SSD Diskpart Clean
Paul77
SSD Diskpart Clean
#1 Post by Paul77 »
Accidentally ran Diskpart Clean on data SSD drive. I followed the instructions in the PDF but have not been successful. Also, I believe the drive was bitlocked :x
Tried the default (intel) quick and deep scan.
The tried scanning with type none and selecting NTFS
Now trying to scan EFI which is super slow.
Here's the log file.
Fri Mar  1 10:49:14 2019
TestDisk 7.1-WIP, Data Recovery Utility, December 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=7601479745536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=7601479745536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255465619456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=7601460871168
Disk /dev/sda - 7601 GB / 7079 GiB - CHS 924160 255 63, sector size=512 - Intel Raid 1 Volume, S/N:Volume0, FW:1.0.
Disk /dev/sdb - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - NVMe SSDPEKKF256G8 NV, S/N:BTHH83530TNU256B, FW:D05N
Disk /dev/sdc - 1024 GB / 953 GiB - CHS 124519 255 63, sector size=512 - NVMe KXG50ZNV1T02 NVM, S/N:78ES10GXT8KQ, FW:4105
Disk /dev/sdc - 1024 GB / 953 GiB - NVMe KXG50ZNV1T02 NVM
Analyse Disk /dev/sdc - 1024 GB / 953 GiB - CHS 124519 255 63
BAD_RS LBA=3999945660 7255034
file_pread(6,3,buffer,3999945660(248985/25/61)) lseek err Invalid argument
file_pread(6,1,buffer,3999945660(248985/25/61)) lseek err Invalid argument
     FAT16 >32M           248985  25 61 429990 147 20 2907852971
This partition ends after the disk limits. (start=3999945660, size=2907852971, end=6907798630, disk end=2000409264)
file_pread(6,2,buffer,2000410623(124519/204/37)) lseek err Invalid argument
file_pread(6,1,buffer,2000410623(124519/204/37)) lseek err Invalid argument
file_pread(6,2,buffer,2000410624(124519/204/38)) lseek err Invalid argument
file_pread(6,14,buffer,2000410626(124519/204/40)) lseek err Invalid argument
file_pread(6,3,buffer,2000410640(124519/204/54)) lseek err Invalid argument
file_pread(6,3,buffer,2000410687(124519/205/38)) lseek err Invalid argument
file_pread(6,8,buffer,2000410703(124519/205/54)) lseek err Invalid argument
file_pread(6,11,buffer,2000410750(124519/206/38)) lseek err Invalid argument
file_pread(6,2,buffer,2000412672(124519/237/7)) lseek err Invalid argument
The harddisk (1024 GB / 953 GiB) seems too small! (< 3536 GB / 3293 GiB)
Store new MBR code
Store new MBR code
Partition table type: None
   P Unknown                  0   0  1 124519 182 63 2000409264
Change partition type:
   P NTFS                     0   0  1 124519 182 63 2000409264
Partition table type: EFI GPT
Trying alternate GPT
New options :
 Dump : No
 Align partition: Yes
 Expert mode : Yes
Re: SSD Diskpart Clean
As the disk was blitlocked, when using TestDisk, Analyse, QUick Search, Stop, manually add a partition ('a' key) starting at sector 2048.
Set the type to MS DATA / NTFS. On next screen, choose Write, confirm, Quit.
If you are lucky, you will be able to unlock your bitlocked drive and access your data.
