I have accidentally written a 6GB USB Stick Image to a 2TB NTFS Drive (other Linux sdx order of the external drives this time).
I have overwritten that first 6GB with zeros so it is clearly invalid now, so no partition table, bootsector and MFT.
As far I understood there is a Backup-Boot-Sector at the end of the NTFS-Drive which testdisk can find with deep search and restore partition table and boot sector from.
There is also an Backup MFT / Mirror but haven't found for sure if also at the end and so still on my disk.
Doc says testdisk can copy Backup MFT (hopefully at the end) to MFT.
If I can restore the partition (table) with testdisk, should I copy the Backup MFT, or does chkdsk restore the filesystem from Backup MFT when only zeros in the MFT?
NTFS MFT overwritten
Re: NTFS MFT overwritten
Deeper Search found several Partitions, on NTFS spanning the whole disk which is may be the right one.
Pressing P for List Files only says Filesystem corrupt.
Does this Test check the MFT Mirror at all, I know MFT is only zeros.
Unfortunately I pressed <Enter> and have to start over again.
It would be really nice if testdisk stored it's results and could continue with.
Will need 8 hours now to get to the same point.
sachinkhanna32
Hi, I have the same problem. If I Format the drive will it solve the issue.iwlf wrote: 29 May 2019, 21:53 Deeper Search found several Partitions, on NTFS spanning the whole disk which is may be the right one Pressing P for List Files only says Filesystem corrupt. Does this Test check the MFT Mirror at all, I know MFT is only zeros. Unfortunately I pressed <Enter> and washing machine have to start over again. It would be really nice if testdisk stored it's results and could continue with. Will need 8 hours now to get to the same point.
With formating you delete more and recover nothing.
