_EXT2: s_block_group_nr=25/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_block_group_nr=0/1863, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Sat Oct 20 00:09:35 2018
Linux 15176 92 21 45577 134 61 488394752
ext4 blocksize=4096 Large_file Sparse_SB Recover, 250 GB / 232 GiB
This partition ends after the disk limits. (start=243808256, size=488394752, end=732203007, disk end=488394752)
Linux 15178 167 30 45579 210 7 488394752
This partition ends after the disk limits. (start=243845120, size=488394752, end=732239871, disk end=488394752)
Linux 15187 17 63 45588 60 40 488394752
This partition ends after the disk limits. (start=243980288, size=488394752, end=732375039, disk end=488394752)
Linux 15197 166 10 45598 208 50 488394752
This partition ends after the disk limits. (start=244150272, size=488394752, end=732545023, disk end=488394752)
Linux 15198 203 46 45599 246 23 488394752
This partition ends after the disk limits. (start=244168704, size=488394752, end=732563455, disk end=488394752)
Linux 15225 47 55 45626 90 32 488394752
This partition ends after the disk limits. (start=244592640, size=488394752, end=732987391, disk end=488394752)
Linux 15227 90 32 45628 133 9 488394752
This partition ends after the disk limits. (start=244627456, size=488394752, end=733022207, disk end=488394752)
Linux 15249 71 55 45650 114 32 488394752
This partition ends after the disk limits. (start=244979712, size=488394752, end=733374463, disk end=488394752)
Linux 15263 175 17 45664 217 57 488394752
This partition ends after the disk limits. (start=245211136, size=488394752, end=733605887, disk end=488394752)
Linux 15282 76 27 45683 119 4 488394752
This partition ends after the disk limits. (start=245510144, size=488394752, end=733904895, disk end=488394752)
file_win32_pread(560,2,buffer,488394751(30401/42/41)) read err: read after end of file
The harddisk (250 GB / 232 GiB) seems too small! (< 375 GB / 349 GiB)
* Linux Swap 17 86 6 278 107 21 4194304
SWAP2 version 1, pagesize=4096, 2147 MB / 2048 MiB
1 * Linux Swap 17 86 6 278 107 21 4194304
block_group_nr 1
block_group_nr 3
recover_EXT2: s_block_group_nr=3/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/1863, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
block_group_nr 27
block_group_nr 49
block_group_nr 81
block_group_nr 125
block_group_nr 243
block_group_nr 343
block_group_nr 625
block_group_nr 729
interface_load
Re: file recovery from a deleted partition on a image file. err hard drive too small
If you want to recover a deleted partition, select a PhysicalDrive, not a drive letter. It's useless to search partitions inside a partition.
saffa747
#3 Post by saffa747 »
i had to mount the image so that testdisk would create a log file. for some reason it does not create one when recovering from an image. so are you saying i should write the image to the original drive? i got the same error when performing the search on the physical drve
saffa747
#4 Post by saffa747 »
cgrenier wrote: 14 Jan 2019, 06:45 If you want to recover a deleted partition, select a PhysicalDrive, not a drive letter. It's useless to search partitions inside a partition.
#5 Post by cgrenier »
Do not mount the image file.
Run "cmd", go in testdisk-7.1-WIP directory, run "testdisk_win.exe /log image.dd" Fix the image.dd pathname if necessary.
saffa747
#6 Post by saffa747 »
cgrenier wrote: 17 Jan 2019, 07:21 Do not mount the image file.
thank you I will post result when done
saffa747
#7 Post by saffa747 »
here are the results
Using locale 'C.UTF-8'.
Fri Jan 18 16:27:26 2019
Command line: TestDisk /log D:\image.dd
Disk D:\image.dd - 250 GB / 232 GiB - CHS 30402 255 63 (RO), sector size=512
Media is opened in read-only.
Fri Jan 18 16:29:41 2019
Command line: TestDisk /log d:\image.dd
Disk d:\image.dd - 250 GB / 232 GiB - CHS 30402 255 63 (RO), sector size=512
Disk d:\image.dd - 250 GB / 232 GiB (RO)
Analyse Disk d:\image.dd - 250 GB / 232 GiB - CHS 30402 255 63 (RO)
#8 Post by cgrenier »
image.dd is the image of a partition, not the image of a disk.
If you work on this file, choose partition table type: None, Advanced, Superblock or List.
