Recovering/Resolving MacOS Partition Issue
cjscheller
#1 Post by cjscheller »
Macbook Pro running High Sierra will not boot, diskutil repairDisk returns the following message: "Couldn't repair the partition map because a new EFI system partition couldn't be created"
Testdisk Quick Search generated following report:
TestDisk 7.1-WIP, Data Recovery Utility, December 2018
OS: Darwin, kernel 16.7.0 (Darwin Kernel Version 16.7.0: Tue Jan 30 11:27:06 PST 2018; root:xnu-3789.73.11~1/RELEASE_X86_64) x86_64
Compiler: GCC 4.0
Compilation date: 2019-01-11T07:56:50
Disk /dev/disk0 - 500 GB / 465 GiB - 977105060 sectors (RO), sector size=512
Disk /dev/disk1 - 500 GB / 465 GiB - 122086923 sectors, sector size=4096
Disk /dev/disk2 - 500 GB / 465 GiB - 976773168 sectors (RO), sector size=512
Disk /dev/rdisk0 - 500 GB / 465 GiB - 977105060 sectors (RO), sector size=512
Disk /dev/rdisk1 - 500 GB / 465 GiB - 122086923 sectors, sector size=4096
Disk /dev/rdisk2 - 500 GB / 465 GiB - 976773168 sectors (RO), sector size=512
Media is opened in read-only.
Disk /dev/disk0 - 500 GB / 465 GiB (RO)
Partition table type: EFI GPT
Analyse Disk /dev/disk0 - 500 GB / 465 GiB - 977105060 sectors (RO)
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=977105059 (expected 977105059)
hdr_lba_start=34
hdr_lba_end=977105026
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
7c3457ef 0000 11aa aa 11 00 30 65 43 ec ac
 1 P EFI System                    40     409639     409600 [EFI System Partition]
 2 P Unknown                   409640  977105023  976695384 [Macintosh HD]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT differs, FAT sectors=608-624/3151
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
     EFI System                    40     409639     409600 [EFI System Partition] [EFI]
     Unknown                280550117 114451516807908 114451236257792
     WBFS, 58599 TB / 53295 TiB
Partition not added.
LVM magic value at 293835926/0/1
   P EFI System                    40     409639     409600 [EFI System Partition] [EFI]
dir_partition inode=0
FAT: cluster=2(0x2), pos=6374
       3 drwxr-xr-x     0      0         0 28-Dec-2017 18:45 EFI
    2566 drwxr-xr-x     0      0         0 12-Feb-2013 13:14 .Trashes
   78104 -rwxr-xr-x     0      0    170349 28-Dec-2017 18:45 BOOTLOG
 1 P EFI System                    40     409639     409600 [EFI System Partition] [EFI]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Based on instructions, I'm unclear if best next steps are to use fsck to repair damaged partition or use Testdisk to write new partition. Any suggestions?
Re: Recovering/Resolving MacOS Partition Issue
Your partition table lists an Apple APFS filesystem. Since macOS High Sierra, all devices with flash storage are automatically converted to APFS.
The partition table looks OK. Do not try to repair or fix this disk using Sierra or an older version, you really need High Sierra.
cjscheller
#3 Post by cjscheller »
Got it, thanks. I've created a bootable USB running High Sierra and have been attempting to repair. Have not had success with macOS Disk Utility repair, TestDisk, or Data Rescuse. Was going to give Disk Warrior a shot but APFS not currently supported. Any thoughts/recommendations on what I should try next?
