4tb hdd, split into 2 pats., 1 raw, 1 unaloc. i didnt do.
darkmj16
#1 Post by darkmj16 »
well... this one has me drawing a blank. the last time i unplugged the hdd it was fine. did safe removal (even though i dont need to). but now i put it into my new computer build and all of a sudden the drive is split into 2 partitions. 1 is 2048gb raw. and the other is 1678.02gb unallocated this is a 4tb drive. of windows is saying the disk has to be formatted 1st. and i cant do anything to the unallocated space. i have about 1.5ish tb of data i believe.
ive read the testdisk manual and im confused. bc the options it has dont match what i see. i do have the quick search scan and then the deeper scan (running now) and its coming back with fat16 invalid boot fat12 invalid boot...ect pretty sure i had the hdd formatted as ntfs.
it also said something about mismatched size and to check the jumpers and bois setting... i have checked the bois. and it sees the drive as a 4tb and all the info like manf. serial number ect. the drive itself i do not see any jumpers on?
can someone please help me.
Re: 4tb hdd, split into 2 pats., 1 raw, 1 unaloc. i didnt do.
When you scan the disk, choose EFI GPT instead of PC Intel.
Can you copy/paste the testdisk.log file content ?
darkmj16
#3 Post by darkmj16 »
update: didnt want to waste a post with the update but i didnt realize the efi scan was so slllooooowwwwww. itll probably be an overnight scan
ill do the new scan after work. heres the testdisk.log. i believe it only shows the quick scan. bc at the end of the log i posted what i see in the tool after the deep scan.
Thu Feb 21 18:34:05 2019
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249481396224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2199022206976
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Drive C: - 249 GB / 232 GiB - CHS 30331 255 63, sector size=512
Drive D: - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
New options :
Dump : No
Align partition: Yes
Expert mode : No
test_FAT()
1 P FAT16 >32M 0 32 33 267349 89 4 4294965248
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
fat1x_boot_sector
Bad
Analyse Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
file_pread(5,1,buffer,3519070207(486401/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519070208(486401/86/22)) lseek err Invalid argument
file_pread(5,14,buffer,3519070209(486401/86/23)) lseek err Invalid argument
file_pread(5,3,buffer,3519070223(486401/86/37)) lseek err Invalid argument
file_pread(5,3,buffer,3519070270(486401/87/21)) lseek err Invalid argument
file_pread(5,8,buffer,3519070286(486401/87/37)) lseek err Invalid argument
file_pread(5,11,buffer,3519070333(486401/88/21)) lseek err Invalid argument
file_pread(5,2,buffer,3519072255(486401/118/53)) lseek err Invalid argument
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
fat1x_boot_sector
Bad
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
BAD_RS LBA=843518476 7716552
FAT16 <32M 52506 152 11 115174 132 42 1006760192
BAD_RS LBA=2693512726 13101410
FAT32 435012 194 21 581280 53 11 2349786528
This partition ends after the disk limits. (start=6988480022, size=2349786528, end=9338266549, disk end=7814037168)
BAD_RS LBA=40349630 783733
FAT12 269860 254 25 342571 88 5 1168091738
file_pread(5,2,buffer,3519070208(486401/86/22)) lseek err Invalid argument
The harddisk (4000 GB / 3726 GiB) seems too small! (< 4781 GB / 4452 GiB)
L FAT16 <32M 52506 152 11 115174 132 42 1006760192
L FAT12 269860 254 25 342571 88 5 1168091738
add_ext_part_i386: max
add_ext_part_i386: min
1 * FAT16 <32M 52506 152 11 115174 132 42 1006760192
2 E extended LBA 269860 0 1 342571 254 63 1168118280
5 L FAT12 269860 254 25 342571 88 5 1168091738
deep scan results that were on the tool window:
HPFS - NTFS 448335 112 30 515107 143 49 1072694153
> FAT12 474843 120 61 567795 106 52 1493272990
[ Continue ]
764 GB / 712 GiB
darkmj16
#4 Post by darkmj16 »
ok so the scan has been going for 16 hours and is only 14% done... do i need to let it run the whole scan?? heres what on the screen right now...nvm idk what i did but appearemtly the scan stopped and the info is gone. the testdisk. log says this.... which was on the scan but on the scan also was this
Fri Feb 22 19:44:46 2019
Partition table type: EFI GPT
Trying alternate GPT
ms data 250323635 252859836 2536201 [^D*4^Y~K~A/m\^G
darkmj16
#5 Post by darkmj16 »
restarted the scan just to get this info. the computer is off till someone replys.
Analyse cylinder 17333/486400: 03%
MS Data 250323635 252859836 2536201 [^D*4^Y~K~A/m\^G M-$ 34]
