Function not implemented
westmantooth
#1 Post by westmantooth »
I have been given an Encase E01 file which has a deleted partition. I am attempting to recover it using testdisk but getting an error. If looked at the man page but can't see what I'm doing wrong. I've double checked the path to the file etc. Output below. Any help would be greatly appreciated.
Thanks
root@kali:~# testdisk /mnt/hgfs/Forensics/CaseOX201804.E01
Unable to open file or device /mnt/hgfs/Forensics/CaseOX201804.E01: Function not implemented
Re: Function not implemented
Run "testdisk -v". Is ewf lib enabled ?
If it's not the case, download and compile testdisk source code as described in https://www.cgsecurity.org/testdisk.pdf
Good luck
