Win10 disk not readable anymore
mada
#1 Post by mada »
Hey,
possibly the 1000th time that this question pops up, but I can't get it to work...
After fiddling around with dualboot, changing parameters in the BIOS and so on I finally managed to get my Win 10 System to not work any more. The Disc appears in the BIOS but it won't boot from there any more.
First step was to try the Win10 USB repair, at some point a guide required to
"c:\Windows /l de-de /s B: /f ALL"
but this didn't work because I cannot access/read the drive anymore.
Then I found diskpart.
EFI/GPT was found on the disc, here's the first Output
Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63
        Bad GPT partition entries, invalid checksum.
Trying alternate GPT
 1 P Windows Recovery Env        2048     616447     614400 [Basic data partition]
 2 P EFI System                616448     821247     204800 [EFI system partition]
 3 P MS Reserved               821248    1083391     262144 [Microsoft reserved partition]
 4 P MS Data                  1083392  246614878  245531487 [Basic data partition]
 5 P Windows Recovery Env   246616064  248223743    1607680
 6 P Windows Recovery Env   249147392  250068991     921600
after the scan it looks like this
        The harddisk (128 GB / 119 GiB) seems too small! (< 253 GB / 236 GiB)
>  MS Data                248225791  495368190  247142400
continue...
>P MS Data                     2048     616447     614400 [Wiederherstellung]
 P MS Data                   616448     821247     204800 [NO NAME]
 D MS Data                  1083392  246614878  245531487
 D MS Data                  1083392  248225791  247142400
 D MS Data                245008385  246616064    1607680
 D MS Data                246616064  248223743    1607680
 D MS Data                247304193  248225792     921600
 D MS Data                248225792  249147391     921600
 D MS Data                248225793  249147392     921600
 D MS Data                249147392  250068991     921600
                P=Primary  D=Deleted
     Enter: to continue
NTFS, blocksize=4096, 314 MB / 300 MiB
Now I'm confused on how to continue...
I don't Need the disk to be bootable, I just need access to the data in order to secure some important files.
Help would be much appreciated!
Thank you
Mark
Re: Win10 disk not readable anymore
You should set the same partition layout than displayed on the first screen :
Set the other partitions as D(eleted). Use 'a' to manually add a partition if necessary, 't' to change the partition type.
On next screen, choose Write, confirm, Quit and restart your computer.
mada
#3 Post by mada »
Hello cgrenier,
first, thanks for your great tool! And again, thank you for the answer.
the "D"elete option scared me off so I wanted to be 100% sure... nevertheless, I tried messing around with this further on and now the situation has changed. As I could see the data with another tool called "Minitool Partition Wizard" my hope grew, but I screwed it up I think and now the disc is displayed as "raw". I turned the computer off otherwise I would've thrown it out of the window....
I will provide another screenshot this evening, hopefully there is still hope...
mada
#4 Post by mada »
just to give an update: I was able to recover the files from the disk without having to repair the filesystem, so I just formatted the disk afterwards ;)
Thanks though for the tool and the help!
JohnnyB1234
#5 Post by JohnnyB1234 »
Hi, what did you do finally recover your data? thanks, JB
