Hey,
there was a power failure, the computer went out (Win7 system). After running, he cries out that there is no boot partition. SSD drive. It removes from the computer, I connect it with an external controller. Checking. Indeed, it is not formatted. I run Testdisk, search for partitions. The result is clean, no recovery.
What now? There is some important data.
https://imgur.com/a/4FLwe26
Power failure. Lost partition.
Re: Power failure. Lost partition.
Can you try PhotoRec and check if it recovers some data or not ?
