I think I need your help. I have SanDisk 128 GB SD card and used it in Sony Experia Z3 Compact android mobile. After I put it away I have got it corrupted and now Sony mobile cannot read it and Windows 10 also cannot read it.
I finaly find your application that suppos to be very powerfull. I think it can help me to recover the file system or partitions.
When I put it by card reader to windows 10 it tells it si OK but only "31 MB RAW" as primary partion.
Whe I try to open it. It says "Disc must be formated before using and when I Cancel it tells that the disk does not contain any system.
Whe I run TestDisk application it tells this:
>Disk /dev/sdc - 32 MB / 30 MiB - SD
So firstly I have to make it to recognize the right size but I do not know how. I have the newest drivers and windows 10.
Can you help or hint if this is possible?
Here is th log of TestDisk:
Wed Feb 27 16:38:16 2019
TestDisk 7.1-WIP, Data Recovery Utility, December 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000392994816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=32096256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000392994816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=32096256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=511450284032
filewin32_getfilesize(\\.\D:) GetFileSize err Nesprávná funkce.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Nesprávná funkce.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000388063744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=32096256
Disk /dev/sda - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - ADATA SSD SX900 512GB-DL2, S/N:7E4420000290, FW:5.4.1
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512 - WD My Book, S/N:WU2Q10045836, FW:1017
Disk /dev/sdc - 32 MB / 30 MiB - CHS 3 255 63, sector size=512 - SD, FW:0001
Best Reagrds
Wrong size of corupted SD card from Android mobile
- obr.png (41.73 KiB) Viewed 1794 times
Re: Wrong size of corupted SD card from Android mobile
The flash controller may be damaged. You should contact a data recovery company.
Thank you for answer even if it's not good.
Best regards.
Best regards.
