WD My Book Studio 3TB Mac External Hard Drive Storage USB 3.0
Formatted HFS+ journaled
I've installed macDrive to access my Mac files in a Windows environment. I accidentally deleted the partiton of my HFS + Journeled Formatted disc. Since this process I cannot access my information. In addition, 1936 near the Hd Regenerater program with bad sector output diskimde. How do I save my data and information from my disk that I shared a screenshot below?
Destekleniyor = Not Supported.
what would you recommend for a disk that is in this state? I have 15 years of photos. Waiting for your support and help.
My English is not very good. I am writing using Google translation.
Thanks.
My Book Studio 3 TB missing
pilgrimage
- mac_disk_status.jpg (41.21 KiB) Viewed 2080 times
- Ekran Resmi 2019-03-06 15.57.18.png (34.28 KiB) Viewed 2080 times
- BAD_SECTOR_RECOVED222.jpg (115.74 KiB) Viewed 2080 times
Re: My Book Studio 3 TB missing
You should clone your damaged disk to a new empty disk using ddrescue, remove the original disk and use testdisk to restore your deleted partition on the clone.
If your recovered partition isn't readable, use photorec to recover your data. You will need enough space to store the recvored data (documents, pictures, videos...)
pilgrimage
When I scan the disc quickly, a message appears as follows. What should I do ? I got stuck here.
thankyou.
thankyou.
- Ekran Resmi 2019-03-08 14.36.35.png (33.22 KiB) Viewed 2053 times
pilgrimage
What should I do ? I need guidance.
Pls help me ? ?
Pls help me ? ?
- Ekran Resmi 2019-03-08 15.23.27.png (64.75 KiB) Viewed 2045 times
- Ekran Resmi 2019-03-08 15.24.39.png (41.75 KiB) Viewed 2045 times
