I had a hard drive with my important files accidentally fast formatted and a restore partition incorrectly put on it yesterday.
It looks like most of my files that were on other partitions but C are there, but it's taking FOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOORRRRRRRRRRRRREEEEEEEEEEEEEEEEEVVVVVVVVVVVVVVEEEEEEEEEEEEERRRRRRRRRRRRRRRR to recover them. On what seems to be a reasonably fast i5 system.
However it appears I can do other things with the computer without having any effect.
Can I by any chance run more than instance of testdisk at a time?
Dora
Can I run more than one instance of testdisk at once
Re: Can I run more than one instance of testdisk at once
Yes, it's possible to run several instance of testdisk at the same time.
But do not run several instances of PhotoRec unless you have started photorec from the command line in a different working directory.
