How can I learn disk blockize sector size information?
pilgrimage
#1 Post by pilgrimage »
I want to save partiton with the pdisk command, but I need disk information. How do I get this information
The test disc does not show this information.
First block ??
lenght in block ??
thankyou.
Re: How can I learn disk blockize sector size information?
What are you looking for exactly? "block size" or "sector size"?
I don't know what you mean by "blockize sector size".
pilgrimage wrote: 11 Mar 2019, 08:51 I want to save partiton with the pdisk command, but I need disk information. How do I get this information
First block ??
lenght in block ??
"First block" and "lengths in blocks" is not a disk specific information.
They depend on the partitioning scheme.
"Sector size" however ist disk specific, it is static and does not change.
When you are talking about "blocks" you probably mean "cluster".
If testdisk does not show cluster or sector information it's because this partition information is missing.
You can have testdisk search for partitions.
If you change your tool to work on a disc using "pdisk" the underlying base problems remain the same - unfortunately.
